Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
All I can get on my tv is a blue screen - sometimes its says no video input but I've checked the cables and they are fine.
I can't get regular tv to work. I'm able to play dvd's but when I eject the dvd only the welcome screen shows.
Posted on Dec 01, 2009
2 Suggested Answers
  • 15 Answers
SOURCE: when using component cables(red, green, blue )
The series of the cable should go green red blue into the back. if you put the green in the red and the red into the green it give the TV a red base to go off of for the picture so everything is red. The reason the green cable won't is because it transmits a black and white picture which allows it a nice base to add the green and red to.
Posted on Feb 24, 2010
I am getting a blue screen whenever i turn on my ps3. Ive tried resetting the system several times and can not find the solution. Audio works just a blue screen on the t.v.
You said the sound works but you get a blue screen on the TV, check your TV if it is set properly.
Make sure the Input is correct on the TV to shoe the Video coming from the console and check if the cable connections are properly connected to the TV and the console video output and input.
Also try it on a different TV to see if the issues is with the TV or the Console itself if on a different TV and the issue is still the same the issue is the Video output from the console but to check further more try a different cable, borrow one or maybe buy a new one just to see and eliminate possible causes of the Blue screen issue.
I hope this helps.
Aug 01, 2011 | Sony Playstation 3 (PS3) Console
Unit displays intermittent blue screen. No break in sound as connected by Digi coax. Video via HDMI
hmm..sounds like an input issue..check all cables for breaks, bends, cracks, etc...blue screen is video equivalent of a bad ground, sometimes..
May 03, 2008 | Televison & Video
I have a apex 32-inch tv model (AT3208S), This tv was connect to a converter box, the other day electric power went out in our area for about 8 mins or less, once the power was back on the tv screen was...
OK, I have one of these TVs, and here's a thought: There's nothing wrong with the TV nor with the cable converter box. Please bear with me. Since I don't know how much you may know about TVs in general and this one in particular, I'm going to assume you know nothing and go from there.
This TV has several different "inputs", which are ways a signal can be transferred from its source to the TV, where it "outputs" the video image. I believe this particular TV has 5 different inputs: In descending order of the quality of the video signal, there're one S-video input (a 4-pin video connector plus red & white audio), three composite video inputs (3 connectors each: yellow video and red/white audio--audio connectors are the same for both s-video and composite), and one coax connector (a single large screw-on connector with a little wire sticking up through the center of it) for a total of five different inputs.
The problem with these Apex TVs is that they always default to the Antenna/coax input first when they are restarted. Most people use the TV to display an input signal (like the cable box or a DVD player) connected either to the S-video or to one of the 3 composite video inputs, not to the coax input, which just displays the channel numbers from 1-125 when it's set to do that (hit the "display" button on your remote to toggle showing the channel numbers for the coax input). If there's no signal coming into the coax input, the screen with appear blue. (If it's blue, it simply means it's not getting a signal via the input to which the TV is currently set. You can turn off the blue screen in the menu settings, but then you'll just get a blank screen. It's probably better just to leave the screen blue; at least you can tell the TV's actually trying to display something that way.)
You have to manually select the proper input by pressing the "video" button either on the remote (lower right corner) or the "video" button directly on the TV (hidden control panel under the middle of the margin around the bottom of the TV screen. You'll have to press on the door, and the whole control panel rolls open to reveal another set of composite inputs and some buttons. The video button is the one farthest to the left.)
Anyhow, by pressing the video buttons, you'll cycle through the various inputs. Assuming your cable converter box is functioning properly, powered on, receiving a signal from the cable company, and connected to the TV via a(n) appropriate wire(s) connected correctly, you should see the output from the cable box on the screen when you cycle through to display the proper video input.
Another possibility: the power outage fried the input to which your cable box was connected on the back of the TV. If that's the case, your cable box would probably also have sustained damage. You can check to see if the various video inputs on the TV are working by connecting different source inputs (like a BluRay/DVD/VCR player, video game console, video camera, etc.) to one of the other inputs and see if you get a picture when the TV is set to the appropriate inputs. (Remember, the "video" button is what selects/changes/cycles through the various video inputs.) One of the sets of inputs went bad on my TV. I just use the other ones.
May 18, 2011 | Televison & Video
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Hd tv
My HDMI has stopped working. I have had a technician from Dish network out to my house 3 times and they have replaced the receiver and the HDMI cable and were unable to get the set to work all I get is a blue screen and a message which reads no signal. I also cannot use mt set using 3 rca cables connected to the component input when set to 1080 I keep intermittenly get a black screen then a blue screeen and sometimes a no signal message. I have to watch the tv set to 720 on component 2 and it is the most stable in that setting. Please send help
Jul 06, 2008 | Protron PLTV-37 37 in. LCD Television
Blue screen on all channels RCA TruFlat
This is NOT the problem. video games, dvd player and cable connection are all all a blue screen with sound
May 14, 2008 | Televison & Video
Attention No Video Input
Check your input cabling and connectors and make sure you have a good input signal. Put another tv on this same input cable and see what happens. Keever
Dec 20, 2007 | Philips Magnavox 27MS343S 27" TV
Visual
First, have you doublechecked the video hookup? It sounds like you are using the video/audio inputs to the TV, so make sure you have VCR video out cabled to TV video input, and the TV source/input selection set to that input (video 1 etc.). If this checks out, check for a dirty video head on the VCR, though a dirty head usually results in a blank or blue video display (older VCRs, snow). You could do a process of elimination by hooking VCR to a different TV and see what is displayed then. Lastly, I assume you've tried multiple tapes, just in case a home recorded tape was incorrectly recorded?
Aug 24, 2007 | Panasonic PV-7450 VCR
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
210 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
