Question about HP Computers & Internet
My printer spooler does not work and I need it to be able to use any printer on my computer. Both of my laptops have the same problem that states that the printer spooler is not working or on and needs to be turned on before printer can be instaalled. What do I do? Is this a glitch with Windows Vista or HP?
I have an Advent 5302 laptop with Windows Vista. The printer is a Lexmark X5150 All in One. It was installed ocrrectly and functioned properly. Suddenly it stopped. So I uninstalled and reinstalled. Now I am told the printer spooler is not working. I have tried various suggestions from Microsoft online and still it does not correct the fault. I have followed the steps you have suggested to start the spooler manually and still nothing materialises. What next? Appreciate your asssisance. Am sure there is a simple explanation/solution. Thanks Andy , London
Posted on Mar 27, 2010
    Novelist:
  • 138 Answers
You can manually start the printer spooler...
click the Start button and, in the Start Search area - type in compmgmt.msc then hit the ENTER key. This starts Computer Management.
On the left side, go to the bottom and expand the Services and Applications area. Click on Services.
On the right side, scroll down to Printer Spooler, right click it and click Properties.
Change the Startup Type to Automatic and then click the START button.
If this fails to start, this may be caused by a recently installed program.
Please report the results of the above suggestion.
Posted on Nov 18, 2009
While installing my printer driver the warning appears that your printer spooler is not working
You need to go into services and enable the print spooler.
How to start or stop the print spooler?
  1. Right click on My Computer (Computer on Vista) and select Manage
  2. In the console that opens, pull down the Services menu and applications
  3. Click on Services
  4. Double-click on the Print Spooler key
  5. In the "General" tab, go to Startup Type
  6. Set the value to Automatic, Manual or Disabled
  7. To enable or disable the print spooler service immediately, click Stop or Start
  8. Finally click Apply
Mar 02, 2011 | Computers & Internet
Printer Spooler Problem ??
install new driver , search for it.
try a different cable for the printer, are you routing it from the scanner ? work the scanner.
go to trouble shooting see what it says.
go to adifferent port.
print a test page from the PC.
security setings from pc to router??????????
Vitally
Sep 10, 2009 | Dell Dimension 2400 PC Desktop
Print spooler not running
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
thanks.
Jul 11, 2009 | HP Office Equipment & Supplies
My printer wont print it has a spooler problem.
To start and stop the print spooler
  1. Open Computer Management.
  2. In the console tree, click Services.
    Where?
    • Computer Management/Services and Applications/Services
  3. In the details pane, double-click Print Spooler.
  4. Do one of the following depending on the task you want to do:
    Click Stop to stop the service.
    Click Start to start the service.
Notes
  • To open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management.
  • When you stop the Print Spooler service, it might stop other dependent services.
  • The print spooler runs under the Local Computer system account by default.
Once you get here you should be able to restart the print spooling service.
Mar 25, 2009 | Epson Printer
Computer states printer spooler is not activated
Go to Start, Control Panels, Administrative Tools, Services.
Windows 2000: Go to Start, Settings, Control Panel, Administrative Tools, Services.
Right click on the print spooler and select Properties.
Click on Dependencies to view a list of all the system components that the print spooler depends on.
Under Services, go to each of these dependencies and check the properties. In each case, ensure that the Startup type is set to Automatic, and that the Service status is set to Started.
Jan 06, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer Spooler error 1068
Hi jbaratta,
This sounds like a software problem (in other words, your printer is not the issue). Here's what I suggest:
1) Save whatever you were attempting to print, and restart the computer. Try printing it again.
2) If it doesn't work, try uninstalling the software for your printer, and then re-install it. In the event you don't have the software handy, you can download the driver from this website:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
If it still doesn't work, please let me know, and I'll be happy to offer some more ideas. Hope this helps!
Kind regards,
H2H
Dec 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Print spooler error during printer installation windows vista
Nov 23, 2008 | HP Pavillion ZV6000 Notebook
Both power & feed lights flash
Information gathered: Basically the printer carrier has stalled.
Lexmark documentation states that you should turn off your printer and wait a few seconds and turn the printer back on.
Restarting the spooler will sometimes do the trick as well.
Go to start, run
type: <cmd> without <>
Command prompt will open up.
Type: net stop spooler
The spooler will say it stopped successfully.
Type net start spooler
The spooler will say it started successfully.
Hope this helps!
Jan 20, 2008 | Lexmark JetPrinter Z22 Color InkJet
Printer
Try this first:
CAUSE
This error occurs because the Spooler service has not been started or has stopped working. To start the Spooler service, follow these steps:
1.Click Start, and then click Control Panel.
2.Double-click Administrative Tools, and then click Services.
3.Double-click the Printer Spooler service, and then change the startup type to Automatic. This sets the Spooler service to start automatically when you restart the computer.
4.If you want to start the spooler service immediately, click the Start button under the Service Status field.
STATUS
Microsoft has confirmed that this is a problem in the Microsoft products that are listed at the beginning of this article.
From: http://support.microsoft.com/default...;EN-US;Q314876
Jan 16, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
