Question about Daewoo Washing Machines
I bought a Daewoo washer and dryer set just over a year ago and we have replaced the pump on the washer already, the dryer takes longer to dry than my old one and the washer does not wash and never has washed well at all. Tonight the pump went for the second time and I would like to have either these machines replaced or money back so I can purchase something new. I am prepared to talk to the news as well as posting on every site available about this problem. Please get back to me by tomorrow.
  • donnakozensk
    donnakozensk Jul 21, 2012
    thank you i will NOT purchase it.....
The problem with the drain pump is that items get stuck in them. That is the reason for the filter which needs to be cleaned occasionally. It is a very easy job to remove the pump via the bottom of the machine and clean out the pump. I had a coin stuck in there and a toothpick. After cleaning out the pump the machine ran perfectly.
I like the machine, it does a good job and has a lot of neat settings.
Posted on Feb 12, 2010
My 4 year 0old front loader is no longer spinning dry the laundry. Was bought from Charllotte Appliances, Rochester NY
Hello & Welcome to FixYa
If you have already checked the drain pump filter (located inside the bottom front panel) and the drain hose for any blockages, then the problem is with the belt going bad, its either worn out or loose. To check what is bad you have to take it apart and then check the belt, if bad replace it. Please get back to me if you have any other questions.
Kevin
Jan 18, 2011 | Frigidaire ATF6000ES Front Load Washer
We bought our maytag washer/dryer in 2007. Washer does great, however our dryer is the problem. It seems to take longer to dry clothes, than any dryer that we have had, also the clothes "ball up", which...
are u sure the belt isnt sliping somtimes if u over load or have a lot of cloths in it that will ball up the cloths and haeting problem either the vent tube is stopping up or heating coil is going out
Oct 23, 2009 | Dryers
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
My dryer takes much longer to dry loads now
Hi!
You need to check the following things to sort out the issue you are facing with--
Improper sorting •Separate heavy items from lightweight items (generally, to dry a well-sorted washer load is a well-sorted dryer load).
Large loads of heavy fabrics •Large, heavy fabrics contain more moisture and take (like beach towels) longer to dry. Separate large, heavy fabrics into smaller loads to speed drying time.
Controls improperly set •Match control settings to the load you are drying.
Lint filter is full •Clean lint filter before every load.
Improper or obstructed ducting •Check installation instructions for proper ducting/venting.
•Make sure ducting is clean, free of kinks and unobstructed.
•Check to see if outside wall damper operates easily.
•Check the Installation Instructions to make sure the dryer venting is correct.
Blown fuses or tripped •Replace fuses or reset circuit breakers. Since most dryers circuit breaker use 2 fuses/breakers, make sure both are operating.
Overloading/combining loads •Do not put more than one washer load in the dryer at a time.
Underloading •If you are drying only one or two items, add a few items to ensure proper tumbling.
Thanks for using FixYa and do rate the solution as Fixya if found helpful.
Thanks
Rylee
Apr 03, 2009 | GE DVLR223 Dryers
Is fading and shrinking my clothes
low temperature and low rpm of motor,must try this.
Feb 16, 2009 | Frigidaire FTF2140F Front Load Washer
Kenmore dryer only heats on delicate
I am not familiar with this particular dryer but most of the Kenmore family use different thermostats for different temperature. They are usually located in the rear and are clustered on the blower housing. Take the two wires off one thermostat at a time and test. It should be closed when cold if not replace it (Usually around $15 each) You probably have a very dangerous clogged exhaust. This will cause thermostats to fail. and can cause a fire. CLEAN It out and dont use flexible plastic duct pipe. The other cause of thermostat failure is if the washer doesn't spin properly and the clothes are too wet when dried. A properly operating dryer will not take much longer than 45 minutes max to dry a load.
Jun 14, 2008 | Dryers
Front Load MAH2400AWW Washer
sounds like you have a short in control board on washer buy service smart agreement from sears it will cost a little and cover up to 500.00 or give you 500.00 towards replacement value, dryer if you have heat its your vent in wall not breathing well , it will cause long dry times
Feb 13, 2008 | Maytag MAH2400A Front Load Washer
Washing Machines Logo
1,807 people viewed this question
Top Daewoo Washing Machines Experts
dweatherby
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
