Question about Sony Playstation 3 (PS3) Console
US playstation 3 loss of power
My playstation has lost its power supply ie:- no power lights
, the fuse in the mains adaptor has not blown and the power switch at the back is on.
    Problem Solver:
  • 19 Answers
Sounds like you got a system with a defective power supply you could either send it back and have them replace it or i think you can take game systems to geek squad now, that would save you the wait but you would probably have to pay a small fee
Posted on Jan 11, 2008
6ya staff
SOURCE:
Blown main fuse in the power supply
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 15, 2016 | Televison & Video
Samsung tv CS-29M16MG fuse always blown
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 12, 2014 | Televison & Video
Sharp 19" flat panel tv has no standby light and wont turn on cant find any blown fuses ?
Sep 10, 2014 | Sharp Televison & Video
No power. no lights. I have checked the power cord and its like there is no power
Firstly check that there is power to the Ac adaptor, this can be done by seeing if the green power indicator light is on on the adaptor body.
If not, then you have a defective plug, blown 3 amp fuse or the adaptor is fried (not uncommon)
If you have a multimeter, you can set it to 20 volts DC and with the adaptor pligged into the mains, test the DC JACK end! by putting the red probe to the inner part of the jack and the black to the outer part, if no reading, then assume the adaptor is dead.
Best way to check is by testing with an adaptor (universal charger type) to see if that works.
Assuming the adaptor is putting out power, check the output with a multimeter as above and see if the voltage is at the correct level (think its 19 volts on that model). If it is, then move on to the DC jack connection on the netbook
Watch the power indicator on the adaptor, if it is not steady green (ie flashes on and off), ther power is not making a circuit in the alptop and is being "spat back", this can be anything from a blown circuit board in the power circuit, to something as simple as a motherboard main fuse.
If there is a staedy green light but no power at the netbook and the jack connection at the netbook is firm and not sloppy or loose, then you will need to have the netbook dismantled and the fuse checked ( this will also need to happen if the jack connection is loose.
Sometimes, removing the battery, pressing the power button on (with the adapator unplugged) for 30 seconds and repowering with the ac adaptor can reboot the system, but I'd be inclined to suspect the adaptor first
Apr 22, 2011 | Acer Aspire One PC Notebook
I have the red power light, but when i turn it on, it completely shuts off, red light and all. Then i have to unplug it from the back to get the red light back
Either power supply problem or blown surface mount fuse on the main board. First check all SMD fuses on the main board, and the fuse on the power supply board. If the power supply board fuse has blown replace it and try again, if it blows again you need to replace the power supply. If the power supply seems OK check all SMD fuses on the main board. There are 7 on the V3 and about a dozen on the V4 / V5 / V6.
NOTE.... you have to open the console to do this ...
I hope this help in solving the problem.....
Nov 10, 2010 | Nintendo Wii Console
MY PS3 WONT TURN BACK ON
Good luck...
May 30, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 is completely dead no lights - could it be a new power cord is needed? steve peterson [email protected]
Try a different power cord first. If that doesn't work then your power supply has blown a fuse. Power supplies are version sensitive, so make sure you get the right one if you plan on fixing it yourself.
Jan 08, 2010 | Sony Playstation 3 (PS3) Console
Red light flashing, no picture/sound!!!!
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
FUSE CHECK LIST--
3A 12v- fuse----(242208600623)
SM 3A 125v-fuse----(242208600657)
500 MA-fuse-----(242208611092)
PART NUMBER FOR POWER SUPPLY BOARD
(996500036816)
Please rate and god bless:)
Apr 13, 2009 | Philips 42PF9631D 42 in. Plasma Television
PS2 In-car power supply for slimline model
.. i suggest u buy power inverter 100w this enough to power ur psp even ur laptops..
Feb 04, 2008 | Sony PlayStation 2 Slimline Console
JBL Creature 2 Blowing Fuse
There will be a short somewhere in the power supply. If you replace the fuse it will blow again. You COULD try a larger ampage fuse, but any electrician would not recommend this!
Oct 15, 2007 | JBL CREATURE II Computer Speakers
Sony Playstation 3 (PS3) Console Logo
208 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
