Question about Kenmore Elite 45986 Front Load Washer
Replace Door Pull
The door pull has broken and I cannot figure out what to remove to get to the fasteners for the door pull to replace it.
i couldn't find the fasteners either on the drier. that was about 2 years ago, just after we got the machine and i couldn't be bothered waiting most of a day for a repairman.
Posted on Jan 12, 2008
How do I remove the front driver side power window switch on a 2008 Buick Enclave
Armrest Door Pull
Remove Rubber Cover
Remove 10mm *****
The first step is to pry out the plastic trim plate behind the chrome colored door release handle using a small flathead screwdriver.Then remove the 10mm ***** behind the plate using a ratcheting wrench with an extension bar attached.
Next pry out the rubber cover at the bottom of the door pull located in the center of the arm rest. Use a Torx T-25 (star bit) screwdriver to remove the two screws.
Remove Torx T25 Screws
2 T-25 Torx & 1 10mm *****
Pry Up Arm Rest Panel
Use a flathead screwdriver to pry up the rear of the plastic arm rest panel. There is a plastic hook at the front of the panel, so only pry it up from the rear edge.
Lift Rear End First
Plastic Hook At Front of Panel
Power Window Connector
After you lift out the arm rest panel, you'll need to disconnect the power connector for the window and door lock switches.
Push Connector Release Tab
Power Connector Unplugged
Two More T25 Screws
Push on the release tab with a flathead screwdriver and pull out the power window / door lock connector.Use a Torx T25 screwdriver to remove the two screws located below the arm rest panel.
Remove T25 Torx Screws
Outer Edge of Panel
Push In Center of Fastener
Then move to the outer edge of the door panel and locate the two small round fasteners. Use a small screwdriver to pop in the center pins of the two fasteners.
Pull Out Plastic Rivet
Black Plastic Fastener Removed
Remove Lower Fastener
Pull out the two plastic rivet fasteners and set them aside in a safe place.
Pull Panel Away From Door
White Plastic Pop Rivets
Pull Off Sail Panel
Grab the door pull in the arm rest and tug it towards yourself to disengage the pop rivet friction fasteners that hold the panel to the door frame.Move to the top corner of the door panel and pry off the triangular "sail" panel. On some vehicles, the sail panel contains the tweeter speaker.
Lift Panel Off Door Lock
Pull Out Door Pull Cable
Lift the door panel off the door lock button and tilt the top of it out towards yourself.Use a pair of needle nose pliers to gently lift the metal ball at the end of the door opener cable out of the mechanism.
Disconnect the door cable from the back side of the door panel.
Door Pull Cable Removed
Disconnect Power Mirror
Then disconnect the power connector for the side view mirror by lifting up on the release tab. Slide the power connector off the plastic anchor on the metal door frame.
Slide Connector Off Anchor
Unlock Connector
Connector Detached
Look behind the door panel and locate the large wire connector with the pink lever lock. Swing the lever open to unlock the connector and separate it from the socket.
Door Panel Removed
Power Window Motor
10mm Bolts
Now the door panel can be completely removed by lifting it up and off the door frame.To replace the power window motor, remove the 10mm bolts.
Stock OEM Door Speaker
Remove 7mm *****
The stock "OEM" speaker is held in place by a single 7 mm *****. Remove it with a socket and ratcheting wrench.
Pry Off OEM Speaker
Speaker Removed
Disconnect Power Plug
If the speaker is stuck to the door frame, gently pry it off with a small flathead screwdriver.Disconnect the speaker's power plug by pressing the release tab with the small flathead screwdriver.
Fits 5.25", 6.5", 6.75"
Re-installing Door Panel
According to the Crutchfield website, the 2008 to 2012 Chevrolet Malibu's front door speakers can be replaced withaftermarket speakers in the following sizes: 5 1/4", 6 1/2" or 6 3/4" speakers with the use of a bracket.If you'd like to reduce road noise, make your car quieter and also improve the sound from your speakers, I'd recommend applying some Dynamat Sound Deadener on to the metal door frame.
Re-Attach To Anchor
Plug In Power Side View Mirror
Re-Insert Power Connector
To re-install the door panel, first hold the panel close to the door frame before re-connecting the large wire plug. Swing the pink lever closed to lock it in place.Slide the socket for the power side view mirror back on to its anchor and insert the power plug.
