Question about Hotpoint Dryers
I have fault code E30 any ideas? - Hotpoint Dryers
  • 3,230 Answers
E30 indicates a motor fault.
Unplug the appliance from the wall socket, remove the lid and remove the carbon brushes from the motor. You'll probably find them worn out or broken.
Good Luck!!
Thanks
Posted on Nov 18, 2009
Rational combi oven it shows E30 MEANS I want to know code for E30
One of the lovable boyfriend present ideas that we like is usually to consider a snapshot of you in a fairly racy pose and following that have it made into a mouse pad. This way, anytime he's taking part in World of warcraft, he's thinking of you. Computer Mouse Slow Mouse Reaction AmanStino
Dec 31, 2016 | Combi Ovens
Tricity bendix aw1001w has an unknown error code, the led labled end flashing 3 times, any ideas?
It could be one of the E30 codes which would relate to the pressure switch or an earth fault on the heating element there could be a wiring fault or p.c.b. fault check wires off heater at bottom rear of machine,remove back plate 4 screws.Hope this helps.
Good Luck.
May 07, 2010 | Tricity Bendix AW1200 Front Load Washer
E30 error message what does it mean, Cheers, Dave
E30 can be a faulty pressure switch,Heating element earth fault or the main P.C.B.(Programmer).Does the machine fill with water then empty.
Most common fault is the heating element,once this is replaced it should cure the fault.
May 03, 2010 | Zanussi ZWF1430W Front Load Washer
Machine stopping mid cycle
Count the number of green flashes(1st number of error code). count number of red flashes(2nd number of error code).
Common codes are:
E10 or 11 water pressure faults.
E20 filter/pump faults.
E30 pressure switch/heater faults.
E40 door switch faults.
E50 motor faults.
E60 Heater faults.
These are some of the error codes but there are many variations on some codes depending on the model.Hpoe this has been some help.
Apr 24, 2010 | Zanussi ZWF10070W Front Load Washer
Zanussi washing machine zwf1437w error code e30
E30 indicates a pressure system fault. There can be several causes but the most frequent is a blockage in the system.
First thing to do is check the filter on front of machine.
Please do this and report your findings.
Jan 29, 2009 | Zanussi FJS1225W Front Load Washer
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
HOTPOINT WD71 ERROR E 30
Hello john walker24
Welcome
You said, you have a Hotpoint Ultima 1200 Washier dryer model WD71s and keep getting an E30 error code after it fills with water.
Any idea what the problem is?
This is what Hotpoint tells us!
E30 = A motor drive problem has occurred.Try running the programme again.
If the problem persists call for a Service Engineer.
BUT, I will tell you to unplug the appliance for 5 minutes and see if this resets the system and solves the error code.
Sometimes it is only a glitch and you can reboot and be alright if there is really no mechanical failure!!
Let me know how it goes?
Huuum,
Please remember to leave a rating!
Thank You.
Waiting for your response!
Oct 01, 2008 | Hotpoint Ultima WD72 Front Load...
Zanussi zwf1631w jetwash front loading washing m/c
had to call an enginer out, the problem was down to a faulty motor rota, to identify if e30 is this fault, rotate the drum (so the motor rotates) and try to start the m/c. if it runs ok you know to change the rota. hope this may help someone
Sep 12, 2008 | Zanussi ZWF1440 Front Load Washer
Fault code e30 help
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Hotpoint ultima 1200 wm72
code e30 means motor fault. this can be just motor brushes, tacho fault or module fault. can't narrow it down more than this - you will have to dive in and check
Apr 05, 2007 | Hotpoint Ultima WD72 Front Load...
Dryers Logo
85 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
