Question about Toshiba Satellite A60 Notebook
Toshiba laptop s155 model is showing a ide 1 and 2 error had to remove the cdrom due to failure but still wont boot and harddrive is not showing up at all in bios but it was working ok untill the cd rom went out is their any fix besides a new harddrive Best regards michael
mitch_3020
  • 67 Answers
SOURCE: Toshiba Satellite laptop boots up but shuts down on its own very shortly
Hi JOJO0803,
Based from the error message you're getting it sounds to me that your problem there is not software related but is more hardware in nature.Since you're getting a message "disk read error occurred IDE#0" this pertains to a problem with the hard drive itself. It's possible that your hard drive developed bad sectors or errors on the disc itself.
So to be sure I would recommend that you run the hardware diagnostics for your laptop computer especially the one for the hard drive since you're getting this message. If the hard drive fails the test or any other part fails in the test, contact your techsupport and ask for replacement parts if your PC is still under warranty. Otherwise you may have to buy parts for your laptop.
If the hard drive tests passed and all the other hardware tests also passed then you may proceed to troubeshoot the software using the Windows XP Home CD. Boot from the WinXP Home CD, and you get to the setup screen, choose "R" for recovery console and then on the prompt type "CHKDSK /R" let it run, it may take a while. afterwards it will bring you back to the prompt then type EXIT and it will reboot the system, see if that fixes the problem. Worst case scenario you may have to format then reinstall Windows XP again to fix this problem.
Hope this helps!
Peace! :)
Posted on Oct 23, 2008
  • 73 Answers
SOURCE: Toshiba latop 0201 #ide problem
IDE #0 is your primary hard drive.
Toshiba's System Errors indicate that the error 0201 Failure IDE #0 may be caused by bad contact points where the drive plugs into the laptop chassis. Toshiba recommends pulling the hard drive in and out several times to clean up the male/female contact points.
Toshiba also said that if this doesn't work to contact one of their service centers for assistance.
The contact points solution rarely works, but is worth a try. Most likely, your hard drive failed and needs to be replaced.
Posted on Feb 08, 2009
  • 7 Answers
SOURCE: error 0203 failure IDE #2
1) like always with anything that you do when taking your computer apart, take out the battery and unplug it (common sense)
2) Remove the plastic cover piece above the keyboard, called the "keyboard bezel". this is the piece where you can see the speakers. This page gives several pictures as to how to do this. http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-main...
**I found it a little bit difficult to get the plastic retaining clips to "pop" loose, but if you are careful, you can use a small screw driver and slowly "wiggle-pry" between the two screen mounts. this is done with the screen all the way back. you could use a paper clip with a little 1/8" bend at tip to do this also. (it is a tight working area) Once these three retaining clips have come loose the others are fairly easy to "pop" Just be patient and work it slowly. once this is bezel is off the rest is super easy.**
3) Remove the keyboard. Remove the two screws that are evident once the bezel has been removed. These hold the keyboard in place. Lift the keyboard up from the screw side and the retaining clips at the front of the keyboard will lift out. (there is no need to pry here). Once the keyboard is loose you will have to either leave it connected, just off to the side, or disconnect it from the mother board. The keyboard cable connector has a black clip along the top of it. just lift this clip up a little and the keyboard cable will slide out. (the keyboard cable does not have a fixed connector, but is just a ribbon that is held in place by the black clip along the top of the keyboard cable connector) Once you have removed it you will better understand what I mean.
4) Remove the wireless card. It is the only card visible at this point. It is connected by metal spring clips. just unclip in a similar fashion as removing ram. You do not need to disconnect the wires connected to card, just move card over to expose area below card.
5) This is where the magic is... you will see C88 clearly labeled right next the jack that the wireless card plugs into. There are two little solder squares (approx 1/16") at this location. *** At this point plug the power adapter to your computer again. ***
You will have to jump the two solder squares at label C88. I used a paper clip to do this. I used pliers to bend a 1/8" long "L" and then "scuffed" up the paperclip with the teeth of the pliers. (my first try at this did not work because the paperclip had a varnish coating on it and did not adequately conduct electricity.) Once you have your paperclip set up (or the one you used to pry the bezel with) hold it in place on these two solder contact squares and press the power button to boot your computer.
6) Your computer should boot right up and bypass the bios password, which is now reset/ erased. (You might see the Windows Error startup screen that gives you different options of start up to choose. If you disconnected your keyboard, just wait for screen to time-out and it will continue on its own) Once you have booted into windows use your mouse pad to shutdown, via start-shutdown method.
7) Disconnect your power. Reinstall your wireless card and keyboard (with screws). Don't reinstall keyboard bezel at this time. Once everything (but bezel) is reinstalled, restart the computer with battery and AC adapter connected. This should boot right into your computer without any trouble. (if for some reason it does not boot up correctly and asks for the bios password again you will be glad you left the bezel off. just redo the steps again.)
