Apologies to Andy Hi Fi and tvtek who both answered this query yesterday, but I gave out the wrong model of tv. My set takes about 5 minutes to produce a picture, which is then as good as ever. Sound comes on instantly. I'm looking for advice as to whether or not I should replace set when picture eventually goes, as I assume it will, or should I put it in for repair and what will be approx. cost of this. I want to do my bit for the environment but I also fancy a flat screen tv. What would you do?
    Scholar:
  • 53 Answers
This fault sounds very much like the CRT (Cathode Ray Tube) is approaching the end of its life. If you can find a TV engineer in your area - preferably one from "the old school" - he may well have a "Tube booster". This sometimes works to "rejuvenate" old CRT's but can also unfortunately, bring an abrupt end to the tube, because it involves passing a higher than normal current through the tube heaters.
Environmentally, it all depends on the age of your current TV and the size of the screen. If it's a fairly large screen, (32") it will probably consume around 250 to 300 Watts of electricity. Modern LCD TV's are more efficient, however gas plasma TV's tend to use slightly more power than LCD models.
As you will know, TV's don't use that much power in comparison to say, a cooker, electric kettle, fan heater or washing machine heater so you can expect to use around 200Watts for your new TV if it has a 32" screen. Power consumption goes up of course, the larger the screen size you have, so if you bought a 40" or 50" screen you would not save anything in power compared with your old CRT type TV.
If your current TV has lasted for 20 years or more then you have done reasonably well. That's not to say that many TV's with conventional CRT's often last MUCH longer than this.
Tandberg CRT TV's have been known to still be working perfectly well after more than 30 years! Much the same with Panasonic.
Posted on Nov 18, 2009
Schematic diagram for Tevion CD5 8500 Hi-Fi
INCORRECT PRODUCT CATEGORY
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Aug 25, 2012 | Cars & Trucks
Are the starters on the 1994 golf 3 gti 3 and jetta 3 the same if the ungine types are all 2.0?
Why would you tell the entire world on the internet,
about getting the wrong starter?
You already know they gave you the wrong one
We can not take it back for you
Jun 05, 2012 | Cars & Trucks
I have a zenith z42pq20 about a year and 3 month yesterday a hear a thunder, my tv was on, there.s a power failure and then the standbay light turn red but the tv doesn't turn on. The light doesn't...
Sounds like you took a hit. Unplug your set for 30 minutes and plug it bcck in. It could have just locked up the micro. If this does not fix, unplug the set and take the back off. Plug the set back in and check the powersupply for your 5 volts dc. If it is there, replace your main pcb.
Jul 20, 2011 | Televison & Video
Need to know how to unlock my rankarenna tv model ba34combo tv
Hi brett
To answer your question;
Since the brand name"rankarenna" that you gave us seems to be completely unknown , i `can`t tell you where to look in your menu.
But i can tell you that the keylock is a feature used in different brands and i believe it was made so that little fingers could`nt play with the tv settings.
And the only way to remove it is with the remote and into the tv menu,
The lock function in the menu could be listed for example; under setup or feature or any other functions than audio/video.
Look carefully through your menu and it has to be there.
Hope this will help Good luck
Jan 04, 2010 | Televison & Video
My Sony WEGA TV is only 5 years old and will not turn on. It starts to and I hear sound but then it shuts off and the LED blinks 6 times. I was hoping there might be a ''oh that's an easy one'' kind of...
You probably have a bad lamp. Has the lamp been changed in the past few years? If not I highly suspect it to be the issue. Email me with the model number and I can get you the part number you will need. My email address is tvtek(at)msn.com
Nov 17, 2009 | Televison & Video
Codes and auto don't seem to work as per instructions on internet
Hi the answer is, find the original manual and then you realize that the codes you give for the sanyo are wrong, and the manual is right. 0035 & 0039
If I HAVE A SOLUTION i GIVE IT FOR FREE
regards Ronnie Fogarty
Nov 24, 2008 | Philips Magnavox Learning Universal Remote
Xbox360 picture too wide for TV
http://www.sonydigital-link.com/manuals/manuals.aspx?site=odw_en_GB
try here for the manual. Put in your model number and the size of your tv and you should be able to download the manual in pdf format. Hope this helps
Oct 25, 2008 | Televison & Video
Sony Plasma TV
I had this same exact issue yesterday. I own the same TV model and here is what SONY had me do to get the picture back. Ultimately the picture comes back, but it will be very dim and needs repair. Most likely a power supply issue. Try these steps:
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 12, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
2 year old Samsung 50" DLP
Sounds like a bad digital board to me. Not too hard to replace in those models but, you do have to write down a few settings before replacing it. These settings are available in the service menu. Any questions let me know tvtek@msn.com
Nov 30, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Fabric conditioner drawer does not empty on any of the washing programmes? Any odeas what could be wrong?
Zanussi ZWF1640 Front Load Washer
This video will show you how to keep your soap draw clear and how to service the parts.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Feb 20, 2007 | Zanussi ZWF1640 Front Load Washer
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