Lock Power Connector
Pink Lever Locked
Re-Insert Door Pull Cable Ball
Insert the metal ball at the end of the door opener cable back in to the door handle mechanism.Slide the black plastic cone part of the cable back into the slot in the door opener assembly.
Door Opener Cable Reinstalled
Hang Door Panel On Frame
Gently lower the door panel down on to the edge of the door frame with the door lock switch through the opening at the top.
Line Up White Plastic Fasteners
Push On Sail Panel
Push Door Panel In Place
Move to the bottom of the door panel and line up the white plastic pop rivet fasteners with the holes in the metal door frame.Push all around the door panel to re-insert the pop rivet fasteners.
Re-attach the sail panel at the top corner of the door frame.
Push Panel Flush Against Frame
Insert Side Edge Fasteners
Insert Larger Piece First
Next move to the side edge of the door panel and first re-insert the larger piece of the two fasteners. Then insert the smaller "pin" piece of the fastener into the middle of the larger piece.
Insert Small "Pin" Piece
Install Lower Edge Fastener
Tighten 2 T25 Torx Screws
Re-Attach Power Connector
Insert Front Hook First
Insert and tighten the two Torx T-25 screws located under the arm rest.Re-attach the power connector to the plastic arm rest panel.
First insert the hook at the front of the arm rest panel and then snap the rear end in place.
Pop Arm Rest Panel In Place
Tighten 2 T25 Screws
Replace Rubber Cover
Insert and tighten the two T25 Torx screws into the door pull cup. Then replace the rubber cover over the two screws.
Tighten 10mm Door Handle *****
Replace Door Handle Trim Plate
Malibu Door Panel Replaced
Replace the 10mm ***** that goes above and behind the door opener handle and tighten it. Pop in the plastic trim plate behind the door handle.
Apr 10, 2016 | Buick Cars & Trucks
Need to put passenger miror on. i need help to show me how to take the door panel off.
Section 01-05: Trim, Interior 1998 Windstar Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 01/22/1999 Trim Panel, Door Front
  1. Remove door latch cover by prying from top edge and pulling trim free of retaining clips and sliding trim away from latch.
  1. Remove portion of armrest containing door lock switch and window regulator control switch (14529) by pulling straight up.
  1. Remove rear view outside mirror mounting hole cover assembly by prying at top and pulling upward to release double-sided clip.
    Trim Panel
    Item Part Number Description 1 23942 Front Door Trim Panel 2 56908-S58 Screw (1 Req'd), Right Door 56906-S58 Screw (1 Req'd), Left Door 3 18B978 Radio Speaker Grille Name Plate 4 56911-S58 Screw (1 Req'd) 5 17D720 Cover Assembly Rear View Outside Mirror Mounting Hole
  1. Remove screw attaching front door trim panel (23942) to front door (20124) under switch plate.
  1. Remove two screws located at bottom of front door trim panel.
  1. Disconnect the door lock switch (14028) and window regulator control switch electrical connectors.
  1. Remove door window regulator handle if equipped by unsnapping and pivoting away the handle cover from base to expose retaining screw. Remove screw from the door window regulator handle.
  1. Pull front door trim panel from the top to release hooks from front door .
  1. Remove front door trim panel.
  1. Replace any bent or damaged fasteners.
  1. Follow removal procedure in reverse order.
Body Side
  1. Remove door handle retaining clip by sliding a shop towel between handle and door trim. With tension on the cloth, pull one end of the cloth so it slides between the handle and the door trim. If handle does not come out, reverse direction.
  1. Unfasten 13 christmas tree fasteners using double-acting spring-loaded trim removal tool and pull body side trim panel from body side door.
  1. Remove forward and rearward mating sections from under window trim.
  1. Replace all christmas tree fasteners.
  1. For installation of handle, install clip to handle, then push handle onto shaft to snap in place.
  1. Disconnect rear window defroster wires.
  1. Remove the liftgate window garnish moulding as described.
  1. Remove screws attaching liftgate handle to liftgate and liftgate inside trim panel.
  1. Using Rotunda Windshield and Moulding Trim Removal Kit 107-R0401 or equivalent, pry pushpins retaining liftgate trim from the liftgate.
