Question about Sony Playstation 3 (PS3) Console
My HDMI looks burnt and i cant see or hear anything on the ps3 what can i do
2 Suggested Answers
SOURCE: cant get hdmi for ps3 to work on my jvc hd 52g887
Had same problem with Panasonic PT60LC14 tv when connecting by HDMI cord to my PS3 and a blue ray disc was playing. First, read your tv manual to see what video inputs it supports . Then read the PS3 online manual (section on "video output settings").
For me I found out that my tv only supported 1080i (along with 480i/p, 780p) and the ps3 manual says blue ray outputs 1080p, so my blue ray discs will not play on my tv according to the PS3 manual. PS3 manual says to restart the ps3 (power off, then power on and HOLD for 5 seconds) - then the standard video output settings should be reset. Hopefully the ps3 menu will pop up at least. I haven't tried this yet but if it doesn't work, i'll may try to reset PS3 video out settings manually first using another tv that works with it ..
Posted on Nov 07, 2008
How do i fix my PS3 when I cant see anything, but the system itself looks to be functioning?
You are going to have to do a video reset. Witch takes the video settings of the system back to default. To do this, make sure you have everything hooked up. Power, HDMI. Then, turn the system on, push and hold the power button until the system turns off, then push and hold power button until you hear 2 "beeps" then the video settings will be refreshed. ^^
Jul 14, 2014 | Sony Playstation 3 (PS3) Console
Cant get output ps3 on hdmi cable
  • Make sure the system is off.
  • Hold down the Power Button for 5-6 seconds - until you hear the second beep.
    This resets the video settings to defaults (standard video output).
    Power up the PS3 again and it should auto-detect the hdmi at this point.
    If that does not work use the original audio/video cable that came with the system, power it on, then adjust the video settings and try the hdmi cable again.
  • May 18, 2012 | Video Game Consoles & Games
    How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
    The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
    Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
    If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
    If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
    Hope this helps!
    Sep 19, 2011 | Toshiba 26HF84 26" TV
    Cant get picture on psa3 slim hdmi or av
    conect your ps3 with hdmi to TV then put your TV on hdmi by its remote controler, ps3 is still turned of. Then press switch of/on ps3 buton and hold it for 5 - 7 second cca., You will hear a double beep sound and after that you can turn your ps3 on. Then just follove the instructions.
    Dec 23, 2010 | Sony Playstation 3 (PS3) Console
    My samsung tv wont connect to my ps3 through the hdmi cable, the tv works if i connect my laptop or anything else to it. iv tried my ps3 on my lg an it work just fine just cant get it to work on my samsung...
    When you have PS3 connected to the TV with HDMI connector, hold the ps3 power button down for 5 seconds, when u hear 2 beeps, release it and it should display standard format on the TV, thats when you'll get the option to correct the picture mode for the PS3. Hope that helps.
    Dec 23, 2010 | Samsung LN52A650A LCD TV
    No signal through hdmi ports
    Check the hdmi cables be sure their in proper working condition, wiggle the cables around see if picture comes up. If not and the cables are good then the hdmi processor on the main board of your TV is defective. Alot of times hdmi ports tend to burn so see if you smell a burnt smell near or around the hdmi ports. but before you do anything be sure sure your TV settings are correct for hdmi....
    Oct 18, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
    My ps3 is not showing the game picture on the main menu:(
    its possable thats its the laser there is a method to restor the ps3 back to factor witch might correct any software problems that might cause the laser to malfuction be warned that doing this erase all your data and restores it to the orginal factor state or like brand new here are the steps
    1. Power Off the PS3 via the power switch in back and power back on w/switch.
    2. Hold Power Button on the Front until you hear 3 beeps.
    3. Then go through the initial setup and then run a full Format via System > Format.. You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset
    hope this helps and if you can i would back up your ps3
    Jul 30, 2009 | Sony Playstation 3 (PS3) Console
    I lost my av cord but i have a hdmi cord how ill it change so i can see what im doing because i cant see anything
    Sorry, I initially posted this under the wrong help topic. You should try holding the on/off button for a few seconds until you hear 3 beeps. This should force the ps3 to recognize whatever video connection you have. If you switch back from hdmi to another type (component or composite) this will be have to be done again.
    Jul 06, 2009 | Sony Playstation 3 (PS3) Console
    I cant hear the sound on the ps3 when the hdmi plug is how can i fix that
    ok take out the hdmi cord and make sure its not dusty or anything then put it back in and when turning on your ps3 HOLD the on button for 5 secinds you will hear an extra 2 beeps and you will get a screen saying a hdmi device is connected blah blah blah just set it up to hdmi again and see if it worked
    Jun 06, 2009 | Sony Playstation 3 (PS3) Console
    Screen of my ps3 went black, i cant see the menu
    While the PS3 is off (red led)
    Hold down the power button until you hear the second beep, quickly release.
    That's it!
    May 13, 2009 | Sony PlayStation® 3 (80GB) Console
    Sony Playstation 3 (PS3) Console Logo
    42 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
