My car just cut out took to vw said it yas number 2 injector £500 later and 2 days same again now its number 1 lay say help?
  • 373 Answers
Replace the fuel filter first. then have the fuel pressure checked and the fuel pressure regulator tested.
Posted on Nov 18, 2009
2002 VW citi golf 1.4i cutting out
Don't shoot me. But this is an old problem. The old polos did the same. I used to drive. Then It would just cut out. Leave it standing for around 20minutes. Start it again. And it runs like there were never a problem. Solution.fuel pump relay. Out of my own experience
Feb 06, 2017 | Cars & Trucks
Just got my 2000 VW New Beetle with 3/4 tank of gas. Drove it 36 miles and its below 1/2 tank. Could it be the gas that they put in? Or something wrong with the car itself?
On just about every vehicle I have ever seen, the fuel gauge will move faster from 1/2 to 1/4 (I never let a tank run past 1/4. Bad for the fuel pump) than from full to 3/4 or 3/4 to 1/2.
Do a mileage check. Fill the tank until the pump stops, reset your trip or note your odometer miles. Dive a few days or a number of miles. Fill the tank again until the pump stops and not the amont it took to fill. Note the number of miles you put on and do the math.
Aug 27, 2011 | 2000 Volkswagen Beetle
My vehicle stopped dead at set of lights and would not start, called RACQ he installed new battery $165 Stated that was problem, drove less than 1/2 kilometre down road, felt the vehicle ****. Continued...
Sounds like you have a fuel issue. It could be a fuel pump cutting in and out. It could be fuel pressure regulator, or an injector not spraying correct. I think it's time to find an honest educated repairman.
Mar 02, 2011 | 2001 Hyundai XG300
99 vw diesel new beetle. NOT STARTING
You need to get your injectors checked.
Mar 09, 2010 | 2000 Volkswagen Beetle
Went through a puddle. Car died. Restarted a day
See these items:-
The starter must have been bad due to the water.
Bad PCM or ignition coil.
Corroded battery cables.
See timing belt.
Good luck
Feb 28, 2010 | 1997 Volkswagen Jetta
I have a 2002 VW POLO 1.2 The engine management light came on and the car started to ?shake? on start up until some revs were applied and then returned to normal. Took it in to the garage and they said...
i also have a 2002 VW Polo 1.2, which I bought in January this year. The first time i drove it the engine management light came on. I took it to a garage and they changed a sensor in the exhaust system at a cost of £350. I drove the car again the following week and the light came on again, I took it to the same garage and they told me it was unrelated and that i needed another £300 repair. Refusing this I took the car to my parents mechanic who told me that these lights are prone to coming at the slightest little thing and to ignore it if the car is driving fine and sounds normal. He said that if there was a genuine problem that you wouldn't need the light to tell you but that the problem would be obvious through the sound it made or by the way the car started to drive. He said he felt the sensors were over sensitive and were there largely to encourage owners to take their cars into the garage for expensive repairs which didn't need doing.
He told me to drive the car as normal and ignore the light. He said only take it to a garage if there is an obvious problem, otherwise I was wasting my time and money.
I now drive the car without worrying abou the light and so far I haven't had any problems.
Suggest you do the same.
May 15, 2009 | 1997 Volkswagen Jetta
2006 vw jettA 2.5....trouble starting
I had to take my car back to the dealership twice. First, they replaced the ignition switch. 3 days later, my car wouldn't start again. So I took it back and they called VW - VW said to replace the steering column module. I asked my dealer why they didn't replace the steering colum module first - they said that even if they had replaced that first, the old ignition switch would have shorted out the steering column module. Whatever.
$600 later my car has been fine for about 3 weeks now. If it happens again I will keep you posted.
Mar 17, 2009 | 2006 Volkswagen Jetta
Engine will not start
go with the mechanic he knows what hes talking about
Oct 28, 2008 | 1996 Volkswagen Golf
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
