Question about Canon PIXMA MP780 All-In-One InkJet Printer
I want to know how to empty the waste ink - Canon PIXMA MP780 All-In-One InkJet Printer
    President:
  • 787 Answers
The waste ink tank is on the bottom of the printer.To find and replace or clean it you need to disassembly the hole printer.Also need to reset the waste ink counter.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Nov 18, 2009
I need to know how to empty the ink waste tank so that I can clean up the ink blobs and leakage.
You should be able to go into maintenance in your printer software & it will tell you how to empty the tank.
murf427
Aug 01, 2012 | HP Photosmart C6180 All-In-One InkJet...
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Aug 04, 2011 | Xerox Phaser 8860MFP Printer
I have emptied the waste toner and the machine says replace waste toner cartridge. I know I have done this before and after I have emptied the waste, it worked. Is there a reset??? Thank you ! Larry...
Once you have replaced the waste ink tanks, you must rest the waste ink counter, by downloading the software. The companies discourage their users by not making this software available to the average Joe. So you will have to take it in to be serviced, explain specifically that the waste ink counter needs to be reset. This is going to cost $ how much I don't know, contact a dealer or printer technician.
damnor01
Dec 01, 2010 | Lanier UNKNOWN
Waste ink error message, now the printer won't print until the waste ink tank is emptied or replaced.
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 11, 2010 | Canon PIXMA iP90 Mobile Printer
Empty the waste ink
Take the printer to a qualified technician.
He/she can "empty" or "replace" the waste ink collector
*AND* "reset" the printer's internal software, to say that it has been serviced.
Nov 27, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Waste Ink Full....how do I empty it myself?
http://www.druckerchannel.de/device_info.php?modell_ID=874&t=canon_pixma_ip3000
Jul 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Indicates waste ink absorber is almost full on cannon i9900 print
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
The waste ink absorption pads cannot be emptied, only replaced.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 16, 2009 | Canon i9900 InkJet Photo Printer
Ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Apr 08, 2009 | Canon PIXMA iP1600 Printer
The printer is indicating "waste ink near full"
Hey,
The waste ink pads should generally be around the cartridge carrier, or below, possibly at the bottom of the printer.
have a look at this page for instructions on how to reset the counter after the waste ink pads have been cleaned or replaced.
http://www.allthefaqs.net/forum/viewtopic.php?t=3770
Let me know if you need anything else.
Thanks,
Ekse
Mar 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
59 people viewed this question
old marine
old marine
