Question about HP Office Equipment & Supplies
My printer is not printing yet i have installed it with its appropriate drivers and seen that its fully installed what might be the problem?
  • 630 Answers
You don't say which printer or how you've connected it. If it's USB disconnect the cable and replug it in and check whether windows sees it.
Posted on Nov 18, 2009
Bought a DTC520 and replaced Printer ribbon and now message reads " No Printer Ribbon Installed" Used Part # 86031 DTC500-YMCKO I powered down machine and started again, still NO Ribbon...
You have to check which ribbons are loaded.
Depending on that you have to select the appropriate mode in the driver else it'll keep giving this message.
Y = yellow
M = magenta
C = cyan
K = black
O = overlay
May be you don't have overlay loaded
Aug 15, 2011 | Fargo DTC515 Thermal Printer
I am using DP-301U print server and wanting to attach with hp 1020 plus. However the printer in not printing. what is the root cause and give the solution please...
Hello and welcome to fixya.
First off, I would like to provide you a link with the print server's manual to download it directly and have it as spare.
The printer you are trying to install is a laser printer (black/white only) and probably a bit old model.
Therefore, if you are trying to print from your computer over ethernet, and you have windows vista or 7 (64 or 32bit accordingly) you might have the inappropriate drivers for either the print server or the printer. You can find all of the HP printer's drivers HERE. Select carefully based on your OS.
As a SIDENOTE: If you just need the drivers installed and there are only larger setup execut. files available, you can use 7zip or winace to open up the *.exe file and navigate to the appropriate folder and extract only that one to your computer and install the driver(s) from there.
The D-Link DP-301U print server drivers are available HERE. Default username and password for the management console of the print server can be found at pdf manual page 25. The url to access the administration console is dlink-******,where the asterisks stand for the last 6 digits of the print server MAC address.
Overall, not to make things over-complicated (150+ PDF user manual pages) you need to do the following:
1. Install the appropriate drivers of your hp printer on the computer that will have also print serv. softare installed.
2. Install the appropriate software/drivers of the dlink print server on the same computer.
3. Plugin the usb cable of your printer to the print server's USB port.
4. Plugin the ethernet cable of your print server port to the ethernet port of your home router/switch.
5. Setup Fixed IP settings for your print server configuration (page 20 on the manual).
Let me know how that went. I believe you will manage to do it that way quite easily.
**Don't Forget to vote how helpful this was.**
Thanks.
Regards from FixYa.com
Apr 22, 2011 | D-Link DP 301U (DP-301U) Print Server
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Epson printer not working with Core 2 Duo
printing with the processor type and speed has nothing to do with printing capabilities, you need a driver that rightly correspond to your Operating system, say Vista, Windows XP, or Win 7
kindly check this area, and install the appropriate driver.
hope this helps
Jan 08, 2010 | Epson FX 1170 Matrix Printer
Hi, I can print with it but it would not
uninstall the device drivers, leave the media device connected, reboot the computer. when the computer finds the device, follow instructions, always indicating where appropriate that you will install your own drivers. when asked for driver location, point to the location of the cdrom that came with the device, or the location where you have downloaded the appropriate drivers for this device. it will then automatically complete it's installation. good luck
Nov 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
Wont print from computer will print from labtop
Make sure you have the appropriate drivers installed. Visit the manufacturer's website, find the model of your printer, and download and install the drivers. They may also be on the disk that came with your printer.
Dec 21, 2008 | HP Computers & Internet
No printer will work with my computer
I would uninstall all printer drivers, reboot and then try one at a time.
Install the driver first, then connect the printer.
Dec 11, 2008 | Lexmark P3150 All-In-One InkJet Printer
MY ZEBRA TLP2844 print a symbol...
de-install then re-install the printer driver.
also if it has multiple interfaces (such as serial and parallel) be sure to load the appropriate driver.
Nov 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Problems installing a printer
You can follow the steps below to install a resident printer driver which is part of your operating system.
NOTE: Windows should detect and automatically install devices attached via the Parallel or USB ports on the computer. You should be able to attach the printer, and the "Plug and Play" feature will install the appropriate driver.
If the driver does not automatically install, please contact your Computer vendor. The "Plug and Play" feature may be disabled within your computer.
The resident driver installation should only be used if the printer is not detected and installed.
1. Start by opening the "Printers and Faxes" window. Click on "Add Printer" on the left hand side of the screen.
2. The "Add Printer Wizard" screen will come up. Click on "Next".
3. At the "Local or Network Printer" screen, select "Local Printer" and place a check on "Automatically Detect and Install my Plug and Play Printer". Click on "Next".
4. Windows should report it will check for Plug and Play hardware. It should also detect and install the appropriate resident printer driver.
5. A window will appear and tell you when the process is completed.
*NOTE: If Windows does not detect your printer automatically, you can manually install the printer. Simply select EPSON under manufacturer and select your appropriate model under PRINTERS.
6. When the printer is installed, it will ask you if you would like to print a test page. Check "Yes", then click on "Next".
7. The next screen will display the settings for the printer. Click on "Finish" to complete the installation and print the test page.
May 27, 2006 | Epson LX-300 Matrix Printer
13 people viewed this question
Seeker5211
Seeker5211
