Question about Alesis Sr 16 Stereo Drum Machine
Looses presets when pressing stop button - Alesis Sr 16 Stereo Drum Machine
  • Alesis Master
  • 5,603 Answers
I believe you have to save the performance as a song or the settings will go away when you reset the unit.
Posted on Nov 18, 2009
Won't load to default
Hi Lloyd,
The introduction in the manual warns that you should ask your dealer or store in order to change the batteries. I'd suggest seeing if they have any advice.
That said, how are you trying to default the settings? I've copied the two ways below. Maybe try whichever one you haven't yet. I hope this helps.
Manual: http://hammondorganco.com/wp-content/uploads/2011/03/XK-1manual.pdf
Default #1:
In this mode, you can return entirely or partially to the default setting as set at the factory.
To locate this mode:
Touch the [MENU/EXIT] button for the MENU display, select PAGE D by the [PAGE] button, and then touch the [3] DEFAULT button. To initialize each parameter, touch the button and then [4] OK
1. ADJUST PRESET
  • Initializes the content of the Preset Key [B].
  • If the Drawbar Control mode is at "UPPER A#/B", the content of [A#] is also initialized.
  • If you do this operation before you start a new setting, you can start from the factory
  • setting.
2. PRESET
  • Initializes the content of all Combination Presets.
3. GLOBAL
  • Initializes the Global Parameters such as Master tune or assignment of the Foot Switch.
4. LESLIE
  • Initializes the content of all Cabinets.
5. ALL
  • Initializes all parameters of this keyboard.
  • If anything caused an unstable trouble on this keyboard system, the trouble would be cleared.
Default #2
Please perform the following steps to reset the XK-1 to the initial default setting.
1. Switch off the power of the XK-1.
2. Hold the [REC/JUMP] Button, and switch on the power.
3. Continue to hold down / Keep pressing the [REC/JUMP] Button until "Loading Default..." appears on the Display.
4. After 5 seconds if everything is in order, PLAY Mode appears on the Display. (Completed)
Dec 20, 2013 | Hammond XK1 Pro Drawbar Organ
Cannot format or reload factory presets after it stopped working
The card that you used to transfer the files HAS to be (1) FORMATTED by the ESX-1 unit FIRST, (2) then put the card into your computer's card reader and download the files. (3) Put the card BACK into the ESX-1 and try reloading the factory presets. Good luck!
Jan 11, 2013 | Korg ESX1 Electribe SX production station...
Db60
If you have the beat generated, and merely want to save it, press Write Button once. Use the tempo up and down arrows to select the memory location and press the Write button again. it should store it.
If you are just looking for a different random shuffle, the metronome is hard coded and limited to what you can change on it.
If you did not get the owners manual, it is here:
http://media.rolandus.com/manuals/DB-60_OM.pdf
Apr 10, 2012 | Roland Boss DB60 Dr Beat Metronome
How to factory reset mpd18
Heres how to restore your MPD24 factory defaults using the Vyzex software:
1. Plug in your MPD24 with USB cable, and then open the Vyzex software.
2. Click File > Open
3. Select Factory SET.SQS, and click open it.
4. You should now see BFD Lite and other details on the Vyzex MPD image.
5. As long as you're on the DATA tab, you should see a PUT SET button available. Press it to transfer the factory presets to your MPD24.
6. An overwrite warning will be displayed. Press YES to overwrite your damaged MPD24 presets with the factory presets.
You'll see a progress bar filling up for about 10 seconds, and then once it disappears, that's it!
You're all done - Enjoy!
Jul 29, 2011 | Akai Professional MPD18 Steven Slate...
How do you do a hard rest with the m-audio axiom 25 generation 2 ? DirectLink stopped working, I need to find a way to fix it.
Hold down the LOAD and SAVE buttons while powering on the Axiom will do a hard reset. This will erase any presets you've set up and restore the Axiom to the factory defaults.
