Question about Sony PlayStation Portable (PSP) Console
Psp says ip address took too long to conect what is my psp ip address
  • 188 Answers
Yo... here's the information that you need:
http://www.boutell.com/newfaq/definitions/ip.html
Posted on Nov 18, 2009
How do I find or get my sony PSP SSID code. What is a MAC adress. Is it the same as a IP adres? Software version: 6.37 (latest update) Alias P271 MAC-adres : 00:22:69:82:FD:0D s/nr PSP :...
the SSID is for YOUR wireless network not your sons PSP , A MAC address is a unique identifier for your PSP and no it is not the same as a IP address
Apr 10, 2011 | Sony PlayStation Portable (PSP) Console
It wont go on to the internet because there is a error and the code is 80410410
This might not work because i don't know what your exact setup and situation is. but i would get on your pc, make sure its connected to your home network, and open the command prompt. Type "ipconfig" and hit enter. now, turn on your psp, go to your network settings, and copy the data you see there into the appropriate areas on your psp. just don't copy the ip address, because that address is specifically assigned to your computer. lets say my network ip address 192.168.1.1, and my computer has an ip address of 192.168.1.2. If i want to manually assign an address to my psp, i would chooes something like 192.168.1.55, because that address isn't being used.
Feb 24, 2011 | Sony PlayStation Portable (PSP) Console
How 2 conect 2 internet via wifi
When the psp is on flip the WLAN switch to the on position (This is found on the bottom left corner of the psp) then select network setup from the main menu, select network settings (press X) After that select infastructure mode and click on Create a new connection. Select scan to look for your Wifi network (Otherwise if you know all the settings you can enter them manually) When it appears select your networks name and enter your security information (If applicable) Select easy in configure network settings to get your ip address.Confirm the settings and test your connection. Go back to the main menu, select the browser and enter a web address. Keep in mind that the psp will not connect to certain websites such as youtube because it requires flash,java and enhanced memory (this is not a memory stick) Although it can use cell phone websites.
Hope this helps
Jan 09, 2011 | Sony PlayStation Portable (PSP) Console
Wifi signal canot conect because of DNS problem
see pal.for this you do require ip address settings by that i mean ip address,subnet mask and default gateway.if you do have these settings then the dns address can be used for static ip address primary = 4.2.2.2 & secondary = 4.2.2.3
take care
Jul 10, 2009 | Computers & Internet
Ip adress keeps timing out
bro you will need to change your wep code even if you know the correct one i think it is becuse it allows other devices or somthing to conecte through to change your wep code do the following
1 open internet broser
2 type in the bar (http://192.168.0.1) tuyp tthis in for D-link routers. for Netgear routers type(http://192.168.1.1) as for Belkin routers type (http://192.168.2.1) if you have a diffrent router you are going to have to shearch it on google.
3 ok now when you put in the routers address in the address bar and press enter this parssword/user name thing will pop up you will net to enter (admin) this is the defalt for most routers if you have a difrent router look in the instruction manal or somthing. if you have changed it and you can nto remeber it ring your brodband support.
4 ok now your in your routers seetings change your wep code then reenter the same thing on your psp.
ok some times this will not work and the (ip address thing has timed out) thing will be starting to really **** you off ok this is what you do.
5 go to the start botton in the bottem right coner and click on this then you will need to click on run let it pop up and in the bar type (cmd) this will bring the comarnd promt up if you have vista just go all programs then to asseories then the comarnd promt.
6 once you have ented in (cmd) click on enter and the command promt will pop up in there just type (ipconfig/all) then it will come up with a bunch of informatin on your router.
7 go on your psp and go to ip settings click on manal and enter in the settings that the command promt are telling you.
note: make sure you dont use yuor proxy setings this secrew up thes all way of doing it.
then you are all done and this should work!!!!!!!
Jul 02, 2009 | Sony PlayStation Portable (PSP) Console
What is ip address
to fix go on ip chiken.com it will give you your ip
Jan 10, 2009 | Sony PlayStation Portable (PSP) Console
Cannot Use Wireless LAN
the problem is common, you need to set up the psp manually and not let it obtain an ip address automatically. the easiest way is to find either your router ip address or your pc's ip address e.g if your routers ip address is 192.168.2.1, then your pc's allocated address will be 192.168.2.2, so set your psp address to 192.168.2.3. you will also need to set the gateway address, this is your routers ip address(the one you type in your browser to get into the routers settings).e.g 192.168.2.1. the DNS setting will be 255.255.255.0, all other address settings required will be the routers ip address eg 192.168.2.1.
Aug 02, 2007 | Sony PlayStation Portable (PSP) Console
I need your help with connecting my psp online
You will first need to find the DNS setting which is probably 255.255.255.0 and IP address of your router, which is probably 192.168.2.1. Check your computers ip addresses which will be the next number up eg 192.168.2.2. You then need to go into the psp manual connection set up and use 192.168.2.5 as the psp ip address to be on the safe side and not duplicate an address. Set the dns primary and secondary server addresses as 255.255.255.0 and set the gateway address as 192.168.2.1( if that is your routers address, as the gateway is your router)
Mar 06, 2007 | Belkin (F5D72304F5D7000) Router
Sony PlayStation Portable (PSP) Console Logo
59 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
