Question about Gateway FPD2275W LCD Monitor
MONITOR DISPLAY i HAVE COMPUTER MONITER OF SAMSUNG BRAND SYNCMASTER763DFX MODEL. DISPLAY WIDTH HAS INCREASED ,CANNOT BE ADJUSTED BY MONITOR CONTROLS. HOW TO ADJUST THE WIDTH OF DISPLAY AND PINCUSHION/TRAPEZOID?
  • 589 Answers
6ya staff
SOURCE:
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
I m using acer moniter,i got the probs with its screen display..width of the screen is expand until max n now pic doesnt look good because width is wider then its height...can u pls assit me how to decrese...
You need to set the PC VIDEO resolution to the native resolution of the monitor to get correct aspect ratio (not adjustable at the monitor, the adjustment is doen at the PC VIDEO card setting), you need to find that out from your monitor owner manual.
Mar 22, 2010 | Computers & Internet
I have a u220w monitor which has a rectangular screen but the picture is square leaving both sides black for about 3 inches on each side. I want to fill the entire screen. I just had the windows vista...
Dear You need to adjust the computer resoultion to one of the following..
1088 x 612
1280 x 720
1360 x 768
you can increase it more; depends on your graphic card installed in system..
HOw to change the resoultion??
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor.
Changing the Resolution
To change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box (see left), if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Let me know if it helps...
rate me..
regards,
Dec 04, 2008 | Computers & Internet
Width increases a bit on lowering and incresing resolution
Hence my earlier suggestion of lowering the resolution, it was actually a test.
Now we are getting somewhere. Yoke is definitely out, opposing diode pair is also out. The remote chance of the horizontal sync/oscillator is also out. That leaves us only with a possible resistor that has gone up in value (or is open) (least likely) and/or a capacitor (most likely) that has leaked, bulged or whose capacitance has gone down.
Perhaps a service manual would be of more help.
Good luck.
Jul 20, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Control lock
Temporarily you can -- hold down, while monitor is on and the menu button for 10 seconds (source Samsung faq). This hould unlock the buttons.
This problem is due to abad 7805 regulator ic ora memmory ic
To completely stop this you will have to replace the 5 v regulator
Jun 09, 2008 | SAMTRON 55V 15" CRT Monitor
Samsung Monitor control lock problem
this problem is due to abad 7805 regulator ic ora memmory ic
Nov 22, 2007 | SAMTRON 55V 15" CRT Monitor
Dell m992 monitor screen width
The link below is a Digitally signed M992 monitor driver. http://support.us.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R44148&formatcnt=1&libid=0&fileid=51992 Also try upgrading to the latest ATI software and drivers. You can also try and change the frequency refresh rate to 75mhz. It in the Control Panel under 'Display' and tab 'Monitor'. It shows a list for frequencies you can try.
Oct 02, 2007 | Dell M992 19" CRT Monitor
Width of picture increase
Have you checked your display adapter settings? Check the display settings in control panel. Make sure you are viewing the screen at a decent resolution. 800/600 or larger. Let me know what happens. Good Luck, Tim
Feb 14, 2007 | LG Studioworks 563N 15" CRT Monitor
Width problem
To have unlock your control (auto-adjust ...) you have to hold down the "menu Key" for about an 10 seconds. This will unlock your monitor! [email protected]
May 30, 2006 | Samsung SyncMaster 753S 17" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
137 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
