Question about Sony Ericsson Z530i Cellular Phone
I've got my z 530i screen broken, and i need to save all my contacts number which were saved in my phone memory thanks
Sim card used in samsung phone (contacts saved to sim) when transferred to nokia c5 it doesnt show any contacts. I've tried in another nokia and its fine
You have to set the memory of your current phone, change it to sim memory so that you can retrieve the number save in your sim.
Jul 05, 2011 | Nokia C5 Cell Phone
NOT DISPLAYING CONTACT NAME AND NUMBER DURING INCOMING CALLS on nokia 1600, it is showing no number on screen. can you guide me how to resolve this problem?
If there's no software related issue, this must be problem with contacts. When a contact is saved multiple times, this happens. Check the specific number that's displayed only numbers and make sure you have only one saved contact with that number. This is usual when the same contact is saved on both the sim card and on the phone memory. In other words, duplicate contacts. Once one of the contact is deleted, you'll have no more problem.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 23, 2011 | Nokia 1600 Cellular Phone
The screen is broken on my lg viewty and i bought a new phone but my contacts are saved on the phone memory and i cant get them onto my computer
The phone numbers are generally stored in your phone or in your simcard and not in the memory card. Did you have it saved defaulted to your simcard? If you didnt then it will not trasfer over.
Oct 25, 2010 | LG KU990 Viewty
Dear Sir, I am using Samsung SJ700 mobile phone.And sometimes I get incoming call with no number displayed on the screen. It just shows incoming call. Can you pls help me in sorting out this...
This happens when two or more similar (saving one number with different names) contacts is saved on your phonebook, i.e. if you've saved my number on the sim card with a name and at the same time you have my number (same number) on your phone's memory, the caller id will not be displayed, you'll only see the "Incoming Call" or "Call". So I would suggest you to please check the phonebook and delete (keep only one per number) if there are multiple similar contacts saved on your phonebook.
You can also reset the phone to Factory default, in case there's no problem with your phonebook/contacts.
Good luck.
Aug 14, 2010 | Samsung Cell Phones
All my contacts saved on phone memory was gone. and every time i move a contact from sim to phone, it got lost. even if the numbers were saved on sim inbox messages can't recognize the numbers. please...
Its easier if you just save your contacts on your SIM card that way whenever you transfer your sim card to a different phone your contacts will be on the new phone.
Jun 11, 2010 | Nokia 5310 Cellular Phone
I can not see anything in my phone. I want to take my all phone numbers its important. how can i solve this problem?
use appropriate software to take a back up....fa exampl if ur nokia user use nokia pc suit and access ur mobile with PC......ve a back up...... if ur mobile is jus a basic model then i guess there are no chances!!!! thank u!!! hope this helps!!!!!
Oct 12, 2009 | Cell Phones
Broken screen and save contact to SIM card
u can do 1 thing connect ur mobile wit computer load SE pc suit then all ur mobile data can be saved into ur computer also phonebook
Aug 18, 2009 | Sony Ericsson K750i Cellular Phone
Nokia E71 - Saving new contact
check your phone memory limit may be it is full.
if it is still empty u need to reset all settingms of your cell phone to factory defaults.
Go to setttings then reset your celll phone.
but i think your cellular limit is over for save new contact check it .
Apr 05, 2009 | Nokia Cell Phones
Sony ericsson k800i blank screen need to transfer numbers from phone memory to sim card
Thats a cool phone, pity its screen is broken.... Here is my suggestion
  • If you got keypad lock then unlock the phone
  • Go to menu usually by pressing the top right key...
  • Press 8, which should take you to contacts
  • Press the top right key which would take you to More
  • Press up using the joystick, this should highlight Options
  • Then press the middle of joystick, which would take you into options
  • Press up using the joystick again, this should highlight Advanced
  • Press 5 to backup the contacts to memory card or press 8 to back up your contacts to SIM
Check the memory card or Sim on another phone...
May 10, 2008 | Sony Ericsson K800i Cellular Phone
Sony Ericsson Z530i Cellular Phone Logo
63 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
