Question about Samsung SMH7174BC Microwave Oven
Grill, working, lights all working, but some reason stoped heating up food
    Problem Solver:
Va dorma
Posted on Nov 18, 2009
Microwave doesnt heat food up?
Yes
You did probably has a bad magnetron.
Cost to fix it too high, get a new microwave
Feb 22, 2015 | Kenwood MW598 Microwave Silver Color with...
Microwave not heating up
If the microwave is not heating check magnetron connections, probably you will need to replace the magnetron.
Sep 06, 2008 | Microwave Ovens
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Sanyo microwave with grill.Will not heat food.grill works.Can it be repaired.out of warranty.
hi..the reason to this problem is probably due to the
bad ignitor.
check this out..
thank you..
kindly rate my response..
Jul 20, 2009 | Frigidaire PLMB209DC Microwave Oven
MICROWAVE OVEN NOT HEATING UP FOOD
Will need to pull apart to check....common failure with magnatron fuse....but could be magnatron, capaciter, diode. sugg to have a tech look at....if your not able to check, also call manufacturer, sometimes will cover.
Jun 10, 2009 | Microwave Ovens
Microwave oven does not warm food up
I have not solved my problem,I have decided to buy a new microwave rather than pay for this amount of money on a telephone advice when you have said on your site that it is free.I will also spend further amount of money, to call an electrician after your advice,so I will be better of buying a new one.
PanasonicNN-K627M micro & browner
it is obvious that nthe microwave side of the unit is not working.
microwaaves have a terrible habit of blowing fuses for the most stupid reasons. No not the fuse in the plug but the ones the manufacturer hides inside the case, you will have to look hard. if one is blown replace it with a direct replacement. and do not test the machine with the cover removed
Feb 19, 2009 | Panasonic NN-S753 Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Microwave not heating food
check magnetron and related circuit, and control unit and highvoltage section..
Nov 19, 2007 | Microwave Ovens
Microwave Ovens Logo
120 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
