Question about Konica Minolta bizhub 350 All-In-One Laser Printer
I have a malfunction code on C350 which reads C-0400
  • Konica Minolta Expert
  • 158 Answers
This error code means the exposure lamp has failed and will have to be replaced. you can try to reset the error code but if it comes back the lamp will have to be replaced.
to reset the error:
1.open the front door with the machine left on
2. locate a small square hole inside the front door towards the bottom right.
3.insert a small object such as a small ball point pen to actuate a error reset switch the screen will indicate the front door is open when the switch is actuated.
Posted on Nov 19, 2009
Testimonial: "Thanks, I have reset it by opening the front door and pressing the reset button. I think there must have been condensation on the lamp."
Also it shows code Po400.Do I put in a new MAF Sensor.
code p 0400 refers to exhaust gas recirculation (EGR) system---flow malfunction===causes hose leak/blockage ---basic setting not carried out--wiring---EGR valve EGR solenoid--ECM
the code has nothing to do with a MAF sensor
Jan 12, 2017 | Cars & Trucks
P0400 opel zafira 1999 chek engine
code p 0400 refers to exhaust gas re-circulation (EGR ) system--flow malfunction===causes --hose leak/blockage--basic setting not carried out (if applicable)---wiring---EGR valve --EGR solenoid---ECM
Nov 14, 2015 | Opel Cars & Trucks
Vauxhall fault codes 1405 and 0400 and 0500 and 0105 what does it mean
0105 - MAP/BP Circuit Malfunction
0400 - EGR Flow Malfunction
0500 - Vehicle Speed Sensor Malfunction
1405 - DPFE Sensor Upstream Hose Off Or Plugged
Sep 18, 2013 | Cars & Trucks
C-13c8 malfunction code
The transfer belt does not have a new cleaning unit attached to it. That would be the end with out the handles, get a new transfer belt that is completely new
Apr 10, 2012 | Minolta C350 Color Printer/Scanner/Copier
Konica minolta Bizhub C350. Following message appeared on my printer: Malfunction detected. Please call your Technical Representative and provide code: C-0F36 What does this code mean?
Hi katienash,
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.
Good luck
Regards
m-press.biz
Jan 25, 2011 | Konica Minolta Minolta Printer stand...
C-2152 Malfunction
Yes there is a C2152 code for an error with the transfer belt separation. But this code does not appear in the C350 manual. It DOES however appear in the C250/C252 manual. There is a service bulletin from Konica/Minolta about this code that covers models C203/C253/C353. Since it is not covered in the C350 manual I can only assume that if you have a C350 and have this code then it must be a problem with the Transfer Belt Unit or the Sensor Plate. Here is a link to a forum which has the detail on both the bulletins and solutions for this error code. Keep in mind tho that this is not for your exact model. My experience tho (27 years on Minolta's) is that the code for series of machines don't change much. Have you tried resetting the code with the trouble reset procedure?
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error code on Konica Minolta C350
There is not a C0876 listed in the service manual. Perhaps it's a C0B76 - Finishing option Punch Unit Board Malfunction.
CAUSE: The shaft on which the gear rides is deformed. The punch unit cannot be driven from front to rear.
SOLUTION: Reform the shaft toward the punch unit rail. This will allow the drive gears to mesh properly so the punch unit can be mechanically driven from front to rear.
Aug 28, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Feb 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
Dec 06, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
387 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
