Question about Acer Extensa 4620 Notebook
No audio output device installed? - Acer Extensa 4620 Notebook
  • Clayton Molle May 11, 2010
    What Operating System is on this laptop? Have you verified the driver for your Audio Card is installed? If this has Vista on it, try plugging in a headset into the audio out port. Vista should recognize the connection and enable the port. If this does not work, check to see if your Audio Card is installed and working. Click Start then Control Panel. Click on System then, on the left side, Device Manager. In the Device Manager window, look for the Sound, Video and Game Controllers section. Expand it and look for anything ending with "Audio Device" or "Sound Card". If this is blank and you have an "unrecognized device", you will need to download and install drivers for this device.
    President:
  • 414 Answers
Though itz unclear to me of wat os u r using..
assuming that u r using win xp pro sp2..n directx installed..
check if Audio device is enabled in bios..
howevr,downloadmicrosoft kb888111update n install it..u need to re-install orupdatethe device driver (may b manually)..logon to internet n seekthepackage/audio driver..along wid the company, there will b a list ofsuchsite n driver download links if u search by the model name on asearchengine (like google)..
http://www.laptops-drivers.com/acer-notebooks/download-acer-extensa-4620-driver-for-win-xp.html
downloadthemonto a location; if the driver is in a zip format, unzip it,ifitzin.exe form, just run it; if done manually it'll ask for thecorrectdriver and location; relocate the path and a.inf file (wat it'llaskfor)....goto the device manager n verify, if installed properly..!!
also download n install "k-lite mega codec pack"....
ifnotfixed try using a standby pci snd card (this step will b applicablefor desktop users, in such case it'll b a confirmedcase of ur systemboard is likely to b defective)..
but always better to consult ur system admin/vendor....
Posted on Nov 18, 2009
  • 600 Answers
Maybe you have no device(audio) drivers installed
check out this link...
4 Suggested Answers
sgarrand
  • 25 Answers
SOURCE: no audio output device is installed
On Acer's web site I found the Realtek Audio Drivers.
Posted on Mar 14, 2009
SOURCE: no audio output installed in my aspire 5100 laptop
Try using VLC as your player. Go to www.google.com andin the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Downloadand install it. It downloads and installs in 3 minutes or so. It'sa very fast player, smooth and it can play just about any type of dvd formatsand media. It's totally FREE.
Posted on Apr 26, 2012
bronk50
  • 27725 Answers
SOURCE: no audio output device is installed on my acer aspire 5535 laptop
which operating system ?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver you might have to try a few times to get it right
for windows 7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select
playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although
once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps
Posted on Sep 25, 2012
My pc says no audio output device installed,but in device manager it says its working properly and the drivers are up to date
Well it is possible that the audio driver installed is not the one compatible with you computer board. Try downloading the specific driver needed for your computer's official website. This should solve your problem.
Sep 06, 2011 | Computers & Internet
Audio output device
Hi.
The audio output device in your computer is the audio adapter board (or circuit). This is the device that produces sounds and send them to the speakers.
If you get a message telling you that there is no Audio Output Device detected, or that the Audio Device is not working, that usually means that there is a problem with the audio driver.
In that case the problem is often fixed downloading and reinstalling the drivers for your audio device. If there is a problem with the audio output device, go to the computer manufacturer website (e.g. Dell, HP, Sony etc.) and download the audio drivers for your specific model. When download is complete install the drivers and restart the computer.
Regards.
Ginko
Jul 20, 2011 | Microsoft Windows Vista Home Premium with...
My pc says no audio output device is installed
You have to install the audio driver for the audio device first. As for the output audio it is for speakers connect/plug into to the output audio port.
Aug 06, 2010 | Microsoft Computers & Internet
No audio output device installed and the screen goes off when connected to a projector
For no Audio output device installed message, go to device manager uninstall the audio driver. Reinstall the audio driver from either Windows update or from the manufacturer's(your Computer or Laptop) Web site.
Apr 29, 2010 | Lenovo ThinkPad T61 Notebook
Its appeare in my computer no audio output device is installed
why realtek ac97 audio not being installed in a windows vista?
May 30, 2009 | TerraTec Electronic AudioSystem EWS88MT...
Problems with audio after installing radeon hd 2400
This happens because the video card has hdmi output. Since hdmi output can carry audio signals also, the audio driver gets disabled. Uninstall audio driver and video driver both, install the video driver, and then install audio driver. after installing the audio driver, in playback and recording devices choose choose the audio output device you purchased along with the computer. This should fix the issue.
Revert back for any clarifications.
Warm Regards,
Zulfir Sadat M
Apr 12, 2009 | Diamond Multimedia Stealth RADEON 9250,...
Can't install audio driver
i can't use the audio output device,,, it always says no audio output device is installed..
help me pls..
Apr 11, 2009 | ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2...
NO AUDIO OUTPUT DEVICE IS INSTALLED
its a known issue --if you u upgrade vista home to vista ultimate.just u need to uninstall the audio driver and install it again
Dec 22, 2008 | Microsoft Windows Vista Home Premium with...
How do i install audio output device
No Audio Output Device Installed
Some users have been experiencing problems with a "No Audio Output Device Installed" error when trying to play music, or when hovering the mouse over the speaker icon in the system tray. You may get a white X in a red circle to indicate this error.
Go to the device manager by pressing WINDOWS KEY + R to go to the run menu, and then run "devmgmt.msc".
From here, select your malfunctioning audio device(s) and make a note of the driver name. Then, right click on it and select Uninstall. This will remove the audio drivers from your system.
Once this is done, re-load the drivers for your sound card from the CD your manufacturer gave you with your PC or sound device. If you cannot find this, search for the driver on the manufacturers website using the driver name that has been written down. No Audio Output Device Installed
Aug 26, 2008 | Toshiba Satellite A135-S4527 Notebook
windows key + R = open : devmgmt.msc
Sounds, video and game controlers > (right click) Realtek high definition audio > update driver sofware > browse my computer for driver software > let me pick from a list...> double click on Realtek high definition audio > YES to update driver warning > AND SWEET SOUND IS AUDIBLE :D
Dec 14, 2007 | Microsoft Windows Vista Ultimate Edition
Acer Extensa 4620 Notebook Logo
235 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
