Question about Hotpoint Dryers
HOTPOINT F09 FAULT CODE, WHAT DOES IT MEAN? - Hotpoint Dryers
  • Hotpoint Master
  • 3,463 Answers
Error code F09 means that that the Eeprom is not programmed or is not functioning.
Check the Eeprom and control board.connections.
Eeprom is short for electronic programme controller.
Please rate my solution.
Thanks.
Posted on Nov 18, 2009
Testimonial: "THANK YOU, FOR YOUR HELP. A VERY QUICK RESPONCE"
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 | Dishwashers
Machine stops working and shows F09 what does this mean
Really need the make and model as different manufacturers use the same code to mean different things. Hotpoint/Indesit/Creda F09 on almost all appliances means "Eprom Fault" this is a problem with the main control chip and you will need an engineer to reprogram the main module or swap it out. If it's Bosch, then the good news is F09 means "Heater Fault" which almost certainly means a cheap £20 replacement heating element needs fitting
Sep 19, 2015 | Washing Machines
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
What does error code f09 mean on a bosch vented dryer,?
F09 error is no heating, you can fix that by opening up the back and pressing the red cutout button which will restore hot air.
Jan 30, 2015 | Bosch Dryers
Hotpoint wf541 fault f09 lights 1&4 eprom/setup error
That/those require(s) an engineer- I'm sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 15, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Panasonic dmr-ez48v error f09 what is it?
If I have got the right machine than F09 is an electrical fault. If It is a K Deck model (you need to check) then it means: No serial clock linking IC2004, IC7005 and IC7701.
Nov 14, 2009 | Panasonic Televison & Video
Hotpoint washing machine WF 840 displaying F-09
f09 is a communication fault on the computer board.A suggestion to you would be to unplug unit.Carefully remove and reistall each wire at board
Nov 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint washing machine WF840 which is displaying F-09, do you know the fault
f09 i s a communication problem between mother board and controls.Before replacing board, I would suggest unplugging unit and re-terminating each connecter going to board
Panasonic deck ag dv2000 gives error code f09
Your vcr seems to use the K Mech. F04 Means that the mechanism locks unloading.
The cause of which might be the loading motor timing.
F09 means No serial clock linking IC2004, IC7005 and IC7701.
Apr 29, 2009 | Panasonic AG-DV2000 Mini DV VCR
Dryers Logo
1,806 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
