Question about Cell Phones
Hello, i'm having a problem with my cisco 7970g IP phone running on SIP system and needs settings input to work with my ringcentral.com accounut
  • csmith775 Nov 18, 2009
    the service provider told me to contact cisco to find out how to input those settings into the phone's system.
    Sergeant:
  • 297 Answers
Ask ur service provider
Posted on Nov 18, 2009
How to upgrade to SIP Firmware on Cisco 7945G
This process should work for you http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
Cisco Telephone Power Brick
Sep 08, 2012 | Cisco 7945G IP Phone
Tip
Configure the DPH-540 with RingCentral
To get the DPH-540 to work with RingCentral, you need to add a DigitalLine to your RC service. Then you need ignore the email sent by RingCentral which provides configuration info; instead, login to your account on the RC web site.
Click on the Preferences tab, then the "Setup Instructions" for the DigitalLine device. That should produce a popup window with info like:
SIP Domain: sip.ringcentral.com:5060
Outbound Proxy: sip.ringcentral.com:5090
User Name: 1805715xxxx
Password: yyyyyyy
Authorization ID: yyyyyyy
The password will be the same as the Authorization ID.
Configure your DPH-540 just enough so that it can obtain an IP address via DHCP. Then use a browser to configure most of the rest of the DPH-540 (user admin, password admin by default). However, the browser interface does not let you associate a SIP configuration with a profile; that must be done on the phone itself (consult the userguide and just keep at it; it's not that hard).
For an image of what the web interface and config page for a DPH-540 SIP configuration looks like, see http://homepage.mac.com/saj777/techtips/DPH-540_RC-config.jpg
on Jan 05, 2009 | D-Link DPH-540
Want to migrate fom sccp to sip protocol for cisco IP Phone 7912
Here's a great little document from Cisco directly, called "Converting a Cisco 7940/7960 CallManager Phone to a SIP Phone and the Reverse Process"
Easy to do, just follow the step-by-step directions.
Jan 21, 2010 | Cisco 7912G IP Phone
Can I use a CISCO IP 7941 phone, that has been on a company network, in my home? Should it just work by plugging in a telephone connection and using the appropriate power supply? Is there programming that...
Yes, there is programming which would need to be removed. However, you would need a cisco call manager($800) at home. Unless of course you have voip in your home. then you could just set it to DHCP I'm assuming and then it should just work!
Jan 14, 2010 | Cisco 7940 IP Phone
I am trying to unlock my phone to program it under sip
Complete these steps:
1.On the Cisco IP Phone, press the Settings button.
2.Press **#
3.When the window displays Settings Unlocked, click the More softkey.
4.You now see the Erase softkey, which can be used in order to erase the configuration on the Cisco IP Phone.
I hope that this has been very helpful for you
If this solution will not helpfull for you that time pls send me a IP Phone details.
Jan 01, 2010 | Cisco 7940 IP Phone
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Dec 09, 2009 | 3Com NBX 2102PE IP Phone
Polycom SoundPoint 550-Only Showing 1 line
On the phone, press the menu button, then status, then IP status or whatever and get the phone's IP address. Write the ip address down. On your computer, open up a web browser and input the phone's IP address into the address bar and press enter. This should arrive you at the web gui for that phone. It'll probably ask you for login credentials; by default, the name is "Polycom" (yes , it is case-sensetive) and the password is 456. Once you are logged in, you should see several links like "General" "Network" "Sip" and "Lines". click on Lines. under "line 1", you will see the configuration for that line. simply duplicate the entries for lines 2, 3, and 4.
Jul 29, 2009 | Polycom SoundPoint IP 550 IP Phone
We have a mitel 3300 connected to cisco CM thru siptrunk
can somebody help me we have a Sip connection between a mitel 3300 and Cisco callmanager only the conference call doesn't work who can help me out
Apr 02, 2009 | Mitel 5212 IP Phone
Convert CISCO 7940 to SIP
you need different files to upload by tftp
by example version 8
P0S3-08-2-00.sb2
P0S3-08-2-00.sbn
P0S3-08-2-00.bin
P0S3-08-2-00.loads
OS79XX.TXT (tells the version)
SIPDefault.cnf
Aug 25, 2008 | Cisco 7940G IP Phone
Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
  1. Press Settings.
  2. The Network Configuration lock symbol must be unlocked. If not, exit to the main window and press ** # again.
  3. Press 3 on the keypad (or scroll down) for Network Configuration.
  4. Press 33 on the keypad (or scroll down) to Erase Configuration.
  5. Press the Yes softkey.
  6. Press the Save softkey.
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
May 18, 2008 | Cisco 7910 IP Phone
Cell Phones Logo
95 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
