Question about Fujitsu Siemens AMILO D-7830 Notebook
How do I reformat and re-install Windows XP Home if I was not provided with the OS on CD - it was on-board and installed when it was started up.
  • 530 Answers
This reason you where not provided any software is due to the increase in size of HD (hard drives). When HD became big enough computer manufactures eliminated back-up software on CD and opted to place the software on the HD. They do this using a hidden partition on the HD. This has the added benefit allowing you to restore it back to how it came from the factory or to your last system save.
If you are not sure whether or not you have the Hard Disk Based Recovery, (HDBR), then follow these instructions.
The hidden partition contains an image of the software preloaded. This image is part of a new recovery process called HDBR .
  • Pressing [F8] during the boot process the advanced Windows start option will appear with the new option: "repair computer".
  • Choosing this option a Windows Recovery Environment will be started. In addition to the MS Windows tools, you will find a Fujitsu Recovery Tool. This tool allows you to set the software of the computer back to the delivery state. If you delete the hidden partition this feature is no longer available.
However, if you do not have any media included to your computer it is not recommended to delete this partition because you are no longer able to recover the system then.
Hope this helps, but if not please let me know and I'll try and help.
Posted on Nov 18, 2009
  • 691 Answers
You have a few choices:
1. Contact Microsoft and pay them whatever media fee they want.
2. Download a torrent of the CD. (a little risky). You should search for "XP Retail"
3. Borrow one from someone. You might luck out with a OEM disc.
4. Go to your local ma and pa computer repair shop and ask them if they'll burn you a copy of their disc.
5. Or use one of those "CD repair kits" on your damaged windows CD you had from your last post. You might luck out.
I want to change my windows xp to Home edition
You can also do a clean installation by following the procedure as listed below:To perform a clean installation of Windows XP, follow these steps:Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.At the Welcome to Setup screen, press ENTER to start Windows XP Setup.Read the Microsoft Software License Terms, and then press F8.Follow the instructions on the screen to select and format a partition where you want to install Windows XP.Follow the instructions on the screen to complete the Windows XP Setup.
Oct 27, 2010 | Microsoft Windows XP Professional
How can i reformat my Blue IL1 notebook?? i think it has a virus... it doesn't continue loading, it restart when it reaches the windows xp logo... thanks for the help
Hello, you relly need to reformat it you can use an os installer suach as linux or windows using a usb flash drive, but you have to transfer the installer cd to the usb drive by using the wintoflash application. Once you've done that now you can reformat and install os in your notebook using your usb flash drive.
Sep 12, 2010 | CTL IL1 Notebook
I have installed dual os(XP and Ubuntu Linux 10) on same drive It is working but my pc became very slow. Now I want to uninstall any or both os but it is showing error. So suggest me How can I?
Hi, try the following sequence.Insert your XP disk and reboot, during bootup press your ESC button or Del on some PCs, you will be in BIOS, from here you can change you primary boot drive, select CD rom, save changes and reboot. Press return when request to boot from CD appears, wait for the sequence to finish installing, select the section of the drive you wish to change, select delete, confirm and then reformat your hard drive. PC will reboot afterwards and start installing XP. Be aware this will remove everything from your hard drive, so back up first. Hope this helps
Jul 10, 2010 | Microsoft Windows XP Home Edition for PC
HP 520 Notebook. Shuts down before installing new OS.
I agree a clean install is always the better, fresh start J
OK it sounds like missing drivers, what you have to do is create a new installation CD that will load the drivers for your laptop as it boots. I haven’t try this method with windows 7, but I know it works well with Windows XP. Try and create a new Windows XP CD with the drivers see: http://unattended.msfn.org/unattended.xp/view/web/35/
The start a new installation with this Windows XP CD and reformat you computer, after that you can do a new upgrade to windows 7
Nov 25, 2009 | Office Equipment & Supplies
I reformatted my computer and i cant get drivers
If you have linksys hardware install the cd that came with hardware and get to linksys website and download latest driver. Reformatted cleans drive to zip data and you needed to reload XP to get it going so anything you installed after the system purchase you will have to reinstall.
Aug 29, 2009 | Microsoft Windows XP Home Edition
IBM NetVista 6790 31u - Need to reformat single HD computer.
The PC comes with a restore CD. This to reinstall or repair your OS which is a genuine copy(look for the sticker)Use te restore CD while startup and follow the instructions...........sodeep
Apr 07, 2009 | IBM NetVista PC Desktop
How to install windows xp in presario c700?
First download all of the Xp drivers , unless you have then on a disk already. (Link provided below) Next:   Insert the windows Xp disk into the cd driver. When it says ;"OS system found do you want to repair it?" or anythng else say No. If will say reformat driver? Say Yes. Let it run giving it all the information requested  including the registeration numbers that came with the Win Xp disk when you bought the disk by itself.  Install all of the drivers,one at a time .
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=3632144〈=en
Feb 28, 2009 | HP Compaq Presario C700T
I reformatted my c drive and now cant install windows
when you get past the user agreement page ( F8 ) you need to delete the partitions on drive "C" this will wipe out any previous editions of xp, providing you have an XP install cd it should allow you to install and input the product key
keep us informed so we can asssist further if needed
regards
The Fixya Team
Nov 19, 2008 | Sharp PC-UM20, Pentium III 750Mhz, 12in.,...
Computer Won't Recognize Printer
This is a tough one. When you say that "My Device Manager isn't showing up any of my hardware..." does that mean that there are other hardware problems in the device manager? When you plug the printer in, how des it show-up in the device manager (ie: unknown device under HID)? Why did you "... recently reformatted my computer ..."?
Sep 24, 2006 | Brother MFC 210C All-In-One InkJet Printer
Fujitsu Siemens AMILO D-7830 Notebook Logo
941 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
