Question about Toshiba 27AF44 27" TV
Hi~Our toshiba 27af44 tv has white horizontal lines across the top 6" of the screen. It's been a constant problem only on this tv, not on our other one. The tv is almost 5 years old. Is it worth repairing or is it time to get a new one? Thanks in advance!
  • T.l. Moore
    T.l. Moore May 11, 2010
    hi you have some capacitors failing in the verticle circuit and will require replacement you would probably spend on125 or so to get the unit fixed at a shop in your area id guess and that can vary in your area if your still happy with the set then id say go for the repair if you have been looking then with the price wars going on now,s a good time to start looking hope this has helped
  • 273 Answers
You have some capacitors in the verticle circuit that are failing they would require replacement to correct this problem est 125 or so to repair
and probably still a worth while fix
but with the price wars for Holidays upon us you you may want to look and see what you can get with just a bit more money
i hopw this has helped
Posted on Nov 18, 2009
Testimonial: "thanks for your advice:) will most likely get a new LCD tv before the end of the year"
There are white thin horizontal lines across the top 2" of Toshiba 27DF47 TV. Can this be repaired and how much would this repair cost?
Check and replace all the electrolytic capacitors at its vertical output section circuit. There will be five or 6 of them. Replace all.
Mar 18, 2013 | Toshiba 27DF47 27" TV
Horzontal lines across top 2" of screen on both my Toshiba TVs?
it's NOT the "tubes" (the glass picture tube you view) this is 90% of the time a capacitor in the vertical circuitry. A good TV tech can find and fix this issue for probably a little less than $100 per set at the most.
Feb 10, 2009 | Toshiba 27AF44 27" TV
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Rca projection screen problem
I have a Toshiba 27D46 TV that comes on great.. but within 5 minutes goes black with a white line horizontal midway across the screen. Any fix solutions? HELP..!!! Chip
Jan 06, 2008 | Televison & Video
Horizontal lines across the top of the screen
it is a fault in one of the capacitors in the vertical part of the schematics it is 33uf -160 volts capacitor , dry out and need to replace refer to qualified , regards , plz don't forget to rate thx
May 02, 2007 | Toshiba 27A44 27" TV
Toshiba 27AF44 27" TV Logo
208 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
