Question about Panasonic PT-47WX49 47" Rear Projection Television
PT-47WX49 Panasonic TV turns on, then immediately shuts off? Is this a fuse or capacitor that I can replace? Is there something to reset?
  • pcrawford655 Nov 18, 2009
    No the TV turns on, the picture comes on for 2 seconds than the entire thing shuts off. No lights at all. We have to unplug it in order to turn it on again...then it immediately shuts off again...and so on...and so on.
    Thank you!
  • SD Tech
    SD Tech May 11, 2010
    LET me know if the power light blinks--this code will tell if there what the problem is---if it blinks when the set does not come on COUNT THE BLINKS AND LET ME KNOW. sd tech
  • Panasonic Master
  • 5,138 Answers
Look over around the FBT flyback transfomer coming from hori out put Transistor is a Blue capacitor 2K volt they will somtimes burn with a xmall hole on them if it is bad high voltage will not come up and stay on Call Mats for Part 1-800-628-1118 resolder all poor connections even where the Yoke plugins are which are near the FBT & hori output Transistor.
Posted on Nov 18, 2009
My Panasonic PT-60LCX64 Television shuts off after 5 minutes then I turn in on and it stays on for however long I want
You might check your power supply for a bad capacitor. Look for a swollen top and replace if necessary.
Mar 15, 2013 | Panasonic PT-60LCX64 Television
My Panasonic PT - 47WX49 rear projection wont turn on - it would go on for a second and shut down - then 3 red blinks - so i changed out the IC's now it powers on but immediately shuts down and only 1...
Thats the 140 Volt error. Usually caused by the bridge connectors that connect the two circuit boards or the red HV cable from the flyback not being connected properly
Dec 29, 2009 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX49E just shut off
maybe the convergence resistors? sometimes when the ics blow a resistor or a few blow
Jan 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
TV powers up for literally a second then shuts down (PT-47WX49)
check R517 on the power supply board if burnt replace with 5% 1/4 watt 10K carbon resistor.
Dec 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Tv powers off after 1sec being on?
does the led flash when you try to press power after it shuts down, or when it shuts down? If so how many times does it flash?
Jul 18, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Help please
called h.v. shut down call tv repair shop
Sep 18, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49E will not power on
Thats a power supply module going bad. Dont use it until a person with knowledge on TV see that. Or if you feel you can DIY open the back panel to see if there is a toasted or foreign object near the power supply area. Its located when you follow the main plug going into the back panel of your TV. Look for a dying Fuse too. And watch out for Capacitor that has still current, you may electicuted with that component. That parts its only for qualified servicemen area only.
Aug 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 Convergence IC
usjavelin. I have the pdf files for the tv. I own the same one. I can send them to you if you'd like.
Dec 16, 2006 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
274 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
