Question about Motorola Mobility V360 Cellular Phone
Describe Motorola v360 sync with a server. Can I create an own server or can I use my Gmail account for example? I want to save or backup the smses. In other words I want to transfer the messages to a new phone. Unfortunately the new phone is locked to an another provider so I can't change the two SIM cards. Thanks!
Tip
How to Sync Phone Contacts between a Motorola Droid and Gmail
<p>If an Android phone, the Motorola Droid has a feature that automatically synchronizes the information from phone applications associated with Google Account. This function includes an automatic synchronization between Gmail contacts to phone contacts. The process is immediately at any time a change is made. All the user has to do is the username and password in the right time. <br /> <p><br /> <p>Initial Setup <br /> <p>1. Turn your Droid, the first time. <br /> <p><br /> <p>2. Choose or create a new account or login into an existing Gmail account. Click "Next." <br /> <p><br /> <p>3. Enter your username and email password when prompted. Click "Sign In" or "Create". <br /> <p><br /> <p>After the initial setup <br /> <p>1. Press the "Menu" button on your Droid. <br /> <p><br /> <p>2. Click Settings. Click on "Account & sync." <br /> <p><br /> <p>3. Click "Add Account". Click on "Google." <br /> <p><br /> <p>4. Choose or create a new account or login into an existing Gmail account. Click "Next." <br /> <p><br /> <p>5. Enter your username and email password when prompted. Click "Sign In" or "Create". <br />
on Aug 18, 2011 | Google Android
Tip
Backup SMS Messages In Windows Mobiles With Imap SMS Backup
There can be an instance in your life, when you might delete any single SMS or all the SMSs in your mobile phone by mistake. And worst of all, you needed them badly. They were important and now they are disappeared into a thin air. You can easily save yourself from facing such a situation in case you are proud owner of a Windows mobile device. SMSSyncUp is a WM application that will help you to sync up/backup your SMSs to your gmail account from your device.
How To Use SMSSyncUp :
1. Install it
2. Choose your Gmail Account.
3. Open the application, and fill the Send To: with the gmail id to which you want to backup sms.
4. Go to Menu “Login”(it is not an actual login, you need to configure your Gmail account for it).
5. Login should enable the SMS folders dropdown with all your SMS folders.
6. Select the folder to backup.
7. Go to Menu “Sync SMS Folder”. This should start the message conversion to mail format. Progress will be displayed.
8. On completion it will prompt and then ask you if you want to sync.
9. Syncing would send Emails with Subject IMAPSMS| :Sender and the body will contain Message and time, the subject should help you to create proper rules in your gmail account.
on Mar 03, 2010 | Cell Phones
Trying to backup my old account or gmail to my new account or gmail
You may not be able to do a "back up.
If you now have 2 different email addresses and 2 user names. Open the old one and select and send all the emails you want to save to the NEW email account.
Backup is usually done by an admin on the GOOGLE server itself.which we would not have access to.
Jul 24, 2014 | Computers & Internet
Sign in google chrome
first download and install browser.
https://www.google.com/intl/en/chrome/browser/
Second when chrome browser first opens it will ask to make the default browser and ask you to create a gmail account.
if you re pen internet explorer it will ask you to make it the default again, browser to select no and check to box to never asks again.
Once a gmail account is created, and Chrome is logged into your gmail account, you'll be all set. All the google apps are auto synced to your chrome.
The mail purpose for syncing chrome to your gmail account, is for all shortcuts, bookmarks and home page info you set on your chrome is backup on your gmail account. this way if you log into chrome anywhere, your defaults will follow you. the same will be for chrome on mobile devices, phones and tablets.
Apr 30, 2014 | Computers & Internet
I m looking for email configuration for samsung corby
Note 2 Email accounts and Email section profiles
STEP 1: Create an email account on your phone
Go to E-mail accounts to create an email account (eg Gmail). You will see a screen installation instructions Email> Yes
Mailbox name: The name of the mailbox (you can put anything you like)
Then select Options, select Next to the mailbox. You will see two types of POP3 and IMAP4 (default every Gmail account has been activated POP3 allows sending and receiving mail from a mail client, here is the phone of you. If you want to use IMAP4 account Gmail using your computer to enable IMAP4 for your account because of Gmail IMAP4 default is Disable.) In this section using POP3
Click Next to enter information in the Your email account.
