Question about Samsung Refrigerators
My Samsung double fronted fridge keeps sounding an alert but no doors are left open.It sounds every 30 seconds to a minute.Any ideas?
  • Samsung Master
  • 19,396 Answers
Hi.
Try resetting the appliance.
Hold down the cancel bitton for up to ten seconds.
Try tripping the circuit breaker or disconnecting power cord for a couple of minultes.
If that does not work, then let me know if the unit is cooling or not.
If the fridge is cooling it may be a defective control board.
Regards.
Posted on Nov 18, 2009
Had customer with CO detector sounding quick double chirp about every five minutes. What is this?
This is not a beeping smoke detector. It is probably a CO detector that was installed by your alarm company. GE model 240-COE will give a double beep every 5.5 minutes when the device reaches end of life. Call your alarm company to have it replaced.
Jun 07, 2014 | Kidde DC Voice-Alert CO and Smoke Alarm
New integrated baumatic fridge freezer installed yesterday but the door sensor alarm keeping going off..door is def shut. As baumatic gone into administration has anyone got any ideas plse?
It's telling you it has a fault, you have to find out who is doing the warranty work for Baumatic now, by law they have to honor the warranty.
Nov 30, 2013 | Baumatic Refrigerators
Samsung French door fridge is making an intermittent "whooshing" noise. It's still cooling and making ice and I don't see any frost or standing water in the fridge. Any thoughts or advice would be a
These fridges go through all sorts of cycles, the defrost cycle is probably the noisiest, strange sounds are ok, it will tell you when something serious is wrong, alerts & alarms.
Nov 16, 2013 | Samsung RF265AA Bottom Freezer French Door...
My built in side by side is making a noise about every 30 minutes or so that sounds like a woodpecker pecking on it...about 10 times. It is driving me crazy! Have any idea what this might be?
I have the exact problem with my built0in side-by-side Monogram. 1 yr 3 months old, and it sounds m=like a woodpecker for 3 seconds approximately 1ce/hr. Does not appear related to ice maker. You can create the sound by changing the temp setting on the drawer at the bottom. As you command a lower temp, the sound happens a couple seconds. Actually sounds like a solenoid opening and closing at 60Hz frequency, as though a control board were feeding AC to a DC coil. Any ideas? Fortunately, this fridge has a 2 year warranty, but this should not happen to a $6K dual condenser fridge in just over a year!!
Jan 09, 2010 | GE Monogram® ZISS420DMSS Side by Side...
Vacation button keeps on activated(refrigerator Samsung SRS20NTC)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Set to regular temp then lock functions.
Freezer temp + fridge temp for 3-8 sec to lock function
Dec 13, 2008 | Samsung SRS20DTD Side by Side Refrigerator
Samsung SRL551 DP Fridge/Freezer
check the manual for a reset button, or un plug it for 30 minutes then plug it back in.
check also the door switches, they could be malfunctioning, see if the lights are turning off when you press the switch.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Fridge cooling 54 degrees - freezer 38 degrees and 24 degrees
Will not be the defrost timer as they have a set cycle independant of the normal cycle...unless your fridge is eletronic. Did you stand the fridge up when shifting?
Dec 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
