Question about Fuji FinePix E550 Digital Camera
No picture on lcd display only white light - Fuji FinePix E550 Digital Camera
    President:
  • 2,185 Answers
This might be caused by a common problem with digital cameras with CCD. You'll know if its a CCD problem if you are able to use the video recorder properly.
Since you did not mention the make and model of your camera, here is a list of cameras which were greatly affected by this problem so see if your camera is among them.
http://www.imaging-resource.com/badccds.html
Other manufacturers service these camera's for FREE regardless of warranty so I would suggest you take the camera to the nearest service center since this is something you cannot do it yourself.
If the camera is still under warranty, ask for a replacement.
Hope this helps.
Posted on Nov 18, 2009
When i turn my a630, the lcd only show white screen, but it still can take pictures normally. is something wrong with my a630 lcd?
The display being white can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the display is not seen, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the phone aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Aug 09, 2011 | Canon PowerShot A630 Digital Camera
Outdoor pictures give white display on screen
Go to the menus and reset to default or factory settings. Make sure that the white setting in the picture adjustments in the menus are set to zero or you may have to adjust + or - to get the normal effect again.
Test the camera by taking pictures and saving to a sd card. Then put the card in a card reader/writer which is connected to the computer. Copy the pictures or files to the computer and view them to see if they are in good shape or if there is some problem with exposure or the way it looks.
If the computer pictures show that they are good, and they are not showing good on the camera LCD, then the LCD has a problem, and is possibly either cracked or has some other display problem.
These LCD screens are not that hard to change if you are good at working with small items and screws. If you do this, make sure you have a way to remember where you got each screw, as they can vary in size and kind.
Apr 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
White display LCD TV
the connection of lcd panel is loose that is why display goes white,u hv to take it to the product care center
Mar 29, 2010 | Televison & Video
The screen glowinh white mean it is not getting voltage to the LCD controller, the ribbon cable may have come lose. You need to open it up and look inside.
See some pictures here: http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Picture display result
Which mode are you shooting in?
You may have adjusted the exposure compensation so everything is washed out.
Whatever the cause, your images are overexposed. Try shooting in auto and the camera should take over the settings, but if you are in other modes, check your shutter speed, aperture, & ISO also. These are all things that can cause too much light and wash the picture out/OVEREXPOSE.
If you have any other questions or can give me more details, just ask!
Hope this helps!
Jun 01, 2008 | Canon PowerShot A460 Digital Camera
PB6100:No picture display
The projector needs to be turned on first, then connect it to the laptop. If the picture still does not show at that point, press the FN and the LCD keys on your laptop at the same time. This should work.
Feb 10, 2008 | BenQ PB6100 Multimedia Projector
Sony Ericsson K750i White Display
try service mode to check it
>*<<*<* (<=left move on stick)
(>=right '' '' '' '''' )
Nov 18, 2007 | Sony Ericsson K750i Cellular Phone
LCD display is black
First fault may be in the back light panel which is behind the LCD display unit. If the felexible connector is proper,then there should be the white florescent light. If the light is OK,then look for a fault in LCD section. We can provide the service manuals and spares.
Sep 05, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
LCD screen is white SONY CYBERSHOT
Good Day, try taking pictures despite no display or LCD is white, connect to PC and observe, if the picture you took can be seen on PC, then your LCD display is defective, hope this will help, thanks
Aug 31, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
LCD screen is white
Fuji FinePix E550 Digital Camera Logo
47 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
