Question about Olympus VN-4100PC Digital Voice Recorder
Got new batteries but the screen says Lo and the battery image is empty
    Sergeant:
  • 271 Answers
The Cmos battery is low. The Cmos is the clock battery and is NOT user replaceable! Sond it to olypus to get it replaced.
Posted on Nov 18, 2009
Oven thermometer only displays lo
I just had that LO reading. Pulled back on the tip of the thermometer. Seems I had it inserted into my turkey too far. Probably up against a bone or too close to the center. Good luck! Happy Thanksgiving 2016!
Dec 25, 2013 | Farberware New Classic Alert Oven Probe...
My beutler 800 said lo bat we replaced them and still reads bat lo
The other "solution" posted here is not a solution. According to this web site: http://www.espenergy.com/faq_honeywell_thermostat.htm
First, replace the batteries with a new set of AA alkaline batteries. If you insert the new batteries within 20 to 30 seconds of removing the old ones, you will not have to reprogram the thermostat. If the bAt Lo indication does not clear itself once new batteries are placed in the device install the batteries backward for 5 seconds, take them out, and reinstall correctly.
So I tried it... put the batteries in backwards. It completely reset the thermostat so I had to reprogram it (which was easy enough). One thing I did that the instructions did not specify. After I removed the batteries, I let it go completely blank before installing them backwards. Then I waited 5 seconds, pulled em out and put them back in correctly and eventually it started flashing indicating it needed to be programmed. HINT: Don't forget to set the current time!
Dec 04, 2010 | Honeywell Programmable Thermostat Heater
I changed the batteries of the Honeywell thermostat and on the screen it still shows low battery.
Hello my name is Heath it will be my pleasure to assist you. Take the new batteries out and let the display go completely blank then reinstall the new batteries and the lo batt light should go off.
Nov 08, 2010 | Honeywell Heating & Cooling
I couldn't take anymore pictures because "the memory card was full." I downloaded the pictures and the card is now empty. Now when I turn the camera on, the green light is on but there is no image on the...
Go into the menu and find "reset"...follow the on-screen instructions. Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on. If it now works, with the card in the camera, go into the menu and find "format" and follow the instructions to erase the card and optimize it.
May 20, 2010 | Canon PowerShot A520 Digital Camera
Batt Lo Displayed. I replaced with new batteries. The display still reads Batt Lo and I cannot changed temperature, etc.
sometimes you can bend out the battery holders to allow more tention on the batteries but thats only a temporary repair. a new thermostat is needed
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
"battery empty" on screen after I disconnected camera from compu
Hi, have olympus fe-280 camera. Battery on screen shows full but shows empty (an inch strip) in middle. I have charged it. Even bought a new battery. Can anyone help. Thank you. ...... I want thinking I may have two faulty batteries and just need to buy another one?!
Jan 25, 2009 | Olympus FE-280 Digital Camera
Malfunction D80 showing erratic "Lo " message,
if you're in a P mode it means it in low light condition. whne you see the Letters "LO" and take a shot it woudl take time before the camerea releases the shutter because it's automatically exposing the image and exposure may take longer depending on the lighting condition.
Jun 01, 2008 | Nikon D80 Digital Camera with 18-135mm...
Battery problems
Check the battery contacts inside the camera. Use a strong light, and if you see corrosion (black or greenish areas) on the contacts, rub them lightly with a pencil eraser until they are shiny.
Apr 05, 2007 | Canon EOS-1V with 28-105 and 100-300 lens...
Olympus VN-4100PC  Digital Voice Recorder Logo
126 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