In My Email address box enter your Email address (eg samsung@gmail.com), The User name will automatically be filled in after you enter your email address. Then enter your gmail password (******)
Then select Next to address server and receiving mail server to send mail. (Phone automatically entered so you do not care)
Next to finish the account creation process.
For Gmail you need to install some new numbers on a phone is used, as follows:
After completing the above created account, you go back to Menu Email accounts to edit the parameters for Gmail.
At this time we have created an account named Babi, now I'll edit it (Options> Edit)
You may notice two parts Incoming mail server (the server to receive mail) & Outgoing mail server (mail server):
Incoming mail server you choose, check Secure connection and then Save again
Then go back and select the Outgoing mail server, also check Secure connection> Save
At this point you have completed STEP 1.
STEP 2: Create a connection to the account.
Guide to Vinaphone. Mobifone and Viettel similar
Email back your menu to create a connection profile (as created for the WAP GPRS connection). You select any one profile and select Options> Edit
O Profile name (profile name) can put anything you like, but so named for the network to be distinguishable.
Configuration of Vinaphone Email: APN: m3-world Login ID: mms Password: mms
(Viettel, the selected APN Network: v-internet)
Then choose Save to save your settings.
At this point you have completed the installation Email. Can now be used right:
Message Menu and select the Email Inbox and select Check for new mail check mail from your mailbox.
You will see a list of new mail is fetched. But that's just the title of the email you received. To view the full text, as well as downloading email attachments of the sender. You select Options> Retrieve to restore the email you want.
Mar 17, 2011 | Computers & Internet
I want to know if there's a way / software to sync my Samsung SGH-i607 with my Gmail account.
Yes, the SGH-i607 can support an IMAP account, and Gmail can be accessed through IMAP. They don't list the SGH-i607 as a supported client, but it should be possible to configure it to work with Gmail.
First, go to your gmail account and enable IMAP:
Sign in to Gmail. Click the gear icon in the upper-right and select Gmail settings at the top of any Gmail page. Click Forwarding and POP/IMAP. Select Enable IMAP. Click Save Changes.
Next, configure the SGH-i607:
While in standby mode, press the left soft key for Start Select Messaging Select New Account (3) Select Other (POP3/IMAP), using the navigation keys Press the right soft key for Next Enter your name & E-mail address, using the Qwerty keypad Press the right soft key for Next For User Name, enter your full email address (including @gmail.com), using the Qwerty keypad . For Password, enter your Gmail password. For Domain, enter gmail.com. Press the right soft key for Next. For Server Type, choose IMAP. For Account Name, enter your full email address (including @gmail.com). Press the right soft key for Next. For Incoming Server, enter imap.gmail.com and select "Require SSL connection". For Outgoing Server, enter smtp.gmail.com and select "Outgoing server requires authentication". Press the right soft key for Next. Select desired message settings, using the navigation keys. Press the right soft key for Next. Select desired configurations for Storage and Connection. Press the right soft key for Next. After you have determined how often the device will connect, press the right soft key for Next. Setup will now be complete. Pressing the right soft key for Finish will enter the newly-created account in the Messaging application.
Mar 05, 2011 | Samsung Blackjack SGH-I607 Smartphone
I own LG GW620 cellphone & want to backup my phone by synchronizing its phone contacts and sms messages on to my PC. How do i do that. plz assist
1. make sure you have a gmail account and that it has been set up on your phone.
2. go to settings/general sync settings/contacts and activate.
This will automatically sync with your gmail account. You can check it by logging in to your gmail (on a pc for example) and going to the contacts section of your account.
Aug 02, 2010 | Cell Phones
How to configer email address in lotus notes
From what provider are you trying to configure email?If its gmail,
1. Create a Lotus Notes database file to store your POP emails: Lotus Notes does not create a file automatically as Thunderbird or other mail clients do but you have to manually point the mails to flow to a file that is already existing.
