Question about NetGear RangeMax WPN824 Router
My router resets and all the lights come on and it's no longer connected, I have to unplug it and it connects again but only for about 20 min then all the lights come on again and the connection drops
  • 481 Answers
Check the other end of the power cord to make sure it isn't loose. Check to make sure your wall plug isn't intermittent or attached to a light switch elsewhere in the room. Otherwise, I'd say it's time for a new router.
Posted on Nov 18, 2009
Blinking lights
when the router looses connection, it is best to just leave it as it tries to reconnect automatically
the blinking lights is the communication process and when connection is made for each section the light stays full on
there should be a on/off button that you just press to restart the searching process or a reset button under a small hole that you use a paper clip to gently press to reset
remember that it is not always the router that looses the connection but the server that it is connecting to
Jul 10, 2017 | Cisco -Valet Wireless Router
-Unable to access the router's webpage. -The router is 'trying' connect to modem (modem light flashing, internet light off) despite the fact it's already connected.
Have to unplug router and modem to reset both for approx. 2 min. Then plug in modem first let that reset and all lights come back on (except router light) then when that has finished booting do the same with the router. It should work.
Oct 14, 2010 | Belkin F5D7234-4 Router
My belkins wireless light wont come on anymore?
* try connecting ur belkin router to different power socket * try with different power adapter * or else press the reset key for more than 1 min while holding the reset unplug the router power cable and plug it back again 3 times.--- while holding the reset u shouldnt release the reset while u unplug and replug. the interval between each unplug and replug should be 15 seconds. * then release the reset then unplug the power cable and plug it back * it has to work or else replace it with the belkin tech support
Nov 15, 2009 | Belkin (F5D72304F5D7000) Router
My WGT624 v3 has no power, seems dead
Yup, I have seen those die that way sometimes. Put a voltmeter on the power supply to check (or take it to Radio-Shack) but it is probbaly the router itself
JOAT
Oct 16, 2009 | NetGear WGT624 Wireless Router
NEtgear RP614 cannot connect after a electricity shortage in our home :(
Reset the router to factory default. Usually done by unplugging the router hold in the reset button and plug in the router wait 30 sec. release reset button Wait 30 more sec. and unplug router again. Then reset your computer to obtain ip address automatically in network properties. Next shut down your computer, router and modem. First re-power the modem, give it time to boot (about 2 to 3 Min. for Cable and dsl or 7 to 10 min for satellite), next re-power the router, again give it time to acquire it's info (about 2 min.) then start your computer and try to access the Internet, all should be well...
Good luck, and have a great day...
Tim
Mar 23, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Wont connect to internet
You need to reset the router if the lights are flashing. Press the reset button at the back of the router for about 20 seconds then release it. Now unplug the power for 20 mins as well and plug it back in. Make sure your connection is right. PC connected to port 1 and modem to WAN or Internet port.
Dec 17, 2008 | NetGear WGR614 Router
Connection of internet
Try to power cycle the router and modem. Unplug the power of the router and modem for 30 seconds. After that power on modem first, wait for the lights to go steady then power on the router. If all the lights are solid, try to check if you can connect wireless
You can also try to reset the router. Look for RESET button at the back of your router and press it for 20 seconds, then unplug the power of the router for another 20 seconds then power it back on. Check if you can connect wireless
Aug 25, 2008 | SMC Barricade g SMC2804WBR Wireless Router
Di-624 stopped working
Hi sailaway!
. Make sure the router is going from the modem, to the port marked WAN, on the 624. You can test the cable, by plugging it directly into you computer, from the modem, if you want to. Disconnect the power from your modem, your router, and turn off your computer Wait 1 min. Turn on the Router, wait three full min's. Power up the 624, and wait one min. Power up the PC. Reason for the long wait on the modem is that it has to get data from the internet, to give to the router. If that don't hwlp, try changing the cable from the PC to the router, to a different port. If all that don't work, try resetting the router by gentley pressing a straightened out paperclip into the reset hole in the back. Hold it for 30 sec. If that fail resetting it, try holding it in while you unplug the 624 and plug it back in. If it resets, go thru the first steps to set it up again. If all that fails, your 624 may be bad. Had that happen to me. The steps I listed brought it back to life for about 2 months, and it died completely. Good Luck!
Jan 05, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
2Wire Router will not power up.
If it is not getting any power at all,
only one of three things:
cord is fried/dead;
could be the outlet,
try something else in the same socket; or, the board in the ROUTER is dead.
Disconnect power cable WAIT FOR 20 sec and then reconnect it..Reset your router, ..To reset the router, the best way is to press and hold the reset button for 30 seconds, or to press the reset button for 60 seconds..and for first 20 sec hold the reset with the power cable connected and for the next 20 sec with out releasing the reset button disconnect the power cable and continue holding the restet button , and after 20 sec reconnect power back and then continue holding the reset for another 20 sec.. and then ncheck for the lights status ..
Try another power cord. Take it back to the store and have them exchange it or test it. They'll do that for free.
Dec 07, 2007 | 2wire (1000-400108-001) Router
On and off line every 20 flashes.
Have you attempted to connect the internet after the router stops flashing? Do the lights start flashing again? If you do, then it would be considered normal.
If they don't and you do not have an internet connection, try the next step.
Next, plug your computer straight into the modem - Do you have an internet connection now? If you do, your router may require configuration.
Nov 10, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
NetGear RangeMax WPN824 Router Logo
62 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
