Question about Maytag Neptune MDG5500AW Gas Dryer
No heat on Gas Dryer
So i just installed a new motherboard! and now the dryer wont create heat! do i need to reset the new motherboard? when i plug it in, it will flash a code "P7" for about 5 minutes. what does this mean? i check all the manuals but nothing shows this code.
  • xexar Jan 13, 2008
    i replaced the board because it was displaying"8.8" i opened it up and found that it was no good, so i replaced it! the dryer was working great prior to this problem.
    President:
  • 1,314 Answers
P7 maybe the software version of the motherboard why did you replace the mother board
Posted on Jan 11, 2008
Electrolux dryer won't heat
a gas dryer has a ignighter that may have burned out. a $40 part
May 12, 2014 | Electrolux Dryers
Tip
How to Fix a Gas Dryer That Does Not Heat .
<span>Instructions</span> <ol> <li>Check if the power cord is plugged into the wall. It may have come loose while moving the dryer.<br /> </li> <li> Inspect the fuses and circuit breakers for any that may have burned out or tripped. Most gas dryers require power from two fuses or circuit breakers. Often, your dryer will still tumble but not create heat if a fuse or a circuit breaker is not working. Replace any burned out fuses and reset any tripped circuit breakers.<br /> </li> <li> Determine if the heating element in your gas dryer is burned out by using an ohm meter to check for continuity. If the test reveals there is no continuity, then you will need to fix the heating problem by having an authorized repairman replace the heating element.<br /> </li> <li> Inspect the thermal fuse to see if it's burned out. You will find the fuse attached to the exhaust duct on the back panel of the gas dryer. It's usually surrounded by a black resin material situated in a housing made of white plastic. If the fuse looks like it's blown, then it needs to be replaced.<br /> </li> <li> Ascertain if the main wiring connection from the house to the dryer is broken. A gas dryer can still tumble with partial power, but an inadequate connection with the main power supply to the house may be causing your gas dryer to remain cold. If this is the problem, you may need to replace the power cord that goes to the dryer as well as the terminal block that is attached to the wire itself.<br /> </li> <li> Look at the gas valve coils to determine if they are faulty. If the igniter radiates but then shuts off before it ignites the gas, then the coils are probably bad. Replace the coils and your problem should be solved. Also, if you find the igniter working properly then the problem may be with the radiant heat sensor. The sensors are usually located close by the igniter so are easily visible. Hire a repairman to replace these faulty parts.<br /></li></ol>
on Dec 29, 2010 | Dryers
I have a white knite tumble dryer and the reset button wont push all is workin besides the heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 12, 2011 | Dryers
The flame from my gas/fire that heats the dryer is shooting up too high and hitting the sensor, and then the sensor registers that it's too hot and shuts the heat off completely, therefore my clothes are...
it probably has ruined the sensor eye or dirtied it so it cannot let the gas valve open,by chance,has or was this unit on L.P. gas or Natural gas at one time and has been changed over to the other gas,as this will,due to the wrong orfice in the gas flow create an over size flame
Jan 26, 2011 | GE Profile Harmony DPGT750EC Electric...
I have a gas dryer. the glow plug works but wont stay on
You are likely in need of new coils to make your dryer heat again. If the ignitor glows, the thermal fuses and thermostats are good. The coils sit directly on top of the gas valve, are easily replaced and inexpensive. CLICK HERE for the coil kit to get your dryer heating again. Using coupon code 1050 will save you some money!
Jan 12, 2011 | Whirlpool LGB6300 Gas Dryer
Dryer wont dry, blows cold air
Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty. I hope this helps. If it does, please let Fixya know by rating my solution. Good luck!
Nov 28, 2010 | Whirlpool LGR5636L Gas Dryer
Lg dryer wont heat up DLEX7177RM how do I reset the thermostat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 30, 2010 | LG DLG3788W Gas Dryer
Kennmore dryer wont heat
Your problem could be one of the following:
* thermostat
* gas coils
* radiant sensor
* gas igniter
* timer
Contact an appliance service company.
Feb 20, 2010 | Kenmore 93142 Gas Dryer
Dryer won't heat.
Check the glow ignitor and make sure it is glowing, if it is not glowing then replace it, if it is glowing then check the gas valve.. But sounds like the glow ignitor is bad and needs replaced, if it is cracked it wont work either so look really carefully, maye even pull it out.
Feb 09, 2009 | Kenmore 63942 Dryer
It runs but timer wont advance dryer wont heat.
did you change out the limit switches? they control the heat to the element... and it sounds like you need a new timer
Jan 22, 2009 | Whirlpool GGQ8831L Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
69 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
