Question about Zyxel P660HW-D1 Router
I need to change my nat type from strict to open
    Novelist:
  • 138 Answers
This router does not have the typical "strict or open" NAT types. Looking at the manual, it looks like what you want is NAT enabled and SUA only enabled.
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420041221102511,420041221102520,420050117110858,420050117110916,420050117110934,420050831093216,420050831095441,420060420160946,420060420161739,420060816160116,420080815092146,420090427144843
Page 133 has the details.
Log into router
go to the NAT tab
Enable NAT
Enable SUA only
Apply the change.
Posted on Nov 18, 2009
  • 2,263 Answers
You may need to change some settings on the router.
I can suggest you all guys to use this webpage to change settings on the router for open NAT type
Posted on May 21, 2012
  • 5 Answers
SOURCE: set nat to open
These routers have a setting underneath the advanced tab (within advanced setup) called UPNP.....all three of the active tick boxes need a tick in (by default they don't) and this will sort the NAT stuff out.
Posted on Jan 30, 2008
acdr
  • 1913 Answers
SOURCE: how to fix nat on xbox live
type "msconfig" in run
then startup then disable all.
then aply ok
then restrt .
thats it.
Posted on Nov 15, 2008
Joed911
  • 4338 Answers
SOURCE: Change NAT to open
Open an Internet Explorer browser page.In the address bar type - 192.168.1.1
Leave username blank & in password use admin in lower case...
Click on "Applications and Gaming" tab and then click on "Port Range Forwarding" subtab...
1) On the first line in Application box type in ABC, in the start box type in 88 and End box type in 88, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
2) On the second line in Application box type in PQR, in the start box type in 3074 and End box type in 3074, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
3) On the third line in Application box type in XYZ, in the start box type in 53 and End box type in 53, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box and click on Save Settings...
3) Once you return to the set up page click on the Security tab and uncheck Block Anonymous Internet Requests and click on Save Settings...
4) Click on set-up and change the MTU Size to 1452 and click Save Settings...
5) Goto the XBox Network Settings and IP Address Settings and select manual IP Settings and assign the following on your Xbox
IP Address :- 192.168.1.20, Subnet Mask :- 255.255.255.0, Default Gateway :- 192.168.1.1...
6) Also assign the DNS Addresses on the Xbox
Primary dns :- 4.2.2.2...Secondary dns :- 192.168.1.1
7) Turn off your modem, router, and Xbox...Wait for a minute...
8) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect... Kudos! Thanks! If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 05, 2009
govinda123
  • 2263 Answers
SOURCE: how do I change my nat from strict to open
you will need to change some settings on the router.
reduce the MTU . IF the MTU settings on the router is 1500 then change it to 1365.
Also you will need to open some ports on the router.
I hope the following link will help you.
Click Here for more information
Posted on Nov 10, 2009
govinda123
  • 2263 Answers
SOURCE: bt home hub change my nat from strict to open
reduce the MTU. If the MTU settings is1500 then change 1365.
also you will need to open the some ports on the router.
Posted on Dec 04, 2009
I won't to change my nat type
You will need to change the firewall settings of your router. If your Internet service provider is DSL then make sure that modem is in bridge mode. How to change NAT type to open
Nov 29, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Tip
Xbox live NAT
Simple Rules
-if your NAt is strict and cannot connect
try turning your hub off for 30 seconds then turning it back on
if that didnt work.
-try resetting your IP address.
if that didnt work
-take addaptor from xbox to pc out for 30 seconds, then put it back in
if that didnt work
- try opening thies ports
TCP 53
UDP 53
TCP 80
UDP 88
UDP 3074
TCP 3074
Helpfull Info
Sometimes depending on the router brand, it's not possible to open your NAT, this simpily becuase some are not specificly designed for Xbox Live purposes. A good example of this is Belkin routers. These brands are most commonly made for Buissness connection servers. If you are experiencing a STRICT/MODERATE Nat with a Belkin router, the chances are you are going to have to deal with it, but that is not 100% of the time. If you've have attempted several techniques to open your Nat and the changes arnt happening, i'd recommend a 'N' powerd Belkin router, the most majority of these routers work 100% perect for Xbox Live, I myself oned one but changed due to a broadband switch.
How do I change the NAT firewall protection? (Open/Moderate/Strict)
Find your IP address number then type it in on your web browser, this will bring up all your switchable options where several options can be changed to your approval. The NAT firewall is one of these options which can be changed. (like I mentioned before, if you own a Belkin router, the chances are even after changing the fireall level, it will turn back to moderate or strict)
on Feb 17, 2010 | Computers & Internet
How do I change the NAT type from strict to open so i can play xbox 360 I have a Belkin 3D54 router
There are several things you need to configure in order to change your NAT to open. Here's a link to help you out:
http://support.xbox.com/en-us/pages/xbox-live/troubleshoot/connection-issues/nat-type-strict.aspx
It has steps that can help resolve your issue.
Mar 27, 2011 | Belkin Office Equipment & Supplies
I need to change the nat type to open and and not strict
Fot your to change thesettings of the NAT of your router you need yo access the router page by opening a browser and type 192.168.2.1 on the address bar. It will ask you for a username and password. The default username is admin and the password is 1234. The click on the NAT settings on the left part of the page.
Thanks for using Fixya.
Jan 27, 2011 | Edimax BR-6226n nLite Wireless Broadband...
Dlink dir-615 change nat from strict to open
reduce the MTU. if the MTU settings on the router is 1500 then change 1365 also you will need to open the some ports on the router.
Jan 04, 2010 | NetGear DGN2000-100NAS Router
Ok my nat type is strict and i am trying to change to open
You want the NAT open for X-box ?
For X-box you will need to open some ports on the router.
Also you will need to reduce down the MTU on the router to 1365.
That will work.
for this you will need to open the router set up.
Click here for more info about x-box and router settings
Dec 09, 2009 | Actiontec Computers & Internet
My NAT type is strict on xbox live and i want to change it but dont know how
You need to access your router admin (refer to router manual) and change the NAT type to open.
Nov 27, 2009 | Microsoft Xbox 360 Console
Change NAT from strict to open
You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
Jun 01, 2009 | Zyxel P660HW-D1 Router
Change NAT to open
First make sure your security type on the router is WEP-Personal. You may need to get the port range for that game or manufacturer. Then enter them in to the gaming tab. This will keep ports open all the time. NAT 2 is acceptable but you want NAT 1. Some internet connections cannot get NAT1.reply if you need further assistance
Mar 13, 2009 | Dynex DX-E401 Router
Change NAT to open
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
Oct 08, 2007 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router Logo
8,579 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