  1. Remove liftgate trim.
Mar 07, 2011 | 1998 Ford Windstar
The drivers door will not open inside or outside,don't get it the cables are fasten to seperate places on the latch,feels like no resistence when you pull on the handles,can you HELP!
The handle where the rods are attached could be broken or disconnected inside your door. You will need to remove the interior door panel to figure out what the problem is.
Aug 08, 2010 | 2008 Buick Lacrosse
How do I remove the driver door panel on a 2002 Malibu?
The door panel is held on with small plastic fasteners. Go to your local auto parts store and look in the auto body section for a trim removal tool.
If you do not want to buy the tool, you can use a flat tool of some sort.
Without the tool, you will need to buy plastic fasteners to replace the ones you ruin. (you'll need a flat prying tool at least 8 inches long and 2 inches wide)
Insert your flat prying tool in between the door panel and the door frame. Carefully work your way around the door, slowly popping the panel loose. Once you have the biggest part loose, you will have to pull up on the top and remove the rubber stripping between the window and door frame. Avoid at all cost ripping the plastic fasteners out of the door panel. You want to pull them loose from the door frame. More than likely, you will ruin several of the plastic fasteners. As I mentioned before, you can buy these at the auto parts store. I suggest taking a few with you so you can match them up with the new ones.
May 14, 2010 | 2002 Chevrolet Malibu
Broken water dispensing tube
you h ave a project in front of you. you are going to have to remove the door entirely from the cabinet, including electrical and water line connections. you will then have to remove the inner door liner and gasket, to access behind the dispenser module. you will need to pull the line out from the bottom, carefully, and replace with new water line, then replace gasket and liner, and reattach door.
Good luck.
May 09, 2010 | KitchenAid Superba Architect KSCS25INSS...
Door panel and bezel removal
There are two screws in the door pull (which face straight down) - remove those first.
Next remove bezel around inside door handle. Carefully use screwdriver to push in on four tabs (at the four compass headings) and pull out on bezel. These are easy to break as they get brittle with age.
Start at bottom of door (using a trim removal tool) and pry out door fasteners (white posts which fit into friction fittings in door). You have to pry pretty hard. Use trim removal tool to apply force right at fastener. There are 3-4 on bottom of door and two on each side.
Once all the fasterners are loose. Carefully look behind door and remove the doors light and speaker connectors. The Speaker Connector can be hard to get to - you may need some help holding panel. Be careful because the wires to speakers are delicate and easy to break.
Once the panel is loose - roll down windows and pull up on door panel. It has a lip that fits over top of the door opening. You must pull straight up to disengage it.
That's it all done - not really hard but will seem a little strange at first. Take your time and be careful and the seconds one will take much less. I've had to remove all four of my door panels on my 1999 K1500 to replace window and lock motors. But, after 200,000 miles the 'burb is going strong.
Feb 12, 2010 | 1999 GMC Suburban
How do you take off inner driver side door panel with out breaking the the snaps and panel itself
Sometines the panel retainers do break, they are available at most parts stores, you should use a special tool to remove them (pic below)
Front Door Panel: Service and Repair
Trim Panel Replacement - Side Front Door
J 38778 Door Trim Pad Clip Remover
1. Remove the inside handle bezel (2).
2. Remove the fastener (1).
3. Lift the flap (1) in pull handle opening.
4. Remove the two fasteners (2).
5. Remove the two fasteners (1) from bottom of trim panel.
6. Using the J 38778, release the eight retainers.
7. Lift upward and outward on the door trim panel.
8. Disconnect the door latch cable from the inside door handle.
8.1. Pry the tab on the cable outboard while pulling back on the cable.
8.2. Unhook the collar portion of the clip from the cable attachment.
8.3. Push upward on the bottom of the cable attachment to disengage the cable from the handle clip.
9. Disconnect the electrical connectors.
10. Remove the door trim panel.
1. Partially install the door trim panel.
2. Connect the electrical connectors.
3. Connect the door latch cable to the inside door handle.
4. Raise the trim panel over the lock knob and align the fasteners (1) in the holes in the door assembly.
5. Secure the trim panel to the door assembly by applying sufficient pressure on the trim panel.
NOTE: Refer to Fastener Notice in Service Precautions.
6. Install the two fasteners (2) under the inside pull handle opening.
Tighten the fasteners to 2 N.m (18 lb in).
