Question about NorStar M7208 Corded Phone
NorStar M7208 I have a 2 line phone...the second line shows "as in use" but no one is on that line, but I can not get the line to release. HELP!
Reboot the phone system.
Unplug the main control unit.
Posted on Jan 11, 2008
6ya staff
SOURCE:
Norstar M7324 not showing lines in use and unable to retrieve calls on hold
That might mean that the line(s) is(are) not programmed for that telephone. If you press feature * 0 then one of the line buttons, does it list as a line or blank?
Apr 22, 2014 | NorStar M7324 Telephone
Lines 1 abd 2 on Norstar phone are showing as being used, however, no phone being used
You probably have two lines conferenced together. The fastest way to fix it is to unplug the system cabinet. It drops the conference and releases the lines.
Carl
Oct 31, 2011 | NorStar T7316E Corded Phone
Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Jan 12, 2010 | NorStar M7100 Corded Phone
Norstar M7208 - Only 1 of 3 phones will ring
The display should sat line 001: appear only press CHNG til it says appear &ring.
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
Sep 21, 2009 | NorStar M7208 Corded Phone
Line in Use
It's possible that the last caller, never gave the system the "Disconnect" it needs from the phone company. Try rebooting the phone system. Just pull power on it, let it sit for 10 seconds, then reapply power.
Jul 14, 2009 | NorStar M7324 Telephone
Deleting security code from Norstar Meridian M7208
Go to programming of Norstar bY Feature**266344 passwordwill be 266344.
Press show put the extension number then show the keep pressing next until display shows restrictions.Press show the next until dispaly shows ext rest. then show then show again and check what is the restriction filter number.
Press heading till u get restrictions.press show then show again. put the restriction filter code and delete or remove all restrictions from the filter and press release and come of the programming.
Restriction has been removed now.
After that u can easily make o/g calls without using any code.
May 05, 2009 | NorStar T7208 Corded Phone
Meridian M7310-shows outside line in use and cannot disconnect
the easist way to reset that is to reset the system. unplug it for a moment that should clear it.
Mar 27, 2009 | NorStar Meridian M7310 Phone
Only First Phone in the system will ring on incoming calls
These manuals are available on the norstar web site.
Jul 08, 2008 | NorStar M7310 Corded Phone
NorStar M7208 Corded Phone Logo
219 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
