Question about EliteGroup P4VMM2 Motherboard
I HAVE WINDOWS INSTALLED ..ITS COOL BUT IT WONT SEE MY EXTERNEL HARD DRIVE?
  • KENTRONICS
    KENTRONICS May 11, 2010
    what version of windows and what make/type/model of exhdd
  • 235 Answers
Try replacing the connection cable a worn cable sometimes is the cause of these problems, try inserting a usb flash drive and if the system detects it then do that replace the cable and if you replace it and still not working a device driver for the external is required, try also to plug it on other computers and if it works fine then theres a problem with youre usb port
Posted on Nov 20, 2009
    Sergeant:
  • 233 Answers
For some reason it happens that the power comes out from usb port is not enough to trigger the External Hdd on
if you have a long usb extension or using the front usb ports also it could happens (avoide them) .
Posted on Nov 18, 2009
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
This is an externel hard drive that was working correctly but now my system will not recognise the drive and it's now showing a blue light
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 11, 2011 | LG Computers & Internet
Hard drive installed windows wont come up
One bad lead can cause a computer lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to your hard drive
hope this helps
Oct 28, 2010 | Seagate Momentus Ultra (st94019a) 40 GB...
Toshiba 500gb hard drive is not visible on my computer, the hard drive has a light but it is showing on my computer
Go to computer management by right clicking 'my computer' then selecting 'manage'. Then select disk management. Find your externel hard drive there ( it should be there). Then right click on it, and choose assign drive letter. Just choose a letter in the middle of the alphabet like N or O, then enter. You should see the icon of your external hard drive inside 'my computer'.
Sep 16, 2010 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
How to format external hard disk on MacBook pro?
insert the externel drive into you computer..after detecting your drive by your PC...right click the drive and select format option...
May 24, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I accidently formatted the drive, now have no
try recovery softwares, download pc inspector file recovery software its free on net
Sep 21, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Firelite wont mount on my computer
look at its format, (NTFS) or (FAT32)? and check the DRIVER for the hdd to see if it has any complications or errors, this is easyest fixed by deleting the HDD driver in Device managment and then restarting the computer. good luck.
Oct 09, 2007 | FireLite (USBFLB80) Hard Drive
EliteGroup P4VMM2 Motherboard Logo
75 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
