Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
000014-000 this the error code. When I turn the copier on ... it tries to start ... then this code come on and it says call a tech.
  • 1,219 Answers
E014
000 After the fixing motor drive signal is generated, the clock signal does not
arrive within 3.0 sec.
Main cause The fixing motor (M19) is faulty. The DC controller PCB is faulty.
Action
1. Connector
Is the connector of the fixing motor connected?
NO: Connect the connector.
2. Main power supply PCB
Is the drive voltage (24 V) of the fixing motor supplied by the main power
supply PCB?
Main power supply PCB: between J202-3 (24VU1-S) and J202-4 (OVU1)
NO: Replace the main power supply PCB.
3. Fixing motor (M19), DC controller PCB
Press the Start key. Is the lock signal of the fixing motor present at the connector
(J312) on the DC controller PCB?
Lock signal: J312-B4 (FSRM_LOCK*)
the DC controller PCB change from 0 to about 5 V?
YES: Replace the fixing motor.
NO: Replace the DC controller PCB.
BUT FIRST: did you removed fixing assy from any reason? If you did try to repositioned it. Check for any foreighn matters inside or around the fixing assy. Try to reconect the fixing assy connectors. Check gears of fixing assy and drive assy.
Posted on May 04, 2010
Canon code E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Oct 21, 2015 | Canon Office Equipment & Supplies
Model 233. What does error code C440 indicate?
C440 error indicates a fuser temp too high or too low. SOMETIMES it's random and can be reset by 1. hold down the 0 and 8 keys while turning on power. 2. Enter 400 press Start. 3. Enter 0 press Set or enter. Copier will begin warm up mode. If the code recurs, you will need the fuser unit rebuilt or replaced.
Oct 04, 2015 | Toshiba Office Equipment & Supplies
Ir5070 error code E000025-002
The error code you have is a toner hopper error code.... Try to take the toner bottle out and close the toner door and turn the Main power switch OFF. Turn the copier back ON and let the copier come back to Ready and install the toner bottle back in and see what happens.... There maybe a problem with the toner hopper and you may need to call a service tech in.... Good Luck
Feb 27, 2013 | Office Equipment & Supplies
Canon ir3300 is giving me error code E6002-0003, h...
Turn off the copier using the power switch on the right. Turn it on again holding 1 and 9. You should see rectangles on the screen. Once this is finished the copier should be in download mode (If this process hangs or doesn't get started the disk will need to be replaced by a tech). Once you reach download mode you'll need a tech to flash the hard disk to get the copier going again. If this doesn't work, the hard disk will need to be replaced. In any case your hard disk is dying and will need to be replaced soon.
May 21, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Error code Ox88108508. Printer starts to print then stops. Error code pops up even when computer is turned off
hhhmmm try to download a resstter for your printer model, cause that error code cud mean that some part of your printer has reach its limits, printers nowadays have a counter in it. if you cant find any resetter software for your printer you shoukd call the HP tech. support cause they are the only who knows the right key combination on your printer panel that allows the parts to be reset.
for more help visit Cbr tech solutions
Dec 07, 2009 | HP PSC 2355 All-In-One InkJet Printer
Error code H4-00
Hi:
That error is referring to the fuser unit not reaching it's correct temp. within a specified period of time. You can try clearing this error with the procedure I will give you, but if it comes back then a service tech should look at it.
With the machine on and the error displayed press these keys in this order quickly. # * Clr * This will put you in a service mode. At this point key is 14 and press Start. Shut off the copier and try turning it back on and check to see if the error has gone away.
Andrew
Aug 06, 2009 | Toshiba e-Studio162 Copier
Error code P27
P27 is a TDS sensor error. You need to check the connectors on you developer unit. Open front cover, push down on copier then lift green handle. remove screw just above toner suppy unit and remove your drum assembly. Next remove your developer unit(two latches hold it in place). your TDS connector is located under your dv unit(you will have to remove the black cover). When finished reinstall drum assembly then turn on copier. If problems persist turn copier on while holding down 47 then press 40 then start.you should hear a motor running (let it run for 1 min.) If you don't try P40 or 01. Turn copier on then back on. If the problems persist I recommend a service tech. your DV or TDS sensor needs to be replaced.
May 28, 2009 | Konica Minolta Office Equipment & Supplies
Toshiba 1370 Wrench and C7 error but, 0 & 8 and 89 did not help
Press 0 and 8 down before you turn on the machine, holding these down turn on copier, the display should say "ad" press 89 then start ( display will say 3 ) press 0 then start display goes back to "ad" turn off and on copier if wrench comes back take off red cover over hot section and in the middle there is a thermostat (1 screw) and toner build up under it needs to be removed.
Mar 03, 2009 | Toshiba 1370 Black and White Copier
How to remove h5-01 error code on a sharp arm550n copier
This is either:
10 continuous POD1, POD2 or PPD2 JAM
OR
Other models this indicates too many fuser jams. The fuser error reset code will reset the machine so it will run after the problem is fixed.First remove any jam in the fuser then enter tech mode;
press program, * ,clear, * enter 1 4 press start then turn machine off and then back on.
Jan 20, 2009 | Office Equipment & Supplies
5020i error code E000001-0000
turn on the copier and quickly press * (with the little head around it) then 2 and 8 at the same time, then the * again... this should put you in service mode. now press copier >funtcion>clear>err>ok. now turn the copier off and back on, If the code comes back call your service local service tech.
Jan 08, 2008 | Canon imageRUNNER 5020 Copier
Computers & Internet Logo
233 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
