Question about Brother MFC 240C All-In-One InkJet Printer
UNABLE TO SEND OR RECEIVE FAXES WHEN DIALLING OUT ALWAYS GET ENGAGED TONE
  • 630 Answers
Check whether it is dialling 9 first (or whether it needs to dial 9 first)
Posted on Nov 18, 2009
I can't send or receive faxes.
You have connected the phone line, right? Checked the phone line with a phone and you get a dial tone?
Aug 31, 2016 | Canon Pixma MX410 All-In-One Printer
MMY fax machine can receive faxes but i cant send any fax ?
If you machine has a telphone handset attached, see if you can make an outgoing telephone call. if it can then your machine has a dialling problem. Check to see if your dialling method is set to tone/DTMF. It may be on pulse and if in the uk it may cause the problem. If it is on tone/DTMF then it may not be sending any tones. These are usually generated on the modem chip. If this is the case then a new control board will be required. Before buying a new one it may be prudent to RAM CLEAR the board (a full reset). It you want to do that then repost telling us what make and model you have. Good luck
May 09, 2011 | HP Office Equipment & Supplies
Unable to receive faxes. Able to send and cartridge printing OK
There can be a few things wrong lets take it step by step
1)Receive mode,your receive mode must be set correctly.If you don't have a tel connected to it, you cant use it as a Manual receive mode,it must be set on Fax only.If there is a telephone connected to it and it is set on manual mode make sure your Incomming ring is set to ON,you will find it under additional functions,RX settings,Incomming ring.
2)Make sure you have enough memory to receive a Fax.Go additional function,dataregistration,TX settings,Erase failed TX,set it to on.
3)Make sure there is enough toner and paper for the machine.
4)Tone or Pulse Dialing,depents in witch country you are make sure it is set correctly Tone or Pulse.You will find it under user settings.
5)There can be a problem at the you local exchange,you can send faxes but the exchange can be faulty and you would be able to receive faxes.
6)And then there can be a problem with you fax machine' NCU PCB board,there is to gas arresters one for send and the other for receive.If one of them are faulty you will have to replace the NCU.The gas arresters is not available as a part.
Dec 09, 2009 | Canon FAX-L360 Plain Paper Laser
I have a Canon MX850. I have tested the line to have dial tone and followed the instructions to setup the unit but cant send faxes. I dont know if i can receive but when sending it keeps keeping like the...
The fax will only work on an analog phone line, most offices these days especially if you have multiple lines, are digital. You may need the phone company to install a modem compatible phone line.
Nov 05, 2009 | Office Equipment & Supplies
I'm unable to receive or send faxes
Are you sure the line is good? You can try a plugging a telephone into the line to check it.
If you press the "hook button" (or whatever it is called on that machine) do you hear a dial tone?
is the phone cord plugged in snugly and in the proper jack on the machine? Is the cord good?
These are a few things to try.
If all of that checks out, then the phone board on the machine is shot.
May 26, 2009 | Panasonic PANAFAX UF-6000 Fax
Cannot send or receive faxes
Try to call from your fax if u make calls then the line is ok,if not check the line.check the cable have 4 pin ,Take the user settings in the reports menu,check and confirm the mode is "tone" if its "pulse" change it as Tone.
May 05, 2009 | Brother MFC-7820N All-In-One Laser Printer
Problem receiving faxes
your fax is in tad mode (telephone answering device) press the receive button (next to the start button) until you see fax only on the display this will correct the problem.if you have faxes in memory press the report key for reports, then opt.1 for help list
look for print fax
Jul 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C All-In-One InkJet Printer Logo
55 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
