Question about Konica Minolta 5600HS for Maxxum Minolta TTL Flash
I have a Minolta 5600Hs flash. It's worked great
I have a Minolta 5600Hs flash. It's worked great for several years and recently just stopped turning on. I live in a high humidity area and it's been raining a lot recently but the flash has been through several years of this. Should I try to fix it (professionally or by myself) or just toss it?
  • 685 Answers
I would not recommend you fix it yourself since several of the inside componentes are high voltage and dangerous. But, why wont the flash turn on? if the batteries are good, could it be the battery contacts on the battery door and inside the flash? If the batteries have ever corroded (even a little) then that would be the problem. Use a pencil eraser to shine up the contacts until they are bright and shiney clean. Do not use sand paper or anthing vabbrasive as that will cause the contacts to corrod more and the problem will be worse.
Posted on Nov 21, 2009
Wide angle defuser is broken Minolta 5600hs
It's not a problem if you're not using a wide-angle lens. And if you are, you can always diffuse the flash by putting a thin white handkerchief or even a sheet of tissue paper over the flash.
Jan 10, 2013 | Konica Minolta Minolta 5600HS D - Hot-shoe...
I am looking for manual of minolta 5600 hs d
Here is an online manual for your digital camera:
http://www.scribd.com/doc/22344755/Minolta-Maxxum-Flash-5600HS-D-Manual
Hope this helps!
Remember to Thumb me Up lots for all the hard work! :D
~~Dayminner
Jun 03, 2011 | Konica Minolta 5600HS for Maxxum Minolta...
I have a Minolta 5600HS flash that I have used for four years with my maxxum 7d without a problem until recently. The flash continues to function fine while on the camera and can be set to wireless mode on...
It could be a simple connection that is loose and just need to be put back into position, or it could be a controller circuit that is bad and needs to be replaced. This is not a user repairable problem. It should be sent in for repair.
Jan 20, 2010 | Konica Minolta 5600HS for Maxxum Minolta...
MINOLTA DYNAX 5400 HS flashgun manual
Since Minolta quit the camera/flash biz, Ebay is your best bet for a printed copy.
To get a free pdf file, Go to KM global website.
Select Canada, as yer country.
navigate your way to downloads.
Also check the Orphan camera website.
I have a pdf for one, but I am not allowed to give it to you here.
Try the Minolta groups on Yahoo.
Aug 11, 2009 | Konica Minolta 5600HS for Maxxum Minolta...
QUANTARAY QBX-8000xi Flash for SONY ALPHA - 350 digital SLR
Unfortunately not.
This flash is a superb budget alternative to the Minolta alternatives but is only suitable for their film cameras. Sony's SLR's are based on the later Minolta Digital SLR's and they're all incompatible with this flash.
The technical differences between the film and digital Minolta cameras explains why a Minolta 5600HS (for example) had to be redesigned and redesignated as a 5600HS(D). The former will not work on Sony Alpha models, but the latter is fully compatible.
May 13, 2009 | Quantaray QBX-8000XI Wireless Remote Flash
My minolta 5600hs flash does not flash all the time.
Is your Flash on Forced Mode or auto mode? If it's on Auto mode, the camera decide that flash work or not! but if it's on forced mode, I think there is a hardware problem... I hope this helps
Nov 02, 2008 | Cameras
Quantaray QBX-8000xi owners manual
1. No.
Unfortunately not.
2. I haven't managed to find a manual for this model in my stock room and failed to trace one online.
Nov 01, 2007 | Cameras
Is wireless/remote flash available?
Yes. Wireless / Remote Flash allows the camera to control Minolta 5600HS(D) and 3600HS(D) flash unit. (sold separately)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Can the conventional Maxxum/Dynax flash units be used with this camera?
Yes. The following Minolta dedicated external flash units are compatible with the DiMAGE A1 for automatic flash control: Program Flash 3600HS(D), Program Flash 5600HS(D), *Program Flash 2500(D), Macro Twin Flash 2400*, Macro Ring Flash 1200*. * Program Flash 2500(D) will be available around August, 2003. *Macro Flash Controller is necessary
Konica Minolta 5600HS for Maxxum Minolta TTL Flash Logo
168 people viewed this question
Top Konica Minolta Cameras Experts
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
