Question about Bosch Dishwashers
The pump to get rid of water does not stop, I have tried reseting it with no success, it has been fine before this problem
    Scholar:
  • 62 Answers
Hi.
The problem is that water has entered the base of the appliance and has activated the anti flood device.
To prove this disconnect the power to the appliance and wiull a few towels handy pull the dishwasher out. Place towels behind the appliance and tip backwards about 45degrees. If you can see water coming out then this confirms the problem. The appliance will work again for a few washes then same problem wioll come back.
Unfortunately there are many reasons why this can hapen so you will need to call a local engineer.
Regards
Aardvrak Repairs
Posted on Nov 18, 2009
Testimonial: "Many thanks for your help"
LG Frontloader WM1832CW gets stuck on spin at 9 minutes... cleaned drain pump, replaced door lock, motor, hull sensor and bearings... reset a million times... anyone have any idea if it could be the final...
check for blocked pump or slow drains. if water cant get out, machine will keep trying to get rid of it. i put drain hose in a big bucket and tried worked fine had a slow drain.
May 16, 2013 | Washing Machines
Brand new SGS57A02GB just fitted. Run initial cleaning wash to get rid of factory water. Drain starts then stops, starts filling, goes through 2 filling cycles then the drain pump starts. The drain pump...
This problem is mostly caused by the drain pump or a restricted drain line. Try taking the end of the drain hose off under the sink and re-checking the drain-out condition. If the unit is still not draining, I recommend replacing the drain pump.
Other possibilities could be that the sump is blocked, or the control or harness may need to be replaced.
Hope this helps.
Shane
Feb 01, 2011 | Bosch 24 in. SGS57E02 / SGS57E08 Exxcel...
After starting dishwasher to do a normal wash with heated dry, the dishwasher stops and Clean light blinks 7 times, pauses and this continues until I reset the machine. After reset it goes to rinse only...
Hi
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn’t work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Please post back for further assistance.
Daniel
Aug 20, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
We have a neff dishwasher and the pump is draining all the time (even when the door is open) but there is no water in the dishwasher. Is there a way to stop the pump and reset the setting for the flood...
The water which has activated the antiflood device is actually underneath the appliance it is held in the sump tray and this has to be drained before the A.F.D.will cancel.You will have to remove the dishwasher to get at the underneath but when you have got rid of the water you will still have to trace what caused it.The seal on the circulation pump could be a suspect or a pin hole in the drain hose.
Hope this helps.
May 09, 2010 | Neff 24 in. S5409X0 Built-in Dishwasher
My Hotpoint Ultima Washing machine - When I switch it on all the lights keep flashing and I can't get rid of them !! When the machine then starts the cycle it still flashes but then stops half way and says...
I would advise you to check the drain outlet hose for a possible blockage, or the pump itself could be blocked or faulty.
Drain any surplus water in to a bucket or similar before removing hose or pump.
Also try resetting washer if there is a reset button, hold it in for at least 3 seconds, this should clear any programme held in the memory.
Hope this helps.
Feb 01, 2010 | Hotpoint Ultima WF860 Front Load Washer
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Water cooling noise
Could be air in the system which you would need to bleed out. Either that or a faulty pump.
Sep 24, 2008 | Thermaltake Symphony mini Water Cooling...
Flashing F and alarm
Based upon your description, the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.... Hope this helps
Jun 08, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Dishwashers Logo
218 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
