Where can I get a spare audio connector as my pc's has broken. Do I have to watch for something specifically when I open the pc to unsolder the connectore please . I am in South Africa.
  • 56 Answers
I am in egypt lol you can get it in a computer shop tell them that you audio jack are broken they might tell you that they dont have it just tell them do you know any other places where i get it or tell them can you get it for me.
Posted on Nov 18, 2009
Model d52w20. The F connector on the rear panel is broken. How can I replace it?
The F connector probably is soldered to a circuit board inside your TV. You would have to disassemble the TV to get access to the board to unsolder the broken connector, remove it, and solder the replacement connector on the board.
Mar 30, 2016 | RCA Televison & Video
Repair broken USB connector on Akai EIE Pro
just at the base? on the pcb, unsolder it and you can just order a new one at an electronic store online. And i had it with my akai mpd26. Akait is perfect build, so unscrew( and make pictures often) and the order at an elektroinsstore a new one. The part itself costs nothing;the most goes to sending it. Don't overheat the pcb...
Oct 30, 2014 | Akai EIE I/O Audio/MIDI Interface with USB...
How can I fix a broken cable inside a sennheiser mzh3040?
you have to unsolder the wires on the coil assembly then pull everything out through the bottom. replace the bad wire, reassemble the xlr end and resolder the wires to the coil.
Aug 05, 2014 | Sennheiser Audio Players & Recorders
Can not get keyborad off
Probably the switch to turn keyboard on/off is broken
1) You have open the laptop (instruction here, but yours might be slightly different: http://www.youtube.com/watch?v=9x5SF_NFsw4 - normally you firstly remove the button panel (no screws) and secondly open 1-2 screws at the bottom of laptop)).
2) Find the switch, remove the broken parts or stick them with SuperGlue. As you can't find the replacement switch currently on eBay - you can ask if the computer repair service has one spare.
Mar 05, 2011 | Coby NBPC1022XPBLK Netbook
Loose power connection on sony vaio PCG 7V1M
I'm assuming the laptop is out of warrantee.
It sounds like the power adapter jack is broken. To replace this you have to take the laptop apart down to the motherboard, unsolder the jack, solder on the replacement and reassemble the laptop. This is not something a novice should attempt.
Check with your laptop repair shops. The replacement/repair should be under $100.
Mar 02, 2010 | Sony VAIO Notebook
Eonon 1025e screen mechanism broken. Need to replace two of the gears but cant find spares anywhere
Hi I have the same problem.E1025 unit has broken gears to make unit come out so just removed broken gears and manually pull out.Screen would fold up and down still until today .Now the other plastic gears have broken.I have tried to contact eonon to buy spares but dont wont to know about it.Now looking at old remote cars,video recorders etc to find something that will fit.No luck yet will let you know if i do. Eonon ****
Oct 02, 2009 | Car Audio & Video
VGA out conector unsolder
Good morning! Moigiver, you can unscrew the bolts at the back of your laptop to see the possible defect of VGA out Port & carefully solder it. However, I second the motion with WarheadsSE recommendation to seek assistance from a professional service technician to handle the task, to avoid future problems that may arise if not carefully handled. Best regards.
May 04, 2009 | Computers & Internet
Broken 22 Pin,sync,charge,connector
Here's a solution for the broken socket on Mio 168 and Medion Micromaxx mdppc150 clones. Cheers
Mar 17, 2008 | Mitac Mio 168 Pocket PC
Chassis blowup
Are you talking about your IF connector on tuner?you have to unsolder tuner then carefully open to reattach IF connector,if tuner is cracked then replace tuner.also you can go to www.repair world for more help.I seen where replacement broad wasnt alot to replace.
Jun 27, 2007 | RCA HD52W59 HDTV Projection Television
Atenna plug pulled out of tv, how do i get a signal now?
It has always amazed me how many "F" connectors get pulled out of tuners. I know because I've replaced hundreds, usually successfully, saving the cost of a new tuner. You need to unsolder the tuner from the board and remove the side cases. If the tuner board is not damaged beyond repair, (if it is you have to get creative), a new unit can be soldered in place. Put everything back together and you will be in buisness. New "F" connectors can be purchased from MCM Electronics at www.mcminone.com, part #215543 for $2.50. I always use a new connector as the old ones are usually trashed. Reliability is compromised if you don't use a new one. Technically you do not need the cable hookup since you have composite inputs. For my money I would just hookup a VCR (with a tuner) coming out of the VCR composite jacks into the TV composite jacks and use the tuner on the VCR leaving the TV in Aux, or whatever they call the composite inputs, and call it a day. It's you're choice but using a VCR tuner is faster, easier, cheaper and if you want to play a VHS tape you're already hooked up! If you are a traditionalist and want the TV 100% remember to be safe while working on it. Good luck whichever way you go.
Jun 19, 2006 | Curtis-Mathis CM19011 TV
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
