Question about Refrigerators
Hi, I have an old Crosley Compact refridgerator which is no longer staying cool. I have just replaced the thermostat in an attempt to correct this to no avail. The door seals are fine, the motor sounds as though it is running, however there is no cooling. I have a bad feeling this means that I need to have the fridge re-gassed, but is there anything else that could be wrong?
    Scholar:
  • 195 Answers
You need to get it re-gassed, sorry.
Regards
Alan Hood
ami-man
UK
Posted on Nov 18, 2009
Refridgerator problem wont; stay cold freezer is cooling down
Bad condenser. Leak in the line, low coolant. Bad compressor. Or the cheapest fix the thermostat.
Aug 06, 2014 | Kenmore Refrigerators
Refridgerator side-by side dripping water drips to floor and freezing on bottom of freezer compartment
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 06, 2011 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
I have a Crosley refrigerator that is about a year old. We decided to replace it because it wasn't big enough. We moved it to our garage and since we've moved it, it doesn't seem to be chilling the...
If the garage is unheated and the garage temperature is below 50 deg F this is the reason that the freezer is not able to freeze. A refrigerator is designed to work in a heated space. The thermostat is in the refrigerator compartment while the cold evap coils are in the freezer compartment. The fridge thermostat is typically set to around 40 deg F. When the fridge is in a colder environment, the compressor does not need to work that hard to get the refrigerator to temperature. But the freezer on the other hand, will be above freezing.
To fix this, there are garage refrigerator heater kits available, for just this situation. They are placed in the refridgerator compartment to heat the thermostat. This causes the compressor to run longer, and thus maintain the freezer temperature better. You could get one of these heaters or you could put an light bulb in the refrigerator to do the same thing as the heater. Remember to use a regular light bulb, and not a cfl or led light bulb, they won't generate enough heat. Also remove the light bulb or heater in the warm months unless you want a higher energy bill. Hope this helps you.
Dec 09, 2010 | Crosley CFFH10W Top Freezer Refrigerator
Hi, My refrigerator isn't getting cold. The freezer is working ok but the bottom refrigerator is set to 7 (coldest) and is barely getting cold. What could this be? Is it expensive to repair?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 03, 2010 | Crosley WCK05W Compact Refrigerator
Habco EMS-28 Thermostat not finctioning correctly
i have HABCO ESM28......Where I can find the thermostat controller.....
Apr 25, 2009 | Danby DKC645BLS Compact Beverage Cooler
Maytag refridgerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
GE GMR04HASCS Problem staying cool
Your off/on thermostat control is sticking. Next time do not turn it off then on.
Take your hand a bump the control a couple times.
If it comes on, replace the thermostat.
Mar 11, 2009 | GE GMR04HASCS Compact Top Freezer...
CLICKING SOUND-Crosley 19 cu ft Refrigerator
Your start system need to be replaced on the compresser go toy the parts house and ask them for a Supco RCO410 or a Supco PRO41 they come with instructions this is a common problem and will get you back in order faster than orering the factory oringinal
Feb 18, 2008 | Crosley CRS40 Manual Defrost Compact...
Crosley Dryer Heats then stops
If im thinking right, this dryer has the element in the top left corner.  This unit has two thermostats, one mounted right above the element, and the other in the lower left front mounted on the fan housing.  The one in the front is called the high limit thermostat, which means when it gets to a preset high temp, it cuts off the system until cooling occurs.  The top thermostat, mounted above the element is the operating thermostat.  It probably is one of the two thermostats.  Its a very good idea to replace not only both of the thermostats, but the fuse as well.  The fuse kit (Maytag Part# LA-1053) comes with a thermostat and 2 fuses, be sure to follow he instructions on how to determine the fuse for electric and gas.  The high limit thermostat (Maytag Part# 53-0771) is an easy replacement.  Something is causing the unit to short cycle.  Sometimes you can hot-wire the operating thermostat (use caution, severe caution if doing this, not recommended if you arent sure whats going on).  By doing this (removing the two wires from the thermostat, taping them together), you can watch and see if the element stays on longer, at least until the high limit switch comes on.  This is really not recommended, if the high limit is out, it will not be good.  Just easier to replace them both.
Oct 24, 2007 | Crosley CDE6000 Electric Dryer
Need replacement freezer door for model Crosley WCK05W
are u sure thats the right model # ..can't bring nothing up on that model # Did u get it off a tag that said model#?
Sep 27, 2007 | Crosley WCK05W Compact Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
