Question about Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Sony KDL-52S5100: What's the recommended display settings
I have a standard definition DVR (digital cable) connected to my brand new Sony BRAVIA KDL-52S5100 52 in. HDTV LCD TV. To gain best picture quality from this set, what picture settings do you recommend calibrating it to besides its default factory settings? Thanks in advance for your response(s)!!
  • 125 Answers
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Posted on Aug 25, 2009
Testimonial: "very fast, thanks for the help!"
SOURCE: How do I reset a Somy bravia KDL-52W4100 back to
While holding down the UP arrow key, press the power button. The TV will turn off and back on and reset to factory default settings. Hope this helps
Posted on Oct 05, 2009
vinnyq
  • 157 Answers
SOURCE: Sony Bravia KDL-40S2000 thin vertical line
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
Testimonial: "Thanks for the response. The service company Sony recommended told me it was probably the screen, too, and they quoted $1000."
  • 73 Answers
SOURCE: My brand new 40
This is a characteristic of the dynamic backlight used on this set.Turn off the dynamic contrast in the customer menu this should solve your problem.
Posted on Oct 15, 2009
Selvol
  • 115 Answers
SOURCE: My Sony KDL 52S5100 52 inch is great except for
Check the  user manual.  You have the Auto dark enabled.
Or so it sounds. Disable that.
Selvol
Posted on Dec 06, 2009
HDMI INPUTS DON'T WORK
It sounds like your set needs servicing. Are the other inputs working? HDMI port failures are indicative of a problem with the main board.
Sep 01, 2012 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Need a base for a display model i bought at wal-mart
If you are looking for base stand fo Sony KDL-52S5100 then I might help you to provide you part number info to buy it.
All I need is exact model number of your tv that would be written at rear to provide you correct part number of required base stand.
Thanks.
Aug 09, 2010 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Selvol
Dec 06, 2009 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
My remote for bose 321 does not work while having sony bravia 52 in same room. I purchased a brand new remote but still same thing.
this may sound strange , but htis is a service not on the sony site place a piece of scotch tape over the sensor on your TV and this should do the trick
Carxy i saod the same thing but it works
Dec 04, 2009 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
I have a sony kdl-52S5100,and every so often when i switch channels i get only half a screen,{on the left side of tv}i can channel up and down abd it stays that way untill i push the input button on my...
I work for comcast have seen 2 kdl 5100 with same issue changed to component cables issue resolved
hdmi input is the problem. Yes I did try 3 different hd boxes same issue problem is with tv .
You are obviosly the third customer with this problem
May 17, 2009 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Color screen
If you are hooked up with a DVI cable you need to either use hdmi, component cables or turn off the non hd override...
Jun 15, 2008 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Sony Bravia KDL-40v3000
NISK-TRY USING YOUR DIRECTTV MENU AND LOOK AT THE SCREEN FORMAT SETTINGS AND MAKE SURE YOU ARE AT 16X9 SETTING.JOETV
Dec 21, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony kdl-40s2000
Probably need a software upgrade. Contact Sony for that information. This would be a common fix in most sistuations when using HDMI.
Dec 30, 2006 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-52S5100 52 in. LCD HDTV Logo
466 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
