Question about Sony PlayStation Portable (PSP) Console
The psp sounds like its trying to spin but it just wont load. can you help me find out whats wrong?
  • 188 Answers
Whack your PSP a few times, not too hard though, see if the UMD drive starts working!
Well, at least 'it' worked for me! XDXDXD
If you PSP is still under warranty, then you can BRING your PSP to SONY, FREE of charge!
If not, bring it to repairs anyway, Eg SONY.
Posted on Nov 18, 2009
Psp not reading games
Sounds like the laser is shot or the door is not making a good connection when its closed. So the system has no clue there is anything inserted. This could be from a bad latch, fried laser, or something on the motherboard itself. Does the spindle motor inside try to spin the disc?
Feb 24, 2014 | Sony PSP-3001
My PSP wont load any of my games, why?
I have the same exact problem except my NBA game wont work. The problem is that the disk won't spin well enough. you need to lubricate it somehow without damaging the disk
Aug 16, 2009 | Ubi Soft Asphalt: Urban GT 2 for PSP
My psp wont play the UMD and a cliking sound is made
get in toutch with sony thay will advise you wetther it can be fixed or if you need a new one
Jul 26, 2009 | Sony ACY-BR81/OB
My psp2006 ver5.03 cant read games
PSP UMD Repair: Not reading UMD discs
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
After this try and see if it is reading UMD again.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
All photos and content copyright © Llamma Corp. 2002-2006
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
Jul 16, 2009 | Sony Video Game Consoles & Games
When i put a psp game in it wont load up all i see is the spinnging thing at the bottom how can i get the game to load up
make sure that nothing stand in front of the psp lens and use some UMD's that are not damaged, no scratch, if after that is still not working, then something is wrong with the psp, also you can try to update the firmware
Jul 08, 2009 | Video Game Consoles & Games
My psp wont read disc
try sending your psp to a game shop and ask if they do consle repairs if they do ask if they know a place were they do repairs
Mar 28, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp3002 when the disc inserted, it made a sound
ok soyou psp made a funny sound when you were loading it up. hmmm i would say you might have a problem wit your disc reader. try other games and see if makes the same noise or doesn't make a noise it used to do like the high spinning revolutions the disc spins at. if it isnt moving then you need to get it fixed because your lense reader have probably shititself from things like smoke ashes or watrer or even heat.
Jan 01, 2009 | Computers & Internet
Help!
You might have PSP stop reading UMD discs, First you will do some trouble shooting with what might be wrong with your PSP unit.
first is the Disc Spinning motor. This will not let The disc in the UMD spin. On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
2nd is something stuck in the UMD gear, try to clean the gear of arm of dust, plastic, soda, and even hair.
and at the last is the actual laser itself. It will not focus the laser to read the UMD disc.
Hopefully this help, Pls post back should you need additional information...!
Jun 01, 2008 | Sony PlayStation Portable (PSP) Console
PSP WILL NOT LOAD DISCS
Hmm there might be something wrong with the drive or the XMB software (read: firmware) which controls the PSP.
You can try updating the PSP to a more recent firmware (if possible) by using it's online update feature or by downloading it from the PlayStation website.
If that won't work I think it's an hardware defect and in that case you'll need to contact Sony PlayStation tech. support.
If you need help updating your PSP unit, let me know.
P.S. No need to type in caps, just sounds like you are screaming ;)
Greetings,
DarkNeogen.
Jan 25, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
