Question about Everex StepNote NC1502 Notebook
It won't bootup and it beeps when i start it up
    President:
  • 414 Answers
Probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/daughter or addon card(s)..
..plz do check the following as in order:..
the Hardware part:..
1)a)in power on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..[not applicable in case of laptop]..
b) in case of laptop try to get output from external display unit/monitor using vga port..if there's proper display in there..the problem is probably with either the 'lcd' or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8)on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue); -5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic', or pwm switching regulator circuit..look for defective protector-transformer/resistance(esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
if u r bot a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 18, 2009
A friend is having trouble starting up her computer and she has asked you to help. When you turn the system on, the video display comes on and you hear the disk drive spinning. Several screens display and...
It could be a number of things. Most computers are programmed with sequenced beeps, ie one long beep....cmos battery low, two short beeps...hard drive error, etc. Like Mr. Hubbard requested, I will need pc manufacturer and model number to provide accurate troubleshooting information to your friend.
Sep 05, 2012 | Computers & Internet
System up and running and getting a constant beeping.
Clean Dust inside the server & update with latest bios ,room temperature should be 18 degree Celsius
Dec 28, 2011 | HP ProLiant ML370 G4 Server
It won;t bootup
Is your monitor plugged in and turned on? There may also be a bad connection between your computer and monitor. Failing that, your motherboard may be bad.
Jul 10, 2010 | Compaq Presario 5000 PC Desktop
No bootup
try booting off a cd..if that works problly reload your operating system or replace hard drive
Oct 10, 2009 | Computers & Internet
Continous beep when turned on
It identifiees Random Access Memory failure, Open the RAM cover at the bottom of the laptop, remove the RAM card/s from the slot, get the tissue, spray a bit of glass cleaner on tissue, and wipe the gold pins of the RAM. Reinstall and have fun.
Best of luck
Aug 07, 2009 | Computers & Internet
Pc won' t go pass the product name on start up.it does let you try the f1 buttons.
go to BIOS presing f10 on system starting and disable the bootup massages option..
Mar 01, 2009 | HP Compaq Presario SR1630NX PC Desktop
Constant beeping
I would first check that all the fans are turning when you first power it up. It may have fan speed sensors on them, and one or more fans aren't coming up to speed. I would check the CPU fan(s), as they are usually smaller, and tend to go bad before the other larger ones.
Feb 22, 2008 | Gateway 960 Series (gtwy960) Server
Everex StepNote NC1502 Notebook Logo
146 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
