Question about Hobart Food Mixers
I want to order 4 pcs. Part # 107342 tumbler yoke & shifter pin assy. where can I order it and how much each for Hobart N50 mixer
  • 235 Answers
SDBARBAS - You might try using the very easy "Hobart" smartparts webapp on the Hobart website. Cut and paste this into your browser Address line: http://catserv1.itwfeg.com/Hobart-Root/items.cfm, which is the parts list and an exploded view of the assembly for: Planetary, Tumbler and Agitator Shaft Unit Assembly. Go to Item # 64, and select "Add". The screen will change to 'Parts Selected'. Increase Qty to 4, hit "Update Quantities" and then hit "Confirm Parts Selected". On the next screen, select "Find Service Office", and follow the instructions on that pop-up window. You should be able to find a Hobart Service Office in your area that can price out your 4 tumbler yoke and shifter pin assembly. Good Luck... I hope this is helpful.
Posted on Nov 19, 2009
  • Howard Lincoln
    Howard Lincoln Nov 19, 2009
    - I was a bit hasty providing the link above. I failed to mention that you first have to register with Hobart to access their Hobart 'smartparts' app. It's well worth the effort. See the msg from Hobart below:
    Public access users
    If you have previously registered via the www.HobartLink.com site, please access www.HobartLink.com via the www.HobartCorp.com site. If you are a new user please register via the www.HobartCorp.com site.
    Sorry for the confusion - Howard
Hobart N50 noises
The frequency is the same in all gears.
disconnect the power and invert the mixer and remove the planetary after driving out the taper pin, then you can access the transmission. It may be a rotor shaft bearing in the motor or no grease on the worm gears.
Nice touch with the video.
If you need parts:
Jan 04, 2014 | Hobart N50 Stand Mixer
My hobart n50 has no ground on the power cord, also any ideas on where to get parts?
If the ground pin on the cord is missing, you can put a new plug on the end of the cord -- hardware stores have them.
Charlie
Jan 07, 2011 | Hobart N50 Stand Mixer
We need to buy some parts for Mixer N50, Please provide us part list easy to order from you.
www.hobartservice.com click on locate an office, enter your zip and it will show the office closest to you. They will be happy to sell you parts for any Hobart product.
Jul 01, 2010 | Hobart N50 Stand Mixer
Hi somenone may describe how I can procede step
after you removed the tapered pin on the plant. you should be able to get it off the mixer main shaft @this point, there is nothing else holding it to the main shaft
Sep 25, 2009 | Hobart N50 Stand Mixer
I have a Hobart N50 and am in need of a SS bowl. The bowl pins are 8 7/8" apart. Do they make a replacement bowl for this? I've seen the ones that have 9" bowl pins. Thanks, Ron
can buy hobart bowls from lots of places, or use the correctly shaped kitchenaid ones, both fit.. i like the lip and thickness of the hobart bowls, bought mine from globe equip.. do u still have the service manual, if so i would be real intrested in it, please
Jun 14, 2009 | Hobart N50 Stand Mixer
Hobart N50 Tripped
The reset button is to protect over amping the motor. The N-50 is not a very strong unit, (commercially), but you won't break a gear. If you overload the unit, you'll either trip the overload (reset button), or you will break the taper pin that attaches the planetary to the center shaft.
If you're looking for a small commercial unit, and you're in the US, look into the 10 qt Precision Mixer.
Apr 04, 2008 | Hobart N50 Stand Mixer
Hobart n50
I need the serial #,ml or spec # and the exact model #.Ill help you out.I can tell you right now from your description is the tumbler assembly is worn.
Mar 29, 2008 | Hobart N50 Stand Mixer
Planetary shaft for h600 is bent
Thats the center shaft and if it moves back and forth the lower bearing is bad or the shaft has cracked.You need to remove all 3 shaft assemblys. if you already removed the gears on the center shaft then you need to remove the shifting yoke---turn power off to machine then take the screws off the trim plate where you shift speeds,you might see a switch that sits up on the shifter cam,remove the screws and put switch aside,take the 4 allen screws off and pull on the shifter(it will come out).If you didnt already drain the oil do it before you mess with the shifter.after the shifter is out grab the upper left gear assy. and the gear assy. below it,rock both gear assy. and pull up,they will both come out(you might need some force)once out remove the remaining gears on the center shaft and remove the shifting yokes.you then need to remove the planetary (lower part of mixer)if not already done,then pull the shaft out from the bottom.any questions let me know.
Nov 19, 2007 | Hobart D300 Stand Mixer
Food Mixers Logo
183 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