2. In the local Address Book, create two accounts for accepting incoming email and sending outgoing email on Gmail. Names are not important but the configuration on the two accounts is!
Account document for Incoming Gmail:
The Basics tab
a. Account name: Can be anything (I chose In Gmail)
b. Account server: pop.gmail.com
c. Login Name: Your gmail email address (complete with the @gmail.com)
d. Password: Your password
e. Protocol: POP
f. SSL: Enabled
g. Only from Location(s): Doesn't matter. Although I would recommend creating a location document specific for Gmail if you are also using Domino Server. I chose creating a location (Gmail).
Protocol Configuration tab: There is only one field here and it doesn't matter what you do with it.
Advanced Tab: This is the most important tab.
a. Port Number: 995
b. Accept SSL site certificates: Yes (Most of the articles on the web tell you to choose No here. But it does work. Trust me. I have tried it)
c. Accept expired SSL certificates: Yes. (Most of the articles on the web tell you to choose No here. But it does work. Trust me. I have tried it)
d. Send SSL certificates when asked (outbound connections only): No.
e. Verify account server name with remote server's certificate: Disabled
f. SSL protocol version: V3.0 with V2.0 handshake
3. Click on Save and Close to save the document and exit. Now you will need to create another account document to handle the outgoing email.
Account document for Outgoing Gmail:
The Basics Tab
a. Account Name: Can be anything. I chose Out Gmail
b. Account server name: smtp.gmail.com
e. Protocol: SMTP
f. SSL: Enabled
a. Port Number: 587 or 465 (Both are SSL port and both work)
4. Once these two documents are created, I would recommend creating a location document to ensure that you separate your gmail from your other Domino based account on the client. The steps to create are:
5. In the same local Address Book, choose New --> Location
Basics Tab:
a. Location Type: Local Area Network
b. Location Name: Can be anything (I chose Gmail)
c. Internet Mail Address: Your gmail email address
Leave the rest as it is.
Servers Tab:
a. Home/Mail server: pop.gmail.com
Ports tab: No changes (ensure TCPIP is checked)
Mail Tab (Most important):
a. Mail file location: Local
b. Mail file: My Gmail.nsf (whatever you created in step 1 above).
Update: A couple of readers pointed out that I had missed an important step in the configuration how-to. So here it is. Step C has been added to include the missed step.
c. Internet domain for Notes addresses when connecting directly to the Internet: gmail.com
d. Send Outgoing mail: directly to Internet
Leave the rest of the fields as it is.
6. There is no need to change the rest of tabs. Click on Save and Close to create the document.
Change to the the new location and you will see Gmail getting downloaded in the mail file you created.
Jul 27, 2010 | Microsoft Windows XP Professional
Can't sync outlook 2003 calendars with iPhone 3g
Synchronization of iPhone 3G with your Outlook 2003 will depend on the type of account that you would like to create. It will depend also on the Web mail that you are going to download.
Example:
1. The e-mail that you would like to download to your iPhone is your Gmail account. You have to enable POP in your Gmail sesttings.
2. On your iPhone > go to Home screen > tap settings...
3. Go to Mail > Add Account > Other > Continue...
4. For the host name: pop.gmail.com
5. For the username: type your complete e-mail address
6. For the Outgoing mail SMTP Host name: type smtp.gmail.com
7. Tap Save..
8. To verify your Advance configuration: Go to settings > click the account that you havve created > Advance
Incoming server port:
-You may use 110 or 993
-Type your password
Outgoing settings:
- You may use 25, 2525, 587 or 465
- Type your password again.
You're done.
NOTE: I just use Gmail as an example. Your incoming mail server will depend on your Web mail settings.. You may contact your e-mail administrator and ask for the Incoming mail server, Outgoing mail SMTP, ask if your account requires encryption or not.
Apr 07, 2009 | Apple iPhone 3G
Motorola Mobility V360 Cellular Phone Logo
51 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
