Question about Compaq Armada E500 Notebook
How do i upgrade the BIOS - Compaq Armada E500 Notebook
    Novelist:
  • 138 Answers
Enter your make and model in this web site...
http://welcome.hp.com/country/us/en/support.html
Answer the OS question and go to the download page. There should be a BIOS section - if not, try a different OS option (Windows XP or Windows XP Professional).
The BIOS download will have directions on how to extract the file and if you will need to use a floppy disk to install it.
Posted on Nov 18, 2009
HOW TO UPGRADE INTEL 945GCLF MOTHER BOARD BIOS. BIOS VERSION IS "LF94510J.64T.0000.2009.0123.1105" & BIOS SOFTWARE VERSION IS AVAILABLE ON SITE IS " LF94510J.86A.0038.EB " WHEN I...
It seem your current version "LF94510J.64T.0000.2009.0123.1105" doesnt have any BIOS ID's which is required to upgrading. Where '0000' should have any version number.
I recommend using DOS environment when upgrading BIOS, this is the safe way flashing BIOS..so download file LF94510J.86A.0278.BI.ZIP here.
Extract all files on USB flash disk which is bootable flash disk. Run files executable on the command prompt and follow the instructions..
Aug 07, 2011 | Intel Computers & Internet
Hello I am looking for XP drivers for a "fujitsu lifebook E series 6555" laptop. I would also like to update the BIOS. Fujitsu's website doesn't even list my model...? Any help is...
hi
i have two links for you .. read and review carefully. you will get the drivers you need
http://support.fujitsupc.com/CS/Portal/supportsearch.do
FAQ, http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=FAQ
How do I upgrade the Bios for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks?
NOTE: This BIOS upgrade is for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks. The upgrade fixes an issue with the Full Dock II/LAN Dock II/Port Replicator II.
Instructions on Upgrading the BIOS.
Step 1: Create a bootable BIOS upgrade disk
This step can be performed on any system (desktop/notebook computer) running a Microsoft Operating system.
  1. Place the BIOS upgrade disk in the floppy drive of your pc/notebook.
  2. Copy the system files onto the BIOS upgrade disk to make it bootable.
  3. For example:
    MS DOS prompt: type 'sys A:'
    MS Windows:
  4. Double click "My computer" on the desktop.
  5. Right click the floppy drive icon.
  6. Select "Format?"
  7. Select the "copy system files only" option
Step 2: Upgrading the BIOS
  1. Attach a floppy disk drive to the LifeBook to be upgraded.
  2. Place the BIOS upgrade disk (created in Step 1) in the floppy drive of that LifeBook.
  3. Reboot the system. Boot from the floppy.
  4. At the command prompt, type:
    phlash /mode=3 filename.rom (put a space after "phlash" and after "3". Filename is the name of the BIOS.)
  5. Allow the system to reboot.
Step 3: Change BIOS settings (For users upgrading from Windows 9x to Windows 2000).
To allow Windows 2000 to better manage your system, change the following settings in your BIOS:
a) Boot the notebook and press F2 to enter BIOS setup.
b) Set Power Management to Disabled
b) Set Plug and Play OS to NO
Consult your user's guide on how to change BIOS settings.
Jan 09, 2011 | Computers & Internet
How to upgrade BIOS in my XW400?
Upgrading the BIOS is an easy task but not recommended unless your computer has a problem which will be solved by a BIOS upgrade.
I assume that you are aware that a failed upgrade may render you system unusable till it is reloaded. Primary cause of a failed upgrade is a power failure so please make sure your PC has a back-up power source in case of a power failure.
The latest BIOS update can be downloaded from this website.
Download the exe file on your desktop and double click on run it. It is to be used on Win XP or 2000.
Before upgrading, check the version of your BIOS. If the version number is same as the one with you are upgrading, it means you have already the latest BIOS and it is not necessary to upgrade. The version number of this BIOS is 3.06 Revision A.
May 14, 2010 | Compaq XW4000 PC Desktop
I want to upgrade the bios of this motherboard. but when i run the update program (download from asrock.com), a menu is display and i dont know what to do..On the asrock web page you should only run the...
Doing a BIOS-upgrade incorrectly can "kill" the motherboard. If you _need_ to upgrade the BIOS, take the computer to a qualified technician.
If you do _NOT_ "need" to upgrade, then don't try.
Mar 26, 2010 | Asrock P4I45GV R5 Motherboard
Can I upgrade Vaio laptop bios in Dos?
BIOS upgrades are USUALLY done in DOS. Most times, you need to boot from a floppy or CD that is specific for BIOS upgrade. Some BIOS upgrade software may be apllied through Windows, but this depends on your computer manufacturer.
BTW, if your computer is running ok, DO NOT MESS UP WITH THE BIOS. You may risk ruining your laptop.
IF IT IS NO BROKEN, DO NOT TRY TO FIX IT.
Mar 19, 2010 | Sony VAIO VGN-N130G/W Notebook
Can the cpu be upgraded to BX80526C1000256! If yes what modifications need to be made? Motherboard is EliteGroup P6STP-FL
Hello!
If you want upgrade you CPU, you must first know, specification of motherboard.
If the motherboard can´t see a new CPU, more exactly bios, you can try only one upgrade bios.
I give you a link for a manual and upgrade bios.
When you upgrade bios, try new CPU, if bios again don´t see a CPU, you can´t do anything about that.
Nov 03, 2009 | EliteGroup P6STP-FL Motherboard
BIOS upgrade
Go to this site, to find bios upgrades for any motherboard.
CLICK HERE
Hope this helps, feel free to leave a Fixya rating if this has helped. Thank you for stopping by Fixya!
Feb 08, 2009 | Matsonic MS8137C Motherboard
BIOS UPGRADE
go to this Dell web site http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&cat=sup&k=bios Put in the info for your comp and you can download the Bios. Also check for other upgrade for your comp.
Jan 22, 2009 | Computers & Internet
How bios upgrade
if you go to the website for your board they will have the lastest bios upgrade and flash utility. also you will find a text file that tells you what bug fixes the newer bios cures.
be that as it may.... i just don't recommend a bios upgrade if everything is working as you can cause the computer to fail if you flash the incorrect bios etc.
Robert
Sep 08, 2008 | Computers & Internet
Upgrade bios
install upgrade bios from intel tools and support
Jul 09, 2008 | Intel DG31PR Motherboard
Compaq Armada E500 Notebook Logo
99 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