7. Install the inside trim panel cover fastener (1).
Tighten the fastener to 2 N.m (18 lb in).
8. Install the trim bezel (2).
9. Install the two fasteners at the lower portion of the trim panel.
Tighten the two lower fasteners to 0.5 N.m (4 lb in).
Oct 30, 2009 | 2000 Cadillac Seville
Where can I read, for free, how to remove the drivers door panel and remove and replace the window regulator. I see these questions on this site but there are NO ANSWERS. What's with that? 1998 Cadillac...
GM Cadillac Deville_Fleetwood_ELD_Seville 1990-1998
Fig. Front door panel-1990-91 Deville and Fleetwood
Fig. Front door panel-1992-98 Deville and Fleetwood
Fig. Carefully pry up the power window switchplate and . . .
Fig. . . . gently remove it from the door panel
Fig. Remove the door pull strap retaining screw covers by gently prying them off
Fig. Remove the door pull strap retaining screws
Fig. Gently pull the inside door handle panel down and . . .
Fig. . . . release the rod from the handle
Fig. Carefully lift up the door panel to release the . . .
Fig. . . . retaining pegs on the door panel
Fig. Do not pull the panel too far away from the door, as some components still have wiring harness connected
Fig. Detach any necessary wiring connectors and remove the door panel from the vehicle
  1. Disconnect the negative battery cable.
  2. Insert a flat-bladed tool between the door panel and the rear edge of the power window switch plate to disengage the retainer from the panel.
  3. Slide the power window switch plate forward, then label and detach the wiring connectors.
  4. Remove the power door lock switch plate retaining screw. Remove the switch plate and detach the wiring connector.
  5. Remove the pull handle retaining screws.
  6. Using a thin-bladed tool, carefully pry the courtesy lamp lenses off. Remove the courtesy lamp bulb.
  7. Pinch the courtesy lamp retainers and pull out the lamp socket holder. Detach the courtesy lamp wiring connector.
  8. Remove the door panel retaining screws.
  9. Using tool J-2459B or equivalent, disengage the door panel fasteners from the holes in the door. Detach any remaining wiring connectors and remove the door panel.
To install:
  1. Position the door panel close to the door and attach the wiring connectors.
  2. Align the door panel fasteners with the holes in the door. Push in on the door panel to install it to the door.
  3. Install the door panel and pull handle retaining screws.
  4. Install the courtesy lamps and switch plates.
  5. Connect the negative battery cable.
I really hope help you with this (remember rated it) Good luck.
Oct 12, 2009 | 2001 Cadillac DeVille
Replacing the rear wiper motor on a 2002 olds silhouette
I have the same issue, and just did it yesterday.
1. remove the rear hatch door handle with a T35 star screwdriver bit
2. gently pry the panel up exposing the two bottom plastic push fasteners
3. I used a flat prybar with the notch on the fastener and pryed both off
(the push fastener has 2 washers on the top end so get the pry bar under the top one)
4. Now pull the panel off the side door latches and gently pull down again to expose the two back push fasteners and pry them off too.
You now should be able to remove the motor. The wiring harness comes off easily after you figured out that the only the small end closest to the wires comes off, not the whole "box". Insert the small blade of a jacknife crosswise in the space on top of the connector and pry up the tab letting the fasterner slip off.
I found a motor on the net for about $80 (part number1880686) but it currently is out of stock so I have to wait a couple of weeks to finish. I put the panel back on without the push fasteners and will wait the 2 weeks. Buick dealer wanted $320.
Good Luck
Mar 28, 2009 | 2002 Oldsmobile Silhouette
I need to remove the driver side rear door panel. How do I do it
There should be screws near the bottom of the door, and maybe the hand hold and or door release handle cavity. Look for removable caps and such as well. Also look in the bottom of the door pull.
Once all screws have been removed, see if lift and pull works. Depending on when GM changed over the holding method, this is the first to try.
If that doesn't work, then get a screw driver and wedge between the panel and the door at the bottom corner and pop the panel up.
You may need to replace the pegs before replacing the panel back onto the door.
Jan 25, 2009 | 2000 Buick LeSabre
Kenmore Elite 45986 Front Load Washer Logo
24 people viewed this question
Sal De
 Brian Main
Brian Main
