Question about Cisco 7970G IP Phone
Guess I need to program these settings into the phone for it to work with RingCentral: (You wouldn?t happen to know where I go on the phone to put those in do you?) Generic VoIP Phone/Adaptor Configuration To configure your device to connect to the RingCentral service, you will need to program it with the following information. The steps for programming will vary from device to device, so please check with your device's manufacturer for specific instructions. Field Value SIP Domain: sip.ringcentral.com:5060 Outbound Proxy: sip.ringcentral.com User Name: 19492077227 Password: 7404279 Authorization ID: 7404279
  • csmith775 Nov 18, 2009
    hello, i'm not very savvy with this phone, would you be able to help me find the sections on exactly where and how to add the following to my cisco 7970 phone?
    Password: 7404279
    I need to configure my phone with these settings: Sip Domain, Outbound Proxy, User Name, Password and Authroization ID so that the phone will configure with my RingCentral Account. Please Help! ;)
    Brigadier General:
  • 7,191 Answers
Your problem dated 18th Nov 2010 was re-posted today. If it has been already resolved, kindly ignore this message.
Thanks for using FixYa
Posted on Aug 09, 2010
  • 838 Answers
Thanks for joining Fixya. First please tell me are you able to access it's setting through touch screen or on screen. Again are you able to access through Cisco Call Manager. Please clarify. Thanks
Posted on Nov 18, 2009
    Guru:
  • 830 Answers
Hello and thank you for using Fixya's services.
The Cisco Administrative guide is very detailed and will guide you on how and where to enter the information in the phone. You can find the administrative guide here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7970g_7971g-ge/7_0/english/administration/guide/70adm70.pdf
If there is anything else you need to configure, now or later, here is the user guide manual.
Please let me know if you have any questions.
Tip
No special firewall rules needed for DPH-540 and Dlink DI-604 router
My DPH-540 works fine behind a DI-604 NAT router, without any special firewall configuration on the DI-604 (I connect to either RingCentral or SIPPhone). I hope to get another SIP phone and see if both phones can work simultaneously behind the NAT router; many web sites suggest that a different proxy port must be used (the default is 5060).
on Jan 05, 2009 | D-Link DPH-540
Tip
Configure the DPH-540 with RingCentral
To get the DPH-540 to work with RingCentral, you need to add a DigitalLine to your RC service. Then you need ignore the email sent by RingCentral which provides configuration info; instead, login to your account on the RC web site.
Click on the Preferences tab, then the "Setup Instructions" for the DigitalLine device. That should produce a popup window with info like:
Outbound Proxy: sip.ringcentral.com:5090
User Name: 1805715xxxx
Password: yyyyyyy
Authorization ID: yyyyyyy
The password will be the same as the Authorization ID.
Configure your DPH-540 just enough so that it can obtain an IP address via DHCP. Then use a browser to configure most of the rest of the DPH-540 (user admin, password admin by default). However, the browser interface does not let you associate a SIP configuration with a profile; that must be done on the phone itself (consult the userguide and just keep at it; it's not that hard).
For an image of what the web interface and config page for a DPH-540 SIP configuration looks like, see http://homepage.mac.com/saj777/techtips/DPH-540_RC-config.jpg
I have a panasonic EB-X400 and i put the sim card in and turn it on. after about 1 minute it comes up with Failed! then emergency calls only. is there anyway to fix it?
hello,i guess the phone has a network programming problem,i will advice you reset the phone.if that is done kindly let me know what happens.
take care.
Aug 11, 2010 | Panasonic EB-x400 Cellular Phone
I need to fix the frequency to match my other motorola XTN series radio model #XV2600 to my new motorola RDM2070d radio
Here is a link to the CP100 user manual, it is the sister radio2.gif to the XTN, and programs the same way. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Refer to the bottom of page 20 to get started programming2.gif.
Basically you hold in the PTT and the MON button while turning the radio on. Continue to hold them in until it stops making noise. This puts you in programming mode, and you can use the menu button and the + and - to walk you through reprogramming the radio.
We do not know specifically how your RDM2070d radio is programmed. You would need to know this to program your XTN to match. However, a good educated guess would be to start with Blue dot and Green dot frequencies off of the frequency chart in the user manual listed above. An educated guess on the code setting would be "zero" or "off".
Your radio dealer who supplied the RDM2070d radios to your corporation should be able to tell you the exact frequency and code; or read-out the radio.
Nov 03, 2009 | Motorola XTN Series Pro Two-Way Radio...
Polycom SoundPoint 550-Only Showing 1 line
On the phone, press the menu button, then status, then IP status or whatever and get the phone's IP address. Write the ip address down. On your computer, open up a web browser and input the phone's IP address into the address bar and press enter. This should arrive you at the web gui for that phone. It'll probably ask you for login credentials; by default, the name is "Polycom" (yes , it is case-sensetive) and the password is 456. Once you are logged in, you should see several links like "General" "Network" "Sip" and "Lines". click on Lines. under "line 1", you will see the configuration for that line. simply duplicate the entries for lines 2, 3, and 4.
Jul 29, 2009 | Polycom SoundPoint IP 550 IP Phone
Power outage and lost features
The Privacy is part of FP1. You need to pick a button with a light, put the T/P switch in P, touch the button, dial *72, and put the switch back in the center position.
If that doesn't work, try Auto Ans Intercom or Do Not Disturb under the same button (*70,*71). If you can't get any of the features to work, I'm guessing that the FP cartridge needs to be replaced or power down the system and remove and insert the cartridge again.
Carl
or
Apr 07, 2009 | AT&T ATT / Avaya / Lucent Merlin 820...
How would fax run on VOIP? what requirment it needs?
typically faxing doesn't work on VOIP. i tried many times and sometimes it would go through although it said it didn't. other times it didn't work at all. VOIP has a limited bandwidth and the fax needs to send more info over the line than VOIP makes room for.
to have the best luck, stop all downloads and other network traffic while attempting to fax, so that there are no other programs or devices using the internet. the fax will have its best chance of working that way, although it probably still won't
here are some very good tips as well:
http://chris.pirillo.com/how-to-fax-over-voip-on-the-internet/
Feb 18, 2009 | Lexmark X4270 All-In-One InkJet Printer
KX-T7730 Doesnt turn on
It requieres cabling. I'm guessing that the jack is wired only for digital phones. Put a single line set on the jack and see if it works.
The 77xx series requires 2 pairs to work, with the voice being carried in the center pins.
Carl
Aug 22, 2008 | Panasonic KX-T7730 Corded Phone
Cisco 7970G IP Phone Logo
172 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
