Question about Dell Inspiron 9300 Notebook
I ran my norton diagnostic test and it said my CPU was running slow. I noticed that my mouse cursor was moving slow... *sigh* what can I do for my CPU? Can I upgrade my Dell Inspiron 9300? Thank you
    Sergeant:
  • 267 Answers
First i would get rid of norton. norton takes up too much resources . and also it takes too much control of your computer. do a disk clean up and a disk defrag. that will clean up ur computer .
go to start then all programs then acessories then system tools then disk clean up. if you notice disk defrag is there also. so is system restore and system information system information tells you everything about your computer. and system restore , restores your computer to an earlier date.
i hope this information was helpful.
Posted on Nov 18, 2009
I have a sony vaio eb series white laptop. The trackpad seems to be disabled and the cursor does not move. However, if i connect an external mouse, the problem is resolved. How do i re-enable my...
Hello, you have to check on your keyboard if it has 'Fn' sign, then if it is there, hold on it and locate key that has a mouse sigh on it and hit on it and try your mouse again. onboard mouse.
Apr 02, 2011 | Sony VAIO EB Series White Notebook...
Slow pc cursor gets out of control
Hmmm... There are 2 things when the cursor goes wild, either ur mouse have a problem(dirty roller balls, open ur roller ball and clean the dirt in the wheel. And for the optic type the lens have to be clean and use a BLACK mouse pad). The other one would be ur processor is getting HOT, heat sink needs to be clean and remove DUST particles in the heat sink!
Hope that helps u out!
Nov 20, 2010 | Symantec Norton Antivirus 2010 Full...
As I type the cursor will jump backward whverever it wishes as follows. As I type the cursor will jump backwarderever it wishes as follows wh
This happens for 1 of 2 reasons: 1. Either your wrist hits the mouse pad and that makes the cursor move
2. If your mouse moves all the time without your control you need to have your palm rest replaced
When this works vote me a 10
Aug 22, 2010 | Dell Inspiron 1525 Notebook
Slow mouse on any surface
Go to the mouse option in the control panel and adjust your mouse speed and sensitivity.
May 07, 2010 | Logitech Cordless Mouse
My cursor won't move, I've had no previous problems with this
If you have an older mouse - take out the ball at the bottom and clean with soap water. Unplug your mouse and plug back in. or go to your system on control panel then under device manager and run a diagnostic on your mouse (windows should do this for you)
Sep 25, 2009 | ASUS EeePc Mouse
Laptop Mousepad and Keyboard stuttering, slow
This may be a battery power monitor issue. Try disabling the "Mircosoft ACPI- Compliant Control Method Battery" device. This is located in Control Panel-->System-->Hardware Tab-->Device Manager-->Batteries. Had similar problem with 2 Acer Aspire series laptops (diff models). 2 and 3 year old. Original batteries (both still hold charges for 1.5 hrs of normal usage). Running WinXP, one with SP2 and other had SP3. Both came in the last month with slow jerky TPAD function and nearly non responsive keyboard access. Checked the usual; virus, spyware, hijacking, driver conflict etc. Cloned drive and factory installed..still same problem with kb & mouse. However an external USB keyboard and mouse functioned normally (no lag). Noticed with Battery removed kb & mouse was normal. Finally found disabling ACPI control battery device resolved this issue while allowing laptop to run on either battery or AC.
Jan 30, 2009 | Acer Aspire 1640Z Notebook
The mouse arrow sticks sometimes and requires a complete shutdown on order to restart. Can you help?.I have tried different mice Thank you
yes i sure do!
generic malware virus.
go to this website and do a free activescan.
http://www.pandasecurity.com/homeusers/solutions/activescan/?
it's the only antivirus to detect this.
fixexe.com temprorarily removed the drag on my mouse.
http://www.mdgx.com/newtip17.htm#TIEF
i kept having a drag on my mouse and the following problems. perhaps these note will help.
MOUSE DISAPPEARS
IF YOU ARE IN THE PROGRAM INVESTOGRAPH PLUS AND YOU ACCIDENTLY HIT THEMOUSE ZOOM KEY WHILE YOU HAVE THE SOLID CROSS HAIRS ON, THE MOUSEDISAPPEARS.
OR
YOU HAVE THE CROSS HAIRS ON AND YOU ACCIDENTLY HIT THE WINDOW KEY ON THE KEYBOARD, THE MOUSE DISAPPEARS.
TO GET THE CURSOR BACK
RIGHT CLICK ON THE CHART
PRESS CTRL+ALT+DEL
HIT
START
RUN
X TO CLOSE THE RUN BOX
AND THE MOUSE CURSOR REAPPEARS.
YOU CAN ALSO RUN
NORTON WIN DOCTOR
CHECK: LET ME CHOOSE WHICH TESTS TO RUN
CHECK: REGISTRY DOCTOR;REGISTRY INTEGRITY
RUN THE PROGRAM AND IT'S FIXED
YOU CAN ALSO DO A BEGIN CHECK UP AND THAT WILL FIX IT.
YOU CAN RESTART YOUR COMPUTER AND THAT WILL FIX IT.
Nov 04, 2008 | Computers & Internet
Jumping mouse cursor
check the battery if any,maybe its leak,try another mouse,maybe the one you have is already defective.
Mar 17, 2008 | Computers & Internet
CPU usage very high, mouse very slow man
hi,
you haven't mentioned whether your mouse started moving after you deleted the applications..
Anyway to lower your CPU usage, you can do the following...
1. Run 'msconfig' without the inverted comas in the run dialog box. ( start--> run )
2. Select the startup tab... you can disable all application at startup to load the system faster. or you can select the application that you thing is unnecessary. this needs a restart.
3. Next try to press Ctrl, Alt , Del at the ssame time to launch the task manager. First you will be seeing the application that is running. Go to the next tab that is the Processes tab. under this you will see all the processes that is running and utilsing how much resources . Below on the status bar of that window you will see the cpu usage... Now identify the processes that has the highest memory usage... right click and select end process tree. the process will be stopped. Remember not to end the explorer.exe process. Most resources is utilised by Anti-virus softwares like norton, also by web-browsing and graphics opertaions....
hope to get rated as fixya!!
regards
bzoy..
Jan 03, 2008 | Acer Aspire 3000 Notebook
Dell Inspiron 9300 Notebook Logo
99 people viewed this question
Alun Cox
