Question about HTC PCMICROSTORE Brand Mogul XV6800 PPC6800 P4000 Solid Magenta Snap-On Case Cover with Removable Swivel Belt Clip
My touch screen is not working properly. it does not recognize any stylus touches on the screen.
  • mkendell Nov 18, 2009
    Where do I find the LCD strip? The screen itself seems to be working fine minus the ability to recognize stylus touches.
  • 42 Answers
SOURCE: htc touch screen is not working
Can you see any cracks in the touch screen?
You can have it replaced without replacing the whole screen which is quite expensive
Posted on Jan 08, 2009
SOURCE: Touch screen not working...
Hi guys,
i post this solution for those wo will be in the same situation in th next future. I had the same problem with my HTC TyTN (Herm 200). The touch-screen was simply not working. I read many 'solutions' on the net but none worked. I did not try the hard-reset because i was convinced this is not a software problem, and resetting the WM5 will not help. So i brushed the corners, looked for small particles which were pressing on the cover of the touch screen. but it did not work. finally i found one post (i don't remember where exactly) where a guy used a credit card and pushed it all around the touch-screen under the metal case (a bit harder). i tried it and it worked. i pressed harder especially in the lower part, above the buttons. and simply it worked ! no problem since then.
Posted on Jan 25, 2009
SOURCE: touch on touch screen phone not working
Hi, I have the HTC touch from bell. I too had the same problem with my screen. It stopped working completely. The phone is pretty much useless without the touch screen working, there is only 3 buttons on the phone! Can't even dial 911... So I was pretty pissed when the screen stopped working. Like others I searched the internet for answers and didn't really find too much. I found that maybe tapping the four corners of the screen firmly might work, but it didn't. Taking the protective cover off the screen might work, didn't work. I tried updating the ROM, using the official software from HTC website. I was able to update my phone, but my touch screen still didn't work. Someone said something about some copper connections inside the phone, need to be re-adjusted behind the screen or something like that. So I willing opened the phone (only 4 hex screws on the back) and took the front plastic cover off. If you look closely, you'll see the front cover is plugged into the 'motherboard' and you can simply unplug it. I unplug it and plug it back in, do a restart of the phone (take battery out and back in) and still nothing, screen doesn't work.
I noticed that on the front cover of the phone (underneath) you can see the copper band of wires that connect to the buttons and probably feeds the information from the touch screen to the 'computer'. I accidentally unplugged the wire (thought I broke it) but was able to insert it back in. I put the the cover back on, put the battery in, power up phone, BINGO! Touch screen works! What I did to make it work? Not sure...
But for people with the same problem. Try this:
1) update ROM
http://www.htc.com/us/SupportDownload.aspx?p_id=70&cat=2&dl_id=98
2) Unplug and plug back in that little wire.
http://img81.imageshack.us/img81/1912/htctouchx.jpg
Its the red circle I'm talking about.
Posted on Jul 18, 2009
SOURCE: my touch screen on my htc touch HD is not working
how can i do that if my touch screen isn't working ...i can't start my phone...:( what can i do?
Posted on Apr 11, 2010
SOURCE: Ihave a touch diamond 2 and the touch screen wont
TOUCH SCREEN
the touch screen of the phone you are using is weak and it is not responding properly again.
in other to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take car
Posted on Jun 24, 2010
Touch screen gives wrong letters when touched
Hi, Try using something like a stylus to type in the letters. I've found with gps' that the touch screens aren't that accurate and almost all fingers are too big to properly type in anything and since a stylus (or even a stick) is much smaller it should be more accurate.
Jun 22, 2011 | Tomtom GPS
Its saying calibration problem on the screen
When the Reader device is started for the first time or is reset back to factory settings, the screen must be calibrated. The Reader device will display a calibration screen that requires you to touch the stylus to the center of an "X" at several points on the screen. This is to make sure the touch screen properly recognizes input.
The process requires you to touch the "X" in the following locations on the screen:
  • Top left
  • Bottom right
  • Top right
  • Center
If the screen is accidentally touched someplace other than the center of the "X" during calibration, the Reader device will display a message stating Calibration error detected. Please restart calibration process .
If this happens, please start again in the top left corner and touch the stylus to the center of each "X" as it is displayed, being careful not to touch any other part of the screen. After the sequence is completed the Reader device will display Touch Panel calibration completed . Click OK to continue to the next step in the setup process.
Dec 26, 2010 | Sony Reader Touch PRS-600
Hi, I have a Casio Classpad 330 and I have problem with my touch screen. There is nothing happened when i tapping on the screen, but the keyboard is working properly. It seems it is damaged or corrupted....
I can give you the following suggestion.
The touchscreen will recognize your
stylus tapping if you simultaneously
have any of the keyboard buttons pressed (except 'Clear').
Once you see the whole menu (after screen
calibration and brightness settings) press
Clear than Exe than Clear and the screen
should be touch sensitive again.
Hope this helps.
Sep 08, 2010 | Casio ClassPad 300 Calculator
Touch screen not precise/not working properly
ttry calabraiting the screen that may help a little i think it will be under pref
Mar 26, 2009 | Palm TX Handheld
Leapster not recognizing the pen??
Press the ? button and hold it while turning unit on.
Press the "a" button to select touch calibration
Press each + with the stylus
Restart machine
Nov 25, 2008 | LeapFrog Leapster Electronic Book:...
PPC 6700 Touch Screen Sensitivity Changed
Realigning your screen might fix your problem. Settings -> System-> Screen > align screen.
I hope this helps
C
Dec 14, 2007 | Audiovox PPC 6700
there is a problem with dust and dirt getting between the casing and touch screen. get an old toothbrush an give it a brush all the way around that should cure it
May 17, 2007 | Nintendo DS Console
Calibration of my MobilePro off
We've put together some useful tips on calibrating your MobilePro * When calibrating your touch screen be sure to use the same amount of pressure that you apply during normal use. In general, the lighter the better. This allows the screen to recognize taps consistently. * When calibrating your touch screen hold the stylus over the calibration point until it moves to the next point. Holding it for this period will lead to greater accuracy than just tapping the spot quickly. * When calibrating your touch screen support the screen from the back with your other hand. Try not to grasp the screen from the side with your thumb on the front. * When calibrating your touch screen do not let anything other that the stylus accidentally touch the screen. For example, don't rest part of your hand on the screen to help steady the stylus. * Once you've completed the stylus calibration, be sure to perform the double tap calibration as well. This will ensure greater accuracy.
Sep 14, 2005 | NEC MobilePro 900 Handheld
HTC PCMICROSTORE Brand  Mogul XV6800 PPC6800 P4000 Solid Magenta Snap-On Case Cover with Removable Swivel Belt Clip Logo
162 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