Hope this helps,
Stewart
Mar 01, 2011 | M-Audio Axiom 25 G2 USB MIDI Controller
When i press the harmony effect i have to hold it
Well i hope the latching mechanism isn't busted!
Check/review your parameter settings for your programs. Especially in the Expression Pedal Control areas.
From their site:
--Harmony Footswitch
This footswitch turns the harmonies on or off. While multiple harmonies can be selected within a preset, the HARMONY footswitch activates or deactivates any selected harmonies simultaneously.
When the LED above the HARMONY footswitch is illuminated, the harmonies are on. When the LED is turned off, the harmonies are turned off.
--Note: The settings for FX Footswitch Control, Harmony Footswitch Control and Guitar Sensitivity apply to ALL presets. The setting for the Expression Pedal Control applies to the current preset only. If you modify the Expression Pedal setting and wish to store it you must Store the preset (see page 11 ). When you load another preset, its setting for Expression Pedal Control will take effect.
--To perform a Factory Reset procedure
If you are editing a preset, press the Up or Down footswitch to exit edit mode.
Press and hold the Major/Minor button and then press and release the Store button. The display will read FAC RESET- WILL ERASE ALL YOUR PRESETS... , then STORE=RST.
Press the Store button again to continue with the factory reset. If you don’t want to do the factory reset, just wait 5 seconds, or press almost any other button, to cancel.
Mar 27, 2010 | Digi-Tech Digitech Vocalist Live 4...
Wheres the preset button on a line 6 spider III 30 WATT
I am guessing that you are trying to replace the presets the amp comes with, with your own. In which case all you do is dial in the sound you want and then hold either the clean,crunch,metal, or insane buttons until you see the light flash. Usually hold it for about four seconds.
Mar 08, 2010 | Line 6 Spider Iii 30
I have a Fender Cyber Twin that does not save my settings. I can set up my volume,gain, treble ect.. hit save button to store the setting and if I switch settings to a different sound and back to the...
From the manual... is THIS the proceedure you are using to save the settings?
 T o SAVE:
1) Press the SAVE key once and a prompt displays the PLAYER’S
LOUNGE preset about to be replaced, (example prompt shown).
2) Rotate the DATA WHEEL to select a PLAYER’S LOUNGE preset to
overwrite with the currently active amp design
(last chance to press EXIT, cancelling the save).
3) Press the SAVE key a second time to complete the save.
Jan 24, 2010 | Music
I bought an Alesis SR-16 drum machine from an online seller advertised as "new". I plugged it in, and it appears that my "new" machine has had all the factory preset patterns erased! Is there a way to...
Hi.
The SR-16 has 50 preset patterns that are built in, I do not think they can be deleted, if there are no patterns the unit may be defective, even if patterns can be reinstalled using an rmidi file or re-flashing the unit.
To reset an Alesis drum machine you have to hold down both Play and Erase buttons while you power on the machine at the same time.
If that does not work, the presets are held into an rmidi file , the Rmidi file is not available for download. I think it can be purchased contacting Alesis or Rmidi.
I quote from Alesis Rmidi page:
"A rMidi Import/Export File named 'Sr16PresetKits.xml' containing the Sr16 Preset Kits has been installed within the folder named 'Sr16' within the directory in which you installed the rMidi FrameWork software. You can Import these Kits into the rMidi Drums Control if you wish. "
Check if you have the file in the folder.
If not the Sr16 will allows you to export your User Drum patterns, but I do not think you can export factory patterns.
Nov 20, 2009 | Alesis Sr 16 Stereo Drum Machine
My 150 w spider III looses power after on for 60minutes. no volume, all preset button lites go off, but preset names stay lit up. Goes off for a few seconds, comes on, goes off. Have to turn amp off and...
Sounds like a power supply problem. Likely have to go to a repair shop unless you are electronically capable.
I would expect either a cracked board or bad solder joint is causing the problem.
Oct 06, 2009 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Alesis Sr 16 Stereo Drum Machine Logo
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
