Question about AT&T 5840 5.8GHz Speakerphone/Answering/Caller ID Answering Machine
AT&T 5840 5.8GHz
Why is my phone flasing all the time and it shows extension in use, and I can't make a call
  • 4 more comments
  • flaca777 Jan 10, 2008
    AT&T 5840 5.8GHz
  • Anonymous May 26, 2008
    the phone light flashes and the message says extension in use. I can't get a dial tone or make a call out.
  • dmc568 Jul 02, 2008
    Phone system is flashing (right back corner) and phone extension is showing Extension In Use. No dial tone, no service. When caller calls in - it reads on their phone that Line is in Use.
    Please provide feedback ASAP.
  • pjwelch Jul 10, 2008
    Phone is flashing saying another extension is in use, please help.
  • q0rban Jul 28, 2008
    I have the same phone, and the same problem. I'm using VOIP and found
    that if I plug the 5840 base directly in to my VOIP unit, the phone works,
    however if it is plugged into any one of my jacks, it displays "Extension in Use" and the line is dead. Other phones work fine on all my jacks...
  • Anonymous Sep 04, 2008
    I have the same problem, please HEEEEEEEEEEEEEEEEEEELP!
  • 47 Answers
You have a voice mail message
Posted on May 11, 2008
2 Suggested Answers
  • 13433 Answers
SOURCE: AT&T 5840 5.8GHz
try reseting the phone by unpluging it and also removeing the batterys. Il check the manual.
Posted on Aug 23, 2008
Phone line doesn't ring
First, lets get rid of the static. Try Feature #86. This will turn off background music. When a music source is not attached you get static.
Enter programming by using Feature XXX66344 password 266344. The display should show "Terminals&Sets" press the top right button with an indicator in the display. The display should show "Show set: ____ enter the extension number that you want to check or program. The display will show ***:name. Press the top right button three times. The display will show Show Line:____ with options to Scan or List. If you select Scan it will show the lines assigned to that phone. If you select List it will start with the first line in your phone system showing one of four states 1- Unassigned, 2- Ring Only, 3- Appear&Ring, 4- Appear only. Change the selection on the line by using the CHNG soft button. This is where line assignments are changed from the four states for each extension.
The only other thing that will keep an extension from ringing is "Do Not Disturb" or DND. Feature 85 and #85 will turn this feature on and Off.
Jan 31, 2014 | NorStar Meridian M7310 Phone
AT&T 5840 5.8GHz
Aug 23, 2008 | AT&T 5840 5.8GHz...
Phone not ringing in normal mode
I believe this is a programming issue.
To change the ringing assignments on extensions enter programming mode by pressing Feature **266344 and password 266344 if it hasn't been changed. You have to do this from an M7310 phone. The top two buttons on each side will move you through programming. The top right button is the SHOW button and the button below it is the NEXT button. The top left button is the HEADER button and the button below it is the BACK button.
Your first category should be TERMINALS & SETS. Press the SHOW button and using the dial pad enter the extension number. The display should show the extension number or name. Press SHOW three times and the display should show LINE ___.
With options to SCAN or LIST. Pressing SCAN will show the lines assigned to the extension. Use the CHNG option to change how the line is on the phone. RING ONLY - UNASSIGNED - APPEAR ONLY - AND APPEAR & RING. Change the lines you want to ring in NORMAL DAY MODE to APPEAR & RING for this extension and press SCAN to move to the next assigned line. Use this same method for any extension you want to change the ringing on.
Dec 18, 2013 | NorStar M7310 Corded Phone
I am also trying to change the extension names but for some reason when I press program the only thing that shows up is "Program No?" what do i do next?
Start by pressing ** and see what the display shows. If it doesn't show anything but beeps, then you have the wrong phone. Try looking for extension 101 or the first phone in the system.
When you find that phone and press program **1234, you'll go into programming. Dial 004 and press ENTER. If you press ENTER again, you'll be looking at extension 101, or you can dial an extension and be looking at a name. Now you spell out the name on the keypad using the letters and the arrow key if necessary and press ENTER (the center of the Navigator button) to store the name. Notice that the 4th time you press a 3 letter ALPHA key, you will get lower case letters. Punctuation is under the 1, * and # keys and Q appears under the 1 and 7 keys :-)
Next steps you to the next extension and you can just pick up the handset and set it back down to end programming.
Carl
Oct 26, 2010 | Panasonic KX-T7633 Corded Phone
W 880i insert correct sim card
may be ur sim ic is damage for sort circut. plz go to tacnician
Jul 18, 2009 | Sony Ericsson Walkman® W880i Cellular...
WE HAVE RCA EXECUTIVE SERIES PHONES INTERCOM LIGHT FLASING
RCA Executive Series Phone: How do you place the caller on hold and then intercom to another, then transfer?
Mar 17, 2009 | Lands Phones
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
HOLD BUTTON FLASING, MSG ON LCD SCREEN
Try press ICM button # 3 and the ext number of that phone
Jan 31, 2008 | Comdial Digitech 7700S-PG Corded Phone
My USB flase
problem is not with your player but with your computer
do these steps to avoid problem :-
1) open note pad
2) type following into it
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies]
"WriteProtect"=dword:00000000
3) save it as .reg extension
4) make sure extension of file is .reg ( once it in done then note pad icon will change)
5) double click on this icon
this should solve your problem
Jan 05, 2008 | iLO (2 GB) MP3 Player
Extension Name
so,first find out what is the port of this 106. by go to 106.it has to be a display phone.press feature then 4. it probably show 106 tel 07. so your ext port is 07. go to any display phone. press feature #0*8974.show program mode.now press line 4 then number 18.show 01/18. name of ext.now you press **** 4 times then press 07.show 07/18 sta name.now you can use the key pad to enter mat.press hold to deleted any digit.agter you done press TRF then speaker to exit. good luck.
Sep 20, 2007 | NEC DTU 8-1 Corded Phone
AT&T 5840 5.8GHz Speakerphone/Answering/Caller ID Answering Machine Logo
152 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
