Question about Kenmore 72802 Gas Dryer
A little heat then nothing
Dryer runs well will heat up for one time only then seams to never heat up again? takes clothes 2 - 3 hrs to dry. there is 4 sensors in the back. i have tested with ohm meter and they all ohm out but one, it is the Thermostat, internal bias it has 4 connectors on it one set ohms out the other doesn't.
is this the problem?
  • 1 more comment
  • jimndawn_1 Jan 11, 2008
    Ok i replaced the cycle thermostat that is the item that has the 4 connectors, after doing some research on the problem i have watched the dryer for a short amount of time,
    1 turn dryer on.
    2 ignighter lites up
    3 flame burning
    4 flame goes out
    5 after some time ignighter lights up again
    6 no flame
    7 about 30 seconds later ignighter lights up, and no flame
    so i think it may be the gas valve coil. i'll let you know
  • jimndawn_1 Jan 18, 2008
    Coils it was.
  • coriefehsenf Sep 28, 2008
    just what the guy said - a little heat then nothing.
  • 88 Answers
Yeah...that's coils 99% of the time.
Posted on Jan 17, 2008
I have a lg dryer that will not dry things all the way before shuting off. I sometimes have to run it 2 or 3 times
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Dryers
Sometimes dryer will heat right, next time it won't
You more than likely have a buildup of lint in the vent hose. Even what looks like not much lint in there can cause the dryer to have issues drying the clothes. Clear the hose out really well, take it outside and shake it all out, then hook it back up and give it a shot. If that doesnt work you may have a bad thermal fuse which regulates the dryer temperature and you will need to have it replaced.
Dec 14, 2009 | Whirlpool Dryers
Front load MDE2400AZW takes forever to dry stuff. A regular load takes 1 1/2 hrs to dry,but the heat is on, and it seems to work.
Make sure the lint trap in the door is clean. It has a plastic cover that opens. Disconnect the venting at the rear and run a load, if it works you have a restriction in the hose after the dryer or in the wall past the hose.
Dec 01, 2009 | Maytag MDE2400AYW Neptune Electric Dryer
Dryer heats up but takes 2 hrs to dry clothes
If the dryer takes so long to dry 1 elimet mit be burned out, tick the drom out and you'll see 2 springs 1 mite be burnet.
Oct 16, 2009 | Whirlpool LER5636P Electric Dryer
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 | Dryers
LGE59777S Not drying
There is a little sensor that tells the dryer when to heat and when not to heat. that sensor is bad. If you take the back of the dryer off you will see it. It is about the size of a half dollar and has 2 wires that plug into it. While you have it apart make sure that the dryer vent on the back of the dryer is not plugged with lint. Major cause for fires in dryers.
Jan 04, 2009 | LG DLE5977 Electric Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Long drying time
Did you find what it was?
Mar 12, 2008 | Dryers
Kenmore 72802 Gas Dryer Logo
70 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
