Question about Philips Magnavox 9P6034C 60" Rear Projection Television
My rear projecti Philip magnovox PTV835 has no power ,its plugged up and i get nothing
  • Philips Master
  • 5,138 Answers
Call Encompass Parts 1-800-638-3328 or try UED 1-800-649-6657 and you can try shipping your power supply Board to PTS 1-800-844-7871
Posted on Nov 18, 2009
Ptv835 phillips
It sounds like the lens fluid has gone sour. Take a look at this Fixya tip for more information on replacing the lens coolant. When it's real bad you won't be able to see the crosshairs sometimes. http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
May 24, 2013 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnovox
Its a power supply issue the only solution is to get it repaired.Possible power outage.Repair charges would be around $400.
Goodluck,
Please don't forget to rate the solution
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
I have a Phillips magnavox P960349102 model#PTV835. I have power no picture or sound. How do I fix this?
Have power/deflection board rebuilt. Probably will not last long from my experience. In reality this model is too old for a good, reliable fix (like CTC167 in RCA is too old for a good fix, and Hitachi pincushion circuits).
Jan 18, 2011 | Philips Magnavox 9P6034C 60" Rear...
ALL OF A SUDDEN MY REMOTE ISN'T WORKING. I CHANGED A CHANNEL AND NOW NOTHING. CHANGED THE BATTERIES AND TRIED TO RESET THE CODE. STILL NOTHING. HAVE A PHILIP MAGNOVOX. ANY IDEAS?
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Jun 12, 2010 | RCA RCU403 Remote Control
PTV835 PICTURE SHRINKS
Hello, I dont have a solution but I am experiencing the same problem. Did your tv get fixed ? Any solutions that you can offer ? Rudy
Jan 13, 2010 | Philips Magnavox 9P6034C 60" Rear...
No sign of power on my Phillips Magnavox rear projection TV
try replacing the fuse. it should be behind the bottom panel near the power cord
Nov 17, 2008 | Televison & Video
DPTV335
Ed did you change the yokes when you put the DPTV series CRT into the PTV chassis? If not its most likely the vertical output or the Horizontal output that got destroyed. If you changed the yoke its most likely the HV generator.
On the DPTV chassis that should shutdown the vertical deflection which would leave audio working worse case scenario would also be the HV generator and Horizontal output.
Oct 20, 2008 | Philips 60PP9202 60" Rear Projection...
Magnovox 55p8288 av does not work
Did you recently move the TV, or do you plug a game system in and out posible its as simple as the internal connector lead poped off from use...
I've added the service manual links hopefully you can find a picture of your A/V input and beable to just plug somthing back in...
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
Good Luck, hope I helped
Oct 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
Help..... Phillip Magnovox Model 9P5034X101
NOT EXPENSIVE POWER SUPPLY PARTS ARE NEEDED TO BE REPLACED . ONLY A TECH WHO , HAS EXPERIENCE ON THIS TV MODEL AND THE KNOWLEDGE ABOUT THIS PROBLEM ,COULD FIX THE TV RIGHT THE FIRST TIME. OTHERWISE REPLACE POWER DEFLECTION BOARD ,PARTS AVAILABLE AT PARTSTORE OR SIMILAR COMPANIES
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
195 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