Posted on Apr 06, 2009
efs_perpends
  • 1996 Answers
SOURCE: Toshiba Satelite M35-456 Error 0201 Failure IDE #0
Here is the Toshiba official line on that error.
If you've already run through their fixes, you could try using the Ultimate Boot CD to test the hard drive, or run Chkdsk c: /r from the recovery console to attempt to recover any bad sectors
Then consult this link and apply the pertinent fixes to attempt to repair the MBR.
Other possibly helpful links here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 17, 2009
  • 10406 Answers
SOURCE: Hi I have a Toshiba Tecra M2 laptop with Windows
>> it says IDE #1 error when it boots up.
IDE #0 is your disk-drive.
IDE #1 is your CD/DVD drive.
So, take your computer to a qualified technician, to first check that the connectors (power, data) from the motherboard to the CD/DVD drive are good, and then, if necessary, to remove & replace the "dead" drive.
Posted on Oct 27, 2009
Hi im getting the pxe-e61 media test failure check cable for a toshiba a350 i have gone into the bios and disabled the lan and put my hdd is slot 1 followed my my cdrom i bought a new harddrive but...
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty.Thenthe hard drive needs to be replaced in the computer/laptop, Windows installedand the computer or laptop's device drivers plus your programs etc. to get afunctioning computer/laptop again.
Aug 03, 2011 | Toshiba Satellite A35-S159 Notebook
When I turn on my acer aspire one d250 it says Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any...
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery which will erase all user data and restore the operating system to its factory default when you purchased the netbook.
Jan 03, 2011 | Acer Aspire One D250 (99802378332) Netbook
Hi I have a Toshiba Tecra M2 laptop with Windows XP Pro SP3. My CD-RW/DVD-ROM/CD-ROM drive is not working. When I try to burn a disc, it says no recorder, or no disc in drive. Also, Windows doesn't seem to...
Oct 27, 2009 | Toshiba Tecra M2 Notebook
Wont recognise disk drive ide error
What you need to do is edit the BIOS so that the computer boots from the CD-ROM initially rather then the harddrive.
To do this follow these instructions:
1. Start the computer and tap the F2 key
2. You will now be in the computer BIOS, look for the option that says "Boot Sequence"
3. Highlight the option that shows your CD-ROM device and tap the "F5" key until it is the first one on the list
4. Hit the "Escape" key and select the option to "Exit & Save Changes".
If you restart your computer it should now boot from the CD-ROM. If you have any problems let me know and I will be more then happy to help you further troubleshoot!
May 05, 2009 | Computers & Internet
Will not boot,bios does not show a hard drive,only two CD drives
The peripheral devices as Hard disk and cdrom is not connected with the IDE cable or has loose contace. Even power cable of devices is not properly done or left out. So you need to check the IO IDE cable connetions and the power cable connections of the devices being connected to the mother board.
Mar 30, 2009 | Intel D865GBF Motherboard
Feb 08, 2009 | Toshiba Satellite M30X Notebook
Toshiba
welcome to fixya
In the bios, set the NIC entry to "ON (PXE off)" and remove the option of PXE boot from the boot sequence. Make sure all IDE devices are set to cable select (hard drives, CDROM, CD-RW etc) and that only those devices you have present are set to AUTO in the bios.
this should fix the problem have a good day
Jul 13, 2008 | Toshiba Satellite A135-S2386 Notebook
PXE-E61 Media Test Failure PXE-M0F Exiting PXE ROM
the laptop not recognizing the boot devices except the network boot that it found but there was no connection so it exit the pxe rom. first you need to open up the laptop and see what is running around inside maybe metal and your in for trouble if its metal maybe screw or so. second and this will hurt but you may need a new motherboard.but first lets get the object out.metal or plastic so you'll need to pull down the laptop and take the cmos battery out for abit .put the laptop back together replace the cmos battery leave out the hard drive and the optical drive (cdrom,dvdrom) then turn the laptop on wait for it to boot then turn off. replace cdrom with bootable cd inside restart. if it boots your in luck.turn off replace hard drive and restart. If all goes well and your able to boot to hard do this first download the bios flash for you laptop at toshiba site only at toshiba site and only your specific laptop model. read the readme file that come attached follow the instructions. then you can do you upgrade that you wanted to do all along
Jul 02, 2008 | Acer Aspire 5100 Notebook
Toshiba PSA60L-004003
1. Try removing the memory
2. Try removing the hdd (try to use another ide drive)
3. try removing the cdrom
In that order try to remove them clean them, or use a spare, and see if the error pops up again.
Apr 09, 2008 | Toshiba Satellite A60 Notebook
Media test failure
Do you have the PXE error?
The media failure is in the boot sequence, on the toshiba press F12 on boot to change boot priority, select cd/dvd or hard drive, or to preclude from happening, press F2 on boot enter BIOS, select Boot options make sure to set priority as cd/dvd, then hard drive, then network or disable network boot. network booting causes media failure.
Mar 20, 2008 | Computers & Internet
Toshiba Satellite A60 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
